Old 05-28-2013, 01:28 PM   #1
xjohnx
Grip>Slip
xjohnx's Avatar
Bumper not lining up near fender?
I've seen quite a few 86's with this issue. Does anyone know what causes it or a good trick to fixing it? I can push it back in and it looks like it's lined up, but after driving again it reverts to its previous state.
Old 05-28-2013, 02:13 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
That's normally what happen after taking the bumper off, just as you have done.
Old 05-28-2013, 02:19 PM   #3
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
yep.. Same issue here as well. Bugs the shit out of me, hope there is a fix for this!
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 05-28-2013, 02:27 PM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
So a body panel is a single use part? HArd to believe, especially since it did this before removal as well. Has to be an install issue or something else.
Old 05-28-2013, 02:46 PM   #5
retrosmiths
Drives: Scion FR-S Whiteout
Replace the clip behind the side markers with a zip tie. Worked for me. Easier to remove in the future too.
Sent from my Galaxy Nexus using Tapatalk 2
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 05-28-2013, 02:47 PM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
i just ordered new mounting brackets (the ones that bolt under the headlights, as well as all new bumper hardware (plastic clips/fasteners). We'll see if that helps.
Old 05-28-2013, 02:48 PM   #7
xjohnx
Grip>Slip
xjohnx's Avatar
are you talking about the inner clip that goes through the side marker bracket up into the fender? or the clip that goes through the outside of the fender liner to the back side of the light?
Old 05-28-2013, 03:53 PM   #8
retrosmiths
The former.
2013 Scion FR-S
The Following User Says Thank You to retrosmiths For This Useful Post:
xjohnx (05-28-2013)
Old 05-28-2013, 04:07 PM   #9
euroshowoff
euroshowoff's Avatar
Drives: 2015 Tacoma
had that happen to my gti after fitting it with a front mount, drove me nuts...hope you find a fix.
euroshowoff is offline   Reply With Quote
Old 05-28-2013, 04:17 PM   #10
xjohnx
Grip>Slip
xjohnx's Avatar
FWIW, here is the part number for the plastic brackets that the bumper attaches to (under the headlights). They're about 21 bucks each.
Right side: 57707CA001
Left side: 57707CA010
Note: I don't know if this will help or not, but it's worth a shot.
charged86 (06-19-2013)
Old 05-28-2013, 08:01 PM   #11
xjohnx
Grip>Slip
xjohnx's Avatar
Any chance you have a pic of how you routed your zip tie? I tried a couple angles but nothing really seemed right.
Old 05-28-2013, 10:15 PM   #12
retrosmiths
Pull the fender lining away after removing that outer clip. Route the zip tie from above (or from below). Of course, the inner clip has to be removed first.
2013 Scion FR-S
DelayedBRZ (06-12-2013)
Old 05-29-2013, 05:35 PM   #13
xjohnx
Grip>Slip
xjohnx's Avatar
My problem might actually be an install issue. My suspicion is that when the bumper skin was replaced after hitting a cone on the highway, the body shop used the wrong fasteners that secure the corner of the bumper by the side marker. The fasteners in there now look nothing like the one in this photo from DarrenDriven
I'm waiting on a full resolution shot to confirm, but hopefully that's the cause. I've got the correct part on order from Subaru. If it fixes the issue I'll be sure to update.
Old 05-29-2013, 05:38 PM   #14
SkullWorks
Drives: SSM LT MT BRZ
My car has same issue, both sides, it will "snap" into place there under the light but soon slips back out
The Following User Says Thank You to SkullWorks For This Useful Post:
Sportsguy83 (06-18-2013)
Bumper and fender damage - Hit and Run 01s0uljah Cosmetic Modification (Interior/Exterior/Lighting) 40 12-24-2016 02:44 PM
Worn floor mats - Covered under bumper to bumper warranty? Philly758 Issues | Warranty | Recalls / TSB 45 08-19-2013 02:32 PM
Where to Buy Fender badges and bumper V light?? taimysho0 Scion FR-S / Toyota 86 GT86 General Forum 5 05-17-2013 05:31 AM
WTB: headlamps, fender garnish/cover/vent, and bumper reinforcement mariolefty1 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2013 05:52 PM
Need scratches/scuff marks buffed out of bumper or cheap bumper for sale [Cyanide] NY / NJ / CT / PA 12 12-28-2012 08:34 PM
