Old 05-18-2013, 04:02 PM   #155
Eau Rouge
Eau Rouge's Avatar
Drives: 2013 BRZ, Limited, C7P, 6AT
Originally Posted by troek View Post
yeah, ive looked at the simple butterfly valves that just bolt in, and are cable operated. my buddy has one on his r32 and it works pretty good.
I know it's a chunk of cash but the Varex has a remote control and you don't have to worry about a manual valve being fully closed and creating excessive back pressure. Hopefully, your friend has the valve stop set so the valve is only partially closed but it is still restricting gas flow because it has nowhere else to go but through whatever small opening is left.
Eau Rouge is offline   Reply With Quote
Old 05-22-2013, 02:21 AM   #156
Onealpha
Drives: 2013 Subaru BRZ
Recieved my cat back today. Looks real nice in the box after a quick examination. I took a neomydium magnet to a short section and there is zero magnetic attraction to the tubing, but ther is strong attraction to the flanges and the hangers. I will check the rest when installing tomorrow.
Onealpha is offline   Reply With Quote
Old 05-22-2013, 09:05 AM   #157
troek
troek's Avatar
Drives: 2012 Toyota 86
so that means its not stainless steel?
troek is offline   Reply With Quote
Old 05-22-2013, 03:48 PM   #158
Onealpha
I believe that means that the tubing is Stainless, but the flanges and hangers are not. Not surprised though, the flanges and hangers on my stock pipes were already rusting away but the tubing was not.
The Following User Says Thank You to Onealpha For This Useful Post:
troek (05-23-2013)
Old 05-23-2013, 12:22 AM   #159
troek
troek's Avatar
i can live with that! thanks for doing that little test.
Old 05-24-2013, 01:15 PM   #160
Onealpha
J2 Engineering Quad Tip Exhaust Install/Uninstall
So three days ago I recieved the J2 Engineering Quad Tipped Exhaust. Two days ago I installed the exhaust. Today I removed it and put the stock exhaust back on. I will be selling the J2 Quad locally and will put an ad on the classified soon.
So here is the scoop. It is a good exhaust. I looks great and the magnet confirms that the tubing is actually stainless steel, but it is just too damn loud for me. I like a deep exhaust and this is definitely that. It sounds amazing when it starts up and fast idles. The quad tips really break up the sound and give it a nice grumble. It sounds fantastic when you open this thing up. It is actually pretty mellow and shows no droning at 2.8k RPM and above. Below 2.8 it gradually gets deeper with its deepest tone around 1.5k. If I was younger and still single I would probably keep this exhaust. However, I am not, my wife hates it, and for a daily driver it is just too much for me. I do recommend using some Dynamat Extreme or something like it behind the heat sheild facing the car body as the exhaust presses against it and causes a rattle without it.
I snapped off a few photo's of the exhaust while it was still on the car up on the lift and will attach them here. If anyone is looking for a great deal send me a PM or watch the Members classifieds. FYI, I will be including all the original gaskets and hardware along with 3 square feet of Dynamat Extreme that you will need for the heat sheild as this exhaust does press against the heat sheild. That and the loud sound was the only criticism I could find.
The Following 4 Users Say Thank You to Onealpha For This Useful Post:
8R6 (04-13-2014), DrSleepy (05-24-2013), hobojoker (05-24-2013), jamesm (05-24-2013)
Old 05-24-2013, 04:28 PM   #161
DrSleepy
DrSleepy's Avatar
Drives: 2013 MT FRS, 2002 MR2
I'm waiting for a few extra dollars saved up to try out J2 Dual Tip but I don't want to grab the exhaust if its too loud. Funny how when I first saw this I was all aboard and now that I have a girlfriend again I'm all about practicality. I done goofed guys.
DrSleepy is offline   Reply With Quote
Old 05-24-2013, 05:25 PM   #162
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
Noob question here:
Is this catted or catless?
[ame="http://www.amazon.com/DNA-J2-CBE-003-J2-DP-001-ENGINEERING-DOWNPIPE/dp/B00CO79VZW/ref=sr_1_2?ie=UTF8&qid=1369429887&sr=8-2&keywords=j2+exhaust+quad+tip"]DNA, J2-CBE-003+J2-DP-001, J2 ENGINEERING SCION FRS GT86/SUBARU BRZ QUAD 2.75 INCH TIP CATBACK+DOWNPIPE EXHAUST : Amazon.com : Automotive[/ame]
CodyFRS is offline   Reply With Quote
Old 05-24-2013, 05:37 PM   #163
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
smh... You're doing it wrong bro.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 05-24-2013, 07:59 PM   #164
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Catless.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 05-24-2013, 08:42 PM   #165
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
Originally Posted by 6-Shift View Post
Catless.
It just connects into the stock catalytic converter then?
Old 05-24-2013, 11:34 PM   #166
6-Shift
Señor Member
6-Shift's Avatar
It replaces the second cat with a straight pipe. First one is in the stock header.
Old 05-25-2013, 08:25 AM   #167
troek
troek's Avatar
2 kits available. one deletes the 2nd cat, one doesn't.
thanks, ive been wondering what that noise is. so you just put it between the heat shield and the underside of the trunk?
The Following User Says Thank You to troek For This Useful Post:
BLACK->BULLET (06-01-2015)
Old 05-25-2013, 08:39 AM   #168
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
Where is the kit that doesn't? I can only find the one I had provided with a link.
Quad exhaust tips? migle Engine, Exhaust, Transmission 86 09-23-2020 11:45 PM
J2 Quad catback exhaust? bcmakesiteasy Engine, Exhaust, Transmission 22 06-01-2015 03:43 AM
TRD Style Quad exhaust Nafe AUSTRALIA 17 05-11-2013 02:13 AM
Quad Exhaust Lip? Neekowahhhh Scion FR-S / Toyota 86 GT86 General Forum 4 12-17-2012 08:49 PM
Stacked Quad Exhaust quik1987 Engine, Exhaust, Transmission 43 08-16-2012 03:34 PM
