#225 |
I Love custom Turbo kits
Drives: Limited BRZ
It DOESNT HAVE to be taken apart. I did it without opening it.
#226 |
Drives: 2023 WRB BRZ (MT)
#227 |
Drives: Limited BRZ
I pushed it out and used a screwdriver. Maybe I installed it in a way where there's more space between the lid and the passenger seat so I can push it further out than normal.
#228 |
Drives: Ultramarine FR-S 6MT
Mine installed fine without needing to take it apart too.
#229 |
Drives: 2012 toyota 86 gts
the caps on the backing of the padding come out, leaving some bolts which can easily be taken out with an allen key. once apart, its super easy to get to those holes
#230 |
Drives: 03' NSX & 13' BRZ 6spd Ltd white
As another member somewhat stated earlier in this thread... No need to remove the cushion.
Before you lay the armrest onto the center console, put those two screws into their respective holes within the armrest frame 1st. They will not drop into the frame holes due to the angle of entry. They will be stuck at an angle. While holding the entire frame in your hand, all you have to do is screw them a few times with your torx screwdriver and they will fall into the frame holes nicely. Now the 2 screws will already be in the frame holes ready to screw into place for mounting. Easy... no need to remove the cushion. I just installed mine last night and it looks fantastic! Thank you JPIT! My interior now feels complete. FYI - My armrest did seem to have a bit of a cosmetic blemish on the center plastic hinge area. The plastic was a sort of rough and a bit more white than black in color at each end of the plastic mould. Since it was just cosmetic and only visible on the passenger side, I didn't really care. Last edited by 996garage; 05-09-2013 at 07:00 PM. |
#231 |
Drives: 2013 H8R FRS, 03 Miata (Sold)
Finally had time to install mine today! Received it about 2 weeks ago from Nigel.
The install was pretty straightforward and easy but I must say that I had some difficulty with the template. Why the 2 pages don't come out of the printer already aligned is strange. I'd suggest to others to just get the initial holes for the studs in the armrest marked out with the template and then using the existing holes in the armrest itself as a guide after getting it lined up. Other than that I couldn't be happier with it! Thanks again Nigel! |
| The Following User Says Thank You to KlafKoon For This Useful Post: | nigel-jdmparts (05-23-2013) |
#232 |
Anyone know where we can buy this?
| The Following User Says Thank You to DIM For This Useful Post: | ravenblackfrs (09-13-2013) |
#233 |
Nigel has it on his website. http://nigel-jdmparts.com/toyota-86-front-arm-rest
#234 | |
#235 |
Ya, I unchecked the "fit to page." The lines on the PDF don't even line up perfectly, you have to shift the 2nd page over a little to line up correctly which was strange to me that it doesn't just line the 2 pages up when printing it out. All in all everything worked out fine though so no real complaints
#236 | |
Drives: BMW E84
#237 |
Drives: WRB BRZ
just ordered! from Chris @ CTP.
Now let the wait begin! |
#238 | |
Drives: 86
P.S. Still have some IN STOCK and READY TO SHIP. |
| Tags |
| armrest, jpit |
| Carsmo Armrest - Short review and quick pics | Bleevin | CANADA | 3 | 09-27-2014 12:21 PM |
| new armrest | Derrick | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 01-24-2014 10:48 PM |
| 86 Armrest | CzechZA | AFRICA | 30 | 02-05-2013 06:44 AM |
| armrest!!! | whitefrs | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-07-2012 03:16 PM |
