Drives: '23 CWP BRZ
LSD?
Our cars come with a Torsen LSD, right? So technically, shouldn't my car not be doing this?
[ame="http://www.youtube.com/watch?v=GdBhsFTbrss"]FRS 3 Wheeling - YouTube[/ame] Is this because I turned off traction control? |
#2 |
Drives: Scion FR-S
I believed the way the torsen works if one tire completely loses traction like that it acts as a open diff.
Sent from my SCH-I535 using Tapatalk 2 |
| The Following User Says Thank You to vtmike For This Useful Post: | 636 (05-22-2013) |
#3 |
Drives: 2013 Subaru BRZ
"If one wheel were raised in the air, the regular Torsen units would act like an open differential, and no torque would be transferred to the other wheel. "
- wiki |
| The Following 4 Users Say Thank You to microbionic For This Useful Post: |
#4 |
Drives: 450 awhp twin turbo vr4
#5 |
The Answer
Drives: Mazda 2
Pull your e-brake, you'll gain traction.
| The Following 3 Users Say Thank You to Rayme For This Useful Post: |
#7 |
Drives: 2013 BRZ GBS
The thread name mislead me .......
| The Following 10 Users Say Thank You to Kwisak For This Useful Post: | Anthonytpt (05-22-2013), Fish Eagle (05-22-2013), jlu (05-22-2013), jstans84 (05-22-2013), microbionic (05-22-2013), Panda Grahams (05-22-2013), pcporo (05-22-2013), tbwoodlee (05-22-2013), tomato88 (05-22-2013), Zgrinch (05-22-2013) |
#8 | |
The Answer
Drives: Mazda 2
The brake trick is something I read on 4x4 forums - they are usually the ones stuck with a wheel in the air.
#9 |
Drives: 2014 Subaru BRZ
Yep, that's going to be normal, even clutch types will do this somewhat, depending on how strong they are. If you get an aftermarket clutch type, it can pretty much have no traction on one tire, and power the other. But that doesn't make it any better in the snow.
#10 |
Drives: '23 CWP BRZ
#11 |
Drives: Raven FR-S
My KAAZ when I broke driveshafts would also free spool. Even clutch type needs some resistance for wedges to work. Our torsens are torque multiplying, 4 times I think? Four times 0 is still 0.
| The Following User Says Thank You to root For This Useful Post: | FRiSson (05-22-2013) |
#13 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
For a RWD car, this is pretty good in the snow. Just get a good set of winter tires, not all-seasons.
#14 |
Member of the year - 2016
Drives: Scion FRS
Nah, its about average. What makes it "good" IMO for snow is the weight distribution, and the fact it has no power so the accidental slippage of throttle won't do much.
