#16 |
Crap, I missed it!
- andy |
#17 |
Drives: CBS BRZ Limited
x2
Repost please! :happy0180:
| The Following User Says Thank You to schtebie For This Useful Post: | OjiGeorge (05-29-2013) |
#18 |
Drives: Attitude
#19 | |
Drives: 2013 Scion FR-S AT Asphalt
Scott
#20 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Would like to see the list as well.
OEM Struts plus RCE Yellows = 65% critically damped on a shock dyno... 250lbs/in and 22mm drop front and rear is plenty for me with my DD that sees the track frequently. The complete lack of body roll and oversteery goodness with the RCE sways and some decent negative camber front and rear just finish off the "OEM+" setup I've been tracking with for many months now. Good guy @Moto-P 's words should be etched in stone and carried to the top of Mount Olympus, Quote:
| The Following 3 Users Say Thank You to ATL BRZ For This Useful Post: |
#21 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Did you get an opportunity to test drive anything with the Koni yellow dampers? I have those along with Eibach Pro-Kits waiting to be installed. Wondering if there's a correct damper setting to best match the spring-rates of the Pro-Kits with the Yellows. My goal (not sure if I can achieve it) is to not make things worst than stock, but willing to give up a little comfort to maintain the performance of the stock car.
#22 |
That Guy
Drives: 2013 asphalt FRS MT
How do you calculate the damping as being critically, under, or over damped when the springs compression curve is linear and the damper has a force vs. speed curve, and that curve is different for both compression and rebound? This is an honest question, and something that has been bugging me for a long time.
#23 |
Ontario's FT86
Drives: 2016 Lexus GS-F
Exact reason why I am saving up for Ohlins/KW/JRZ instead of going with HSD/BC/Stance, do it right or don't do it.
| The Following 3 Users Say Thank You to shu5892001 For This Useful Post: |
#24 | ||
I'd like to learn how to do it mathematically as well, but there's so many factors involved... Per wikipedia... (this only applies to idealized spring damping; there's so much more to damping a car going over a road....) Quote:
| The Following User Says Thank You to CSG Mike For This Useful Post: | Calum (05-28-2013) |
#25 | |
Some like a little higher than 65% for low speed piston velocity and then closer to 65% in the higher speed range. Some like 65% for low speed and 50% for high speed piston velocities. I'm all about theory as a starting point but to me it is a starting point. Not a hard and fast rule. Calibrated butt dynos are excellent tools. Feel, driver preference, and driver confidence can be very important too...and sometimes drivers adapt and end up faster. But I do really like having a starting point over a wild-ass guess.Bottom line and this is what I think CSG Mike was getting at: sometimes we see numbers way beyond or way below what they should be and that's a problem. Get near 65% in the low speed range and you're at least close. - Andy Disclaimer: I am not a shock engineer and I defer to others often. I just try really really hard to learn from them. It hurts my brain too sometimes. |
#26 |
Drives: 2015 Tacoma
Whose hosting the next AMA lol....
Sent from my iPhone using Tapatalk 2
"Bah Weep Granah Weep Nini Bong"
Old: 2013 Arengto FR-S Current: 2015 Tacoma/2020 Sequoia Pro Future: 2022 CWP Limited Est Delivery 06/22 |
#27 |
Ontario's FT86
#28 |
| Mike's CS FR-S build | mikef | Member's Car Journals | 6 | 04-25-2013 09:11 AM |
| Some observations | Nardi330 | AUSTRALIA | 20 | 02-07-2013 06:18 AM |
| 90 Day Anniversary ..some Observations | Scooby South | BRZ First-Gen (2012+) — General Topics | 6 | 09-03-2012 11:17 AM |
| Mike's track videos. | CSG Mike | Tracking / Autocross / HPDE / Drifting | 2 | 08-16-2012 04:00 AM |
| First Payment sent, Observations after 6 weeks. | Scooby South | BRZ First-Gen (2012+) — General Topics | 27 | 08-01-2012 02:02 PM |
