Old 05-18-2013, 10:12 PM   #1
deange
Drives: Black 2013 BRZ Limited Automatic
Torque on a Stock BRZ Head Unit
I am just looking around, and have been reading some of the threads on adding a backup camera. Would it be possible to add mirroring of an a phone and thus the Torque app in the same way?
Basically the cameras that are used have an RCA plug that leads into the head unit. Couldn't a splitter like this:
[ame="http://www.amazon.com/Monoprice-Gold-Plated-Splitter-Adaptor/dp/B004C8I88W/ref=pd_bxgy_e_text_y"]Amazon.com: Monoprice Gold Plated RCA Plug to 2 RCA Jack Splitter Adaptor: Electronics[/ame]
be used along with this usb powered HDMI converter:
[ame="http://www.amazon.com/ViewHD-Universal-Composite-Converter-Standard/dp/B0080KN18K/ref=sr_1_3?ie=UTF8&qid=1368928605&sr=8-3&keywords=hdmi+to+component"]Amazon.com: ViewHD Universal HDMI to Composite / AV Video Converter, Support PAL / NTSC Standard TVs: Electronics[/ame]
to allow phones / devices with an HDMI out to display on the stock head unit and still have a backup camera?
I know it isn't as smooth or sleek as a brand new full android head unit, but I'm not after a better radio. I just want to be able to put all the gauges that Torque has on the screen where I can glance at them?
Any thoughts?
deange is offline   Reply With Quote
Old 05-22-2013, 02:33 PM   #2
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Not sure where you'd put that splitter. BRZ headunit doesn't have RCAs.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-22-2013, 10:19 PM   #3
xwd
It does via the backup camera input, just need the harness from svxdc or make your own. You would have to install a switch to fool the car into thinking you are in reverse so the screen comes on.
The resolution is fairly low though I don't know how good it would look. Also probably won't look too good with the parking lines.
Might be better to just get a used Android phone to run it on.
Old 05-25-2013, 01:20 PM   #4
deange
I was referring to the adapter plug you get from svxdc or beatsonic. I completely forgot about the parking lines. I figured you'd have a switch to have the input be seen by the head unit though.
Old 05-25-2013, 02:23 PM   #5
2forme
I would just replace the HU with one that can run Torque natively. Even if you get the video feed into the stock unit, composite is a very crappy signal. It would look fuzzy.
Old 05-25-2013, 05:52 PM   #6
deange
Yeah, it may not be a very good idea. Was just playing around with the thought. I don't even really listen to music much... I'm more of a talk radio guy.
I do like the torque app though, and I don't want to pay a few hundred bucks for it if I might be able to make it work on the stock head unit. I figure for 30 bucks it might be worth a shot.
If anyone has any ideas or other suggestions I'm open to them. I'm going to put in the backup camera and I'll try it while I have the head unit out anyhow.
LNIB Stock FR-S Head Unit. Chillyairplane Audio/Visual, Electronics, Infotainment, NAV 11 04-03-2013 08:18 PM
Stock head unit. Flawless22 Audio/Visual, Electronics, Infotainment, NAV 1 03-27-2013 02:39 AM
Stock head unit fitcious Electronics | Audio | NAV | Infotainment 1 01-16-2013 05:57 PM
[WA]: FS GTS Stock Head Unit stevo_12v Australia Classifieds 6 01-15-2013 02:30 PM
question about stock F-RS head unit mezdup Electronics | Audio | NAV | Infotainment 3 10-02-2012 12:15 PM
