Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > ASIA
Old 05-25-2013, 02:34 AM   #911
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Originally Posted by Alabang BRZ View Post
Anyone using this?
I'm using a similar app. I have a GoPoint BT1 and I use DashCommand to monitor temps, timing, AFR, fuel economy etc. Then for the track I have Harry's lap timer app, it gives you a lap timer and the ability to render video overlayed with lap times and OBD data
[ame="http://m.youtube.com/watch?v=ca29x07VHpQ"]DashCommand on a Pioneer AppRadio using GoPoint BT1 - YouTube[/ame]
HRTROB is offline   Reply With Quote
The Following User Says Thank You to HRTROB For This Useful Post:
jdmasfcuk (05-28-2013)
Old 05-25-2013, 02:45 AM   #912
NIKDENG
Drives: RED BRZ
HRTROB,
Have you tuned your car already? Did you reflash the ECU or did you go the piggyback route like the Unichip? Thanks.
NIKDENG is offline   Reply With Quote
Old 05-25-2013, 03:04 AM   #913
Alabang BRZ
Originally Posted by HRTROB View Post
You can use Waze with any head unit that has an Aux input, but you will have to navigate using the phone. With the Pioneer head units, you can use the head unit's touchscreen to navigate. I prefer Waze over any other nav program because it gives you real-time traffic updates and warnings
By they way guys if you're installing an aftermarket head unit, use a Toyota wiring harness adaptor and Lexus antenna adaptor so that everything will be plug and play - no wire splicing whatsoever
Aux input?
Google Maps on my iPhone does not do turn by turn. Just a useless preview.
Apple Maps naman... I dont want to end up "inside" Muntinlupa.
Are you using AppRadio 2? I am looking at AppRadio 3 that was announced this week. I prefer the model without the DVD/CD component.
But the Kenwood that Nik uses is a big sell kaso this video shows the Kenwood you need to control the interface via the iPhone rather than direct to the stereo. My preference sana was to plug the phone and tuck it away and control every function and app through the headunit.
[ame="http://www.youtube.com/watch?v=eKkjRQ6g7pY"]Kenwood DDX630wbt and the Iphone - YouTube[/ame]
I am wondering with the iPad being so thin, light and responsive why cant headunits be as trim as well. I read the Kenwood weighs a good 2.6kg and costs more than an iPad. Not against anyone on ft86club but I just find it really really odd.
Alabang BRZ is offline   Reply With Quote
Old 05-25-2013, 03:30 AM   #914
grannyshifter25
Drives: Subaru BRZ
Originally Posted by NIKDENG View Post
Look for Mike the owner. Ok lang na walk in.
thanks! sabihin ko na lang member ng ft86club.
grannyshifter25 is offline   Reply With Quote
Old 05-25-2013, 05:10 AM   #915
NIKDENG
Drives: RED BRZ
Alabang BRZ;
The reason why car head units are heavy and bulky is because of:
1. The cd/dvd unit component which contains the reader motor, loading/unloading mechanisms, etc.. Although some people no longer use the cd on their units, a lot of people still do as music in CD/DVD format still sounds better than MP3 format because of the differences in compression. Same with video.
2. The built in amplification components which are needed to power a minimum of 4 speakers at a level of at least 5 watts RMS each.
3. Cooling components such as heat sinks and fans which are needed because of the offshoot of the amplification process.
If the Ipad was made to have a CD/DVD reader and power 4 speakers without external amplification, it would weight more and just be as bulky as the common touchscreen car head unit and cost a lot more than what it already is.
If you want to make your tablet as your head unit, a lot of people have already done this. The key is the audio output of the tablet is plugged into an amplifier so that it can power the car speakers.
For reference:
http://www.ft86club.com/forums/showthread.php?t=17990
Hope this helps.
Old 05-25-2013, 06:47 AM   #916
HRTROB
HRTROB's Avatar
Drives: Toyota 86
HRTROB,
I'm running a Unichip plug and play piggyback on mine. So far, so good
Aux input?
My head unit is a Pioneer AVH-X5550BT which has AppRadio 2. Yup you can use Waze with any head unit that has RCA AUX INPUTS. I use it on my other car that way. You will need a composite video out cable for your iOS device. I don't think it will work though if you have an iphone 5.
Try using Waze, it gives real time traffic info like average speeds on a particular stretch of road, accident, hazard and police warnings, and yes it does turn by turn navigation. Not bad for a free app, I prefer it over iGO Primo I have in my other car. It even works outside Metro Manila. I've already used Waze's turn by turn navigation in Bacolod. Works great!
Old 05-25-2013, 07:19 AM   #917
NIKDENG
Drives: RED BRZ
Thanks for the info. How much WHP was gained from the Unichip tuning alone without intake and exhaust modifications?
Old 05-25-2013, 08:51 AM   #918
Jetscape
Jetscape's Avatar
Drives: Toyota GT 86 Red AT
Thanks for the Headset info. Really appreciate it. Android head units not yet for prime time I guess.
Jetscape is offline   Reply With Quote
Old 05-25-2013, 10:11 AM   #919
grannyshifter25
Drives: Subaru BRZ
planning to get the stivo full exhaust and uel headers next week, is it required to have your car tuned with those mods?
Old 05-25-2013, 11:37 AM   #920
LLED
Drives: Toyota 86 GBS
Same question as sir Nikdeng sir HRTROB how much WHP did you gain from the unichip and is it better than a ecutek tune ty
LLED is offline   Reply With Quote
Old 05-25-2013, 12:01 PM   #921
dagame
dagame's Avatar
Drives: Subaru BRZ ZC6 Lightning Red
Originally Posted by pauland View Post
Brothers, para sa mga nagpalit na ng horns, is there a way to install an aftermarket horn without dismantling the front bumper? I was in a shop recently and they told me they can install the horn without pulling out the bumper. I'm a bit apprehensive lang for both methods. Kapag kalas bumper, this should be done by a very reputable shop. If hindi aalisin, it will be harder to properly install the horns. How did you install yours?
i had my horn replaced at autokozmetix, they didn't remove my bumper. it was harder to install w/o removing the bumper, but its possible to do and mas sure for me since hindi gagalawin yung bumper.
dagame is offline   Reply With Quote
The Following User Says Thank You to dagame For This Useful Post:
pauland (05-27-2013)
Old 05-25-2013, 12:18 PM   #922
HRTROB
HRTROB's Avatar
Drives: Toyota 86
[ame="http://m.youtube.com/watch?v=quj8tsnNEwc"]Toyota 86 dyno - Milltek Full System Resonated, Afe Takeda Intake - YouTube[/ame]
Autoplus Dynojet
Ambient temp 36-37C
Humidity 54%
Both runs done on the same day, 30 minutes apart
Baseline: 152whp 127tq (stock ecu, stock intake, Milltek overpipe, front pipe, resonated catback)
With Unichip and Afe Takeda dry intake, Milltek overpipe, front pipe, resonated carback: 162whp 134tq
Gained about 10whp and 7tq. Not bad since the intake is known to produce only 5hp based on numerous dynos posted in this forum. With a little tweaking some power can still be squeezed out, as it was running richer than the stock tune. Will do another dyno run once the headers are installed
Ecutek is great and has obviously more potential, but it costs more and inolves flashing the ecu, something I am not comfortable with, having previously bricked two PC motherboards trying to flash the BIOS. Plus you can resell the unichip and recoup some of your money, something you can't do with ecutek
The Following 5 Users Say Thank You to HRTROB For This Useful Post:
Alabang 86 (05-28-2013), jdmasfcuk (05-25-2013), Jetscape (05-25-2013), NIKDENG (05-25-2013), pauland (05-27-2013)
Old 05-25-2013, 12:50 PM   #923
NIKDENG
Drives: RED BRZ
Autoplus Dynojet
Ambient temp 36-37C
Humidity 54%
HRTROB,
Thanks for sharing your data. The baseline seems a little bit low at 152whp with stock ecu, stock intake, Milltek overpipe, front pipe, resonated catback. I've seen completely stock setups baseline from 168 - 172whp which is more in line with a 15% drive train power loss from the 200hp. Does this mean that the addition of the overpipe, front pipe and resonated catback on a stock ecu actually generated less power than stock setup? Even after installing the Unichip, the 168 whp is just like back to stock which seems to show that the addition of overpipe, frontpipe and different catback didn't add any power. Or can the variance be attributed to the differences in the types of dyno's used and testing conditions? Thanks.
Old 05-25-2013, 01:07 PM   #924
HRTROB
HRTROB's Avatar
Drives: Toyota 86
HRTROB,
I agree, baseline was pretty low. But this is because the runs were done on a dynojet, which reads lower than Speedlab's dynapack. The extremely high ambient temps also played a factor - dyno was back in April, middle of summer. There were three of us who dynoed that same day. 86 all stock except for TRD axleback pulled 152whp, and the other guy pulled 157whp 134tq and his 86 had the same Milltek over pipe, front pipe, resonated catback, but with Injen intake and Ecutek tuning. All of our cars were M/T, running Petron Blaze and the dealer Toyota 5w30 mineral oil.
168whp all stock on a dynojet is wishful thinking here in Metro Manila Patch from Autoplus showed us the baseline of their BRZ, only pulled 159whp
