Old 05-28-2013, 12:08 PM   #1
CSG Mike
CSG Mike's Avatar
CSG Mike's observations on dampers/coilovers
Over the past 9 months or so, I've had the opportunity to drive on virtually every damper/coilover system on the market. These are my thoughts. A special thank you goes out to the countless members who have offered me the opportunity to drive in their setups so that I can get an impression of how they function, both on track and on the street.
First, there are a LOT of badly damped systems out there. Frequently, the damper is not properly matched up to the spring, and are often underdamped. The end result is a harsher ride that is frequently perceived to be faster/better because it is "stiffer", but the reality is that these cars had less grip than stock.
Second, there's a strong correlation between underdamped systems and price. This isn't to say that an expensive coilover/shock is always good, but the lower priced systems, so far, have universally been underdamped for hard driving. The underdamped characteristic allows for a "more comfortable" ride under street use with higher spring rates, giving a false sense of increased grip.
Third, the stock dampers are VERY well matched to the springs. While the stock suspension is soft, it is critically damped for performance. Most people will perceive the (somewhat excessive) body roll to be hurting cornering grip, but the reality is that it really only hurts transition time between weight transfer. If you drive according to the car, instead of trying to force the car to do what you want it to do, you can put down some REALLY smoking fast times at the track. To top it off, the stock system uses soft spring rates, so street driving is nice and comfy, albeit a bit on the harsh side given the spring rates (due to the "performance" oriented nature of the damping).
I understand that a lot of you don't like the body roll that is the result of the stock spring rates, but trust me, the stock stuff is GOOD.
As always, do as much research as you can before making a decision as to what's right for you. Some systems offer a different range of ride heights, while others do not. Some systems may not be able to offer the ride you're looking for, and there is no "one product fits all" when it comes to suspension.
The Following 60 Users Say Thank You to CSG Mike For This Useful Post:
37 (08-12-2013), 7thgear (05-28-2013), acro (05-28-2013), akuhei (05-28-2013), Anthonytpt (05-28-2013), AreteAuto (08-13-2015), Asphalt~86 (05-28-2013), ATL BRZ (05-28-2013), autobrz (05-28-2013), bedabi (08-18-2013), BigFatFlip (08-08-2013), Creole (07-22-2016), danthedirt (08-13-2013), Dimman (05-28-2013), djdnz (05-28-2013), DylanFRS (08-26-2013), Efferalgan (06-11-2014), enouf (05-28-2013), Enraged21 (05-28-2013), F1point4 (08-14-2013), FRSRAVEN (09-02-2013), ft_sjo (05-28-2013), Gords_zenith (08-08-2013), GTB/ZR-1 (05-28-2013), hmong337 (08-13-2013), I<3Twisties (08-25-2013), Jasper (05-03-2021), JDKane527 (05-28-2013), Kido1986 (05-28-2013), lazyluka (08-14-2013), Luckrider (06-09-2014), Mgivens (05-28-2013), Mikepage (05-01-2014), mmmcambelsoup (01-02-2015), mrk1 (08-09-2013), naikaidriver (05-28-2013), oofie (05-28-2013), Pseud0logik (06-14-2014), qoncept (08-09-2013), RehabJeff86 (05-30-2013), robispec (05-28-2013), RYU (05-28-2013), Shagaliscious (08-26-2013), Shark_Bait88 (10-09-2014), shu5892001 (05-28-2013), sittinSideways (04-29-2014), SkullWorks (05-28-2013), Spartan65 (08-09-2013), Splat (05-29-2013), suaveflooder (04-29-2014), Touge Monster (05-28-2013), troek (06-10-2014), Turdinator (08-09-2013), Wayno (09-10-2014), whataboutbob (08-23-2013), wheelhaus (04-30-2014), WillRacer1jz (05-29-2013), xxBrun0xx (07-28-2015), zdr93523 (05-03-2014), zoomzoomers (05-28-2013)
Old 05-28-2013, 12:21 PM   #2
robispec
Drives: Black frs project
got your flame proof suit on?
robispec is offline   Reply With Quote
The Following 6 Users Say Thank You to robispec For This Useful Post:
Anthonytpt (05-28-2013), Enraged21 (05-28-2013), FRSRAVEN (09-02-2013), SkullWorks (05-28-2013), suaveflooder (04-29-2014), whataboutbob (08-23-2013)
Old 05-28-2013, 12:22 PM   #3
CSG Mike
CSG Mike's Avatar
Yes... fire extinguishers ready too.
I fully expect everyone to defend their suspension choices, but isn't that expected?
Basket Case (06-13-2014), suaveflooder (04-29-2014)
Old 05-28-2013, 12:22 PM   #4
euroshowoff
euroshowoff's Avatar
Drives: 2015 Tacoma
do you have a thread/blog discussing each setup? For someone like me, who is taking his time making a decision, its important to read as many reviews from someone who isn't biased to their setup.
euroshowoff is offline   Reply With Quote
The Following 2 Users Say Thank You to euroshowoff For This Useful Post:
Mgivens (05-28-2013), sittinSideways (04-29-2014)
Old 05-28-2013, 12:28 PM   #5
Mgivens
Drives: Fr-s MT Ultramarine
This! Would love to hear some more opinions on each setup from someone as experienced as you Mike
Mgivens is offline   Reply With Quote
The Following User Says Thank You to Mgivens For This Useful Post:
Old 05-28-2013, 12:30 PM   #6
SkullWorks
Drives: SSM LT MT BRZ
in b4 flame front.
Old 05-28-2013, 12:39 PM   #7
Ben_G
Drives: Blue BRZ
So there are FEW systems that you liked.....care to share?
Ben_G is offline   Reply With Quote
The Following 2 Users Say Thank You to Ben_G For This Useful Post:
djdnz (05-28-2013), sittinSideways (04-29-2014)
Old 05-28-2013, 12:48 PM   #8
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
So what do you thinking about springs that have higher rates? RCE for example matched with stock dampers.
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
Calum (05-28-2013)
Old 05-28-2013, 12:52 PM   #9
djdnz
1337
Drives: 2013 BRZ WRB S/C
X2, would love to know which ones were your personal favourites. Taking cost into consideration of course
Thanks for the post.
djdnz is offline   Reply With Quote
Old 05-28-2013, 02:18 PM   #10
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Aww what happened to that list? I was hoping to see them separated out into what you'd consider "well" or "badly" damped.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
Old 05-28-2013, 02:23 PM   #11
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
no
99% of these assholes didn't udnerstand a single word in your post and never will.
particulary the part about dealing with OEM roll, which is easily delt with if one knows the track well and isn't jerking the wheel like they do in 90's sitcoms.
so fuck them
The Following 20 Users Say Thank You to 7thgear For This Useful Post:
37 (08-12-2013), Anthonytpt (05-28-2013), AreteAuto (08-13-2015), ATL BRZ (05-28-2013), Captain Snooze (05-28-2013), Creole (07-22-2016), Dimman (05-28-2013), diss7 (08-25-2013), FRSRAVEN (09-02-2013), iketeru (08-09-2013), Kido1986 (05-28-2013), naikaidriver (05-28-2013), Pseud0logik (06-14-2014), raul (08-09-2013), Shark_Bait88 (10-09-2014), suaveflooder (04-29-2014), therealstoly (05-03-2021), Wayno (03-11-2015), WillRacer1jz (05-29-2013), zdr93523 (05-03-2014)
Old 05-28-2013, 02:36 PM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by 7thgear View Post
no
so fuck them
on one hand I'm tempted to delete this post for being a bit too harsh, on the other I laughed while reading it. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 25 Users Say Thank You to Dave-ROR For This Useful Post:
350zgoingFRS_lol (06-12-2014), 37 (08-12-2013), Anthony (08-09-2013), Anthonytpt (05-28-2013), ATL BRZ (05-28-2013), Captain Snooze (05-28-2013), cdrazic93 (05-01-2014), CSG Mike (05-28-2013), Enraged21 (05-28-2013), FRSRAVEN (09-02-2013), Guff (05-04-2014), Hyper4mance2k (02-05-2015), ImperiousRex (05-28-2013), JB86'd (06-13-2014), Lee358 (08-09-2013), naikaidriver (05-28-2013), Racecomp Engineering (05-28-2013), raul (08-09-2013), robispec (05-28-2013), Sportsguy83 (06-05-2013), suaveflooder (04-29-2014), Touge Monster (05-28-2013), Wes (08-22-2013), wheelhaus (04-30-2014), zdr93523 (05-03-2014)
Old 05-28-2013, 02:42 PM   #13
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
@Dave-ROR
I vote leave it. It's too funny AND true hahah.
I get a kick out of people thinking these cheapest coilover kits handle so well (especially while bottomed out!). It used to really bother me. Now, I'm getting to the point I just save my breath. Poor, mismatched Taiwaneese dampers plus 10k springs do not a well handling car make.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following 7 Users Say Thank You to Kido1986 For This Useful Post:
37 (08-12-2013), Anthonytpt (05-28-2013), Brzzee (06-13-2014), CSG Mike (05-28-2013), suaveflooder (04-29-2014), WillRacer1jz (10-10-2014), zdr93523 (05-03-2014)
Old 05-28-2013, 02:50 PM   #14
CSG Mike
CSG Mike's Avatar
Originally Posted by Kido1986 View Post
@Dave-ROR
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
Some observations Nardi330 AUSTRALIA 20 02-07-2013 06:18 AM
90 Day Anniversary ..some Observations Scooby South BRZ First-Gen (2012+) — General Topics 6 09-03-2012 11:17 AM
Mike's track videos. CSG Mike Tracking / Autocross / HPDE / Drifting 2 08-16-2012 04:00 AM
First Payment sent, Observations after 6 weeks. Scooby South BRZ First-Gen (2012+) — General Topics 27 08-01-2012 02:02 PM
