Old 12-09-2011, 12:50 PM   #85
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Originally Posted by ahausheer View Post
When numbers are publishes I will refer to Consumer Reports. My reason for this is their 0-60 times are from idle, no shenanigans. I like this because I too will not be using shenanigans when I drive it hard.
Several car magazines publish times for 5-60 mph, which is more or less rolling on the throttle from a stop sign. This is probably the sort of measurement you're looking for. It is a good indicator of how fast a car is without any drivetrain abuse (clutch drop/slippage).
Going by that sort of testing regime this car won't break the 7s.
Old 12-09-2011, 10:32 PM   #86
Eldorian
Drives: 04 RX8
Originally Posted by serialk11r View Post
Uh not exactly, the Renesis pumps more air than a 2.0L engine per crankshaft revolution. More precisely, 2 crankshaft revolutions will pump the full displacement of the motor into the intake and out the exhaust, while a rotary pumps its full displacement out in 1 crankshaft revolution because it pumps 1.3L worth of air in and then 1.3L of exhaust out together.
I never claimed the Renesis was a 2.0. It's a 2.6. It's still a small, high strung, naturally aspirated engine, though.
Eldorian is offline   Reply With Quote
Old 12-10-2011, 06:58 AM   #87
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Maybe they call it sporty, perhaps you feel like it's sporty, but the ratios are quite a bit lower and far apart http://www.new-cars.com/2004/acura/acura-rsx-specs.html
Auto definitely shifts faster, they're usually plagued by crap ratios.
Actually looking at that chart I totally understand why you complain about your car now, the manual transmission has 17% higher gearing in 1st, combined with torque converter slippage, ouch.
Yeah the automatic kinda sucks ass in my car. So do you think the FRS auto might have higher gearing this time comparable or better than the MT?
SUB-FT86 is offline   Reply With Quote
Old 12-10-2011, 07:27 AM   #88
serialk11r
Drives: '06 AM V8V Coupe
Hard to say, but it looks like they paid slightly more attention to the A/T than usual so it might turn out with close ratios. I think the reason A/T usually has widely spaced ratios is because they assume if you buy an A/T that sort of thing doesn't bother you, but in this car the philosophy looks slightly different. imo it would be sorta stupid to give the auto aggressive feeling shifts and sporty features, and then drop the typical crappy gear ratios in.
Old 12-11-2011, 02:40 AM   #89
Hachi
Drives: Mr2
Launch from 4k rpm, standing start @ 3.12 mins
I'm pretty sure 2nd gear will hit 100-110kph
My estimate for the low spec model? Between 6.2-6.4 sec .. not bad imo
Hachi is offline   Reply With Quote
Old 12-11-2011, 03:22 AM   #90
ryude
Drives: Volkswagen GTI
Why does it sound like he's grinding gears every damn time he shifts?
ryude is offline   Reply With Quote
Old 12-11-2011, 01:36 PM   #91
acheddadi
acheddadi's Avatar
Drives: Honda S2000 AP2, VW Golf GTI MkV
I really doubt this car will do it in less than six. Get mentally prepared to be eaten off the line by pretty much any flagship sports car available right now as they pretty much all have more horsepower and better rubber. This car is for keen drivers who enjoy spirited driving, not smoking people between red lights.
acheddadi is offline   Reply With Quote
Old 12-11-2011, 04:44 PM   #92
SUB-FT86
86 Member
Why does everybody on this site associate high hp/tq cars with traffic light races? I have seen honda civics thinking they are hot shit at stoplights too.
Old 12-11-2011, 11:49 PM   #93
Palmy
Palmy's Avatar
Drives: '12 86 GTS (AUDM)
Because thats all hp is to most people.
Palmy is offline   Reply With Quote
Old 12-13-2011, 07:22 AM   #94
fistpoint
Drives: Supercharged Golf Cart
Originally Posted by Rampage View Post
I am going to guess mid to high 6s. Toyota and Subaru are stating around 6 second 0-60 but in car marketing jargon (and drag racing) that could mean 6.99 sec. ie. "I ran in the sixes!"
The 2012 Honda Civic Si has comparble weight, hp and a little more torque. It runs 0-60 in 6.9 seconds. I would be shocked if a stock FRS/BRZ could best it by a full second to 60mph.
Edit: I better lock down a specific time because everyone else is. I will say MT = 6.5 AT = 6.7 (hey they said it was good!)
The Civic is almost 200lbs more than this car...
fistpoint is offline   Reply With Quote
Old 12-13-2011, 11:50 AM   #95
WolfpackS2k
Originally Posted by acheddadi View Post
I really doubt this car will do it in less than six. Get mentally prepared to be eaten off the line by pretty much any [s]flagship sports car[/s] Camry or Accord V6 available right now
Fixed it
Old 12-13-2011, 03:48 PM   #96
rayman0690
rayman0690's Avatar
Drives: Car
A stock EVO CT9A (VIII and IX) can technically do 0-60 in 5 seconds...but ask any AWD owner (especially one with a toothpick and teflon tape constructed transfer case) when the last time they actually did that was...
Around 6 seconds is plenty fast for the average guy and for timed events like auto-x as well.
-Ray
rayman0690 is offline   Reply With Quote
Old 12-13-2011, 06:01 PM   #97
iff2mastamatt
Feeling Iffy?
iff2mastamatt's Avatar
Drives: it like I stole it
6.8 seems fine to me with Prius tires.
iff2mastamatt is offline   Reply With Quote
Old 12-13-2011, 06:30 PM   #98
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
I say a bit under 6 for a good launch, mid 6s for OK launches. Sticky tires and bolt-ons: mid 5's. Plenty fast.
a 328i does 0-60 in the low 6s its 3340lbs/230hp = 14.5lbs/hp
an FR-S is about 2700lbs/200hp= 13.75lbs/hp
for more comparison
an S2000 is = 11.90lbs/hp = 0-60 is highly dependent on the driver but can get mid 5's
a Mini Cooper S is = 15.88lbs/hp = upper 6's
a Honda Civic Si is = 14.43lbs/hp = Mid/upper 6's
The FR-S has a bit more torque than a Civic and from what I've heard more usable torque down low, plus the FR-S is a bit lighter as well.
86'd is offline   Reply With Quote
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 02:02 PM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-09-2011 05:07 PM
Forget the NA vs Turbo debate!!!! Midship Runabout Engine, Exhaust, Transmission 69 04-05-2011 06:24 PM
AE86 handling video... Blokatos FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 02-07-2010 05:20 AM
