Old 05-21-2013, 10:43 AM   #309
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by Foobar View Post
Yeah, that dyno is definitely reading low. Not a bad plot though. Would expect another 100HP easy with E85. @robispec - does that sound about right?
probably not that much but still looks great, the torque curve is really nice on that plot. Add a header and should be good to go.
Old 05-21-2013, 10:54 AM   #310
Drftfan
Drives: Argento FR-S
Maybe it is just me but I can be patient for this to come out. My first real tuner car was a 95 240sx that we had bought brand new. It took around 4 years before any sort of quality upgrades became available. And even then we just ended up swapping the engine to the sr. Which only made 205 hp. So as it stands we aren't too bad right now.
Drftfan is offline   Reply With Quote
Old 05-21-2013, 10:55 AM   #311
s2d4
s2d4's Avatar
I'll have what you are having.
Old 05-21-2013, 11:13 AM   #312
Foobar
SLO NO MO
Foobar's Avatar
Just basing it on the E85 gains on top of the Vortech, which has similar power to the Sprintex.
http://www.ft86club.com/forums/showp...76&postcount=1
Went from ~253 to ~365.
Old 05-21-2013, 11:54 AM   #313
Cheddar
Saving them pennies...
Its the old innovate thread once again!
:ib42014ishereandnosuperchargeryetagain!:
Cheddar is offline   Reply With Quote
Old 05-21-2013, 01:19 PM   #314
robispec
Drives: Black frs project
No it's not I have a PRODUCTION kit (or Unicorn if you prefer).
Two other INDUSTRY members have their PRODUCTION "test" kits too.
Carb aproval is waiting for some burocrat to wave their magic wand
The latest down under dyno chart is spot on.
E85 = chemical intercooling so we are "very close" to the above intercooled chart.
he is running the 75mm pulley (= 7 lbs of boost)
robispec is offline   Reply With Quote
The Following User Says Thank You to robispec For This Useful Post:
akuhei (05-21-2013)
Old 05-21-2013, 01:40 PM   #315
xxscaxx
Drives: 2013 SWP BRZ
Are you allowed to share what pulley comes with the kit out of the box?
xxscaxx is offline   Reply With Quote
Old 05-21-2013, 01:43 PM   #316
2forme
He also changed pulleys, too. 253 was @ 10psi, 365 was @ 12.5psi
The Following User Says Thank You to 2forme For This Useful Post:
JoeBoxer (05-21-2013)
Old 05-21-2013, 01:46 PM   #317
robispec
Mine had both 75 and 80 mm CARB 91 kit I don't know prob 80 mm.
the 75 mm pulley might be part of a e85 only non-intercooled kit...
xxscaxx (05-21-2013)
Old 05-21-2013, 02:10 PM   #318
sw20kosh
Drives: 2013 Black FR-S
I seem to remember your E85 version actually has a bit more low end than this down under graph. I think the E85 is allowing more timing in the low end.
Old 05-21-2013, 02:11 PM   #319
Foobar
SLO NO MO
Foobar's Avatar
Wouldn't you also use more boost with the Sprintex on e85?
Sent from my Nexus 7 using Tapatalk 2
Old 05-21-2013, 02:53 PM   #320
2forme
I would definitely, but I'm saying that you can't accurately gauge the benefit of E85 when you also change the boost level LOL. That's all
Old 05-21-2013, 03:04 PM   #321
Foobar
SLO NO MO
Foobar's Avatar
Ah point taken. But to be fair, apparently the Vortech isn't seeing much of a gain even with the higher boost/smaller pulley at pumpgas. You only benefit if you change to ethanol. So there's a case where all else being equal (assuming smaller pulley, injectors, and pump), simply switching from pumpgas to ethanol, and the tune to handle it of course, netted a substantial gain.
Old 05-21-2013, 03:15 PM   #322
robispec
We are testing the reliability and efficiency of E 85 with the standard kit and a 75 mm pulley. NONintercooled... Only other upgrade associated with this kit is the teach works 65 pump. And for those people are concerned about their oil temps and water temps the robispec huge radiator with the oil heat exchanger inside...
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 11:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 11:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 02:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 05:40 PM
