Old 05-19-2013, 07:03 AM   #379
Calum
That Guy
Drives: 2013 asphalt FRS MT
NICE! Was that with a WMI kit?
Old 05-19-2013, 07:51 AM   #380
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
Whats that fluid i see next to the car battery?
mnsayer is offline   Reply With Quote
Old 05-19-2013, 08:24 AM   #381
UncleFester
That is the water/meth container.
UncleFester is offline   Reply With Quote
Old 05-19-2013, 12:38 PM   #382
kanundrum
Drives: 2013 Whiteout FR-S
That is correct
The Following User Says Thank You to kanundrum For This Useful Post:
Calum (05-19-2013)
Old 05-19-2013, 03:15 PM   #383
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Hard to tell from the pics, but that piping that goes over the top looks like it's about the same height as the AC lines. Can you confirm? If it's lower, then there's a good chance that the GrimmSpeed strut bar will clear.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-19-2013, 08:01 PM   #384
ptuning
ptuning's Avatar
Drives: White FR-S
Thanks again Sapan for the awesome pics.
It wasn't our intention to dyno tune our FR-S in front of a big crowd before starting our dyno day meet lol, but we were trying to get the car ready for a few ride alongs. Of course mother nature had other plans. Anyhow, it was nice to be able to show the local community that our cars put out the numbers that we say they put out.
If it weren't for the fact that we were a bit late to start the dyno day, we definitely would have cracked the 400whp barrier on pump gas and WMI on Saturday. The new WG springs were in place to make it happen. No worries though, we'll finish up the tune tomorrow and post up the final dyno charts.
ptuning is offline   Reply With Quote
The Following 3 Users Say Thank You to ptuning For This Useful Post:
Calum (05-19-2013), cmss2000 (05-20-2013), kanundrum (05-19-2013)
Old 05-19-2013, 08:03 PM   #385
ptuning
ptuning's Avatar
Drives: White FR-S
We'll see if we can put a bar across the struts towers tomorrow and take a pic of the clearance with the intercooler pipe.
Old 05-19-2013, 08:22 PM   #386
ptuning
ptuning's Avatar
Drives: White FR-S
To answer the questions about dynoing procedures, we do our pulls from 2K rpms. The reason for this is that you cannot tune what you don't sample. It would be difficult to get the AFRs, mbt ignition timing, cam timing, MAF/MAP (speed density) transition, etc right if we started our pulls from 4 or 5K rpms.
Also, the engine is being heat soaked during the entire dyno pull. Shortening the dyno pull by starting at 4.5K rpms shortens the time the engine has to work and will likely inflate the peak whp numbers in the process. The only time we'll start our dyno pulls at 3K+ rpms is when we dyno tune slushbox automatics. Those cars will downshift the moment you apply load, if you start the pull at 2K rpms.
Also, our pulls are done in 5th gear, which is 1:1. In addition, we do not baseline a stock car in 3rd gear and a boosted car in 5th gear. Both stock and boosted numbers are dynoed in 5th gear to give us a proper delta when comparing boosted hp numbers to stock.
The Following 8 Users Say Thank You to ptuning For This Useful Post:
Chewie4299 (05-20-2013), cmss2000 (05-20-2013), Deadpool_25 (05-07-2015), ft_sjo (05-20-2013), kanundrum (05-19-2013), No Brakes (05-19-2013), SnapOv3st3r (05-20-2013), WRXGuy1 (05-20-2013)
Old 05-20-2013, 10:11 AM   #387
SnapOv3st3r
Drives: 400whp Scion tC
The new pipe update is looking beautiful guys. The heat deflectors/shields...will those be apart of the included components for the system or additional add-on upgrades for a small fee?
SnapOv3st3r is offline   Reply With Quote
The Following User Says Thank You to SnapOv3st3r For This Useful Post:
ptuning (05-20-2013)
Old 05-20-2013, 10:58 AM   #388
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
The intake shroud for the air filter will be included as part of the kit.
On a side now, as it stands right now with 393whp DD and weighing in @ ~2800 we have a power-to-weight ratio of 7lbs/whp. That better power-to-weight ratio than an LFA which makes 451whp DD and weights 3552, 7.86lbs/whp. The only questions now is can you shift anywhere near the speed of an LFA gearbox and do you have enough rubber to get that power to the ground
Mrc@ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Mrc@ptuning For This Useful Post:
ScottDRFT (05-20-2013), SnapOv3st3r (05-20-2013)
Old 05-20-2013, 11:11 AM   #389
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Another question is how much is it going to cost us MrC...
Can't wait for Toan to post the final dyno chart.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following 2 Users Say Thank You to ecko04 For This Useful Post:
ptuning (05-20-2013), SnapOv3st3r (05-20-2013)
Old 05-20-2013, 11:23 AM   #390
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Drives: '13 BRZ SWP Ltd --> '24 Trueno Ed
Is that an in-house header that you guys fabricated?
ScottDRFT is offline   Reply With Quote
Old 05-20-2013, 11:57 AM   #391
ptuning
ptuning's Avatar
Drives: White FR-S
Yes, the header is a prototype 4 into 1 unit that we built in-house for testing. The header allows us to make usable (not peak power, but very close) power up to 8K rpms, even on a stock motor without cams or headwork.
The Following 2 Users Say Thank You to ptuning For This Useful Post:
Old 05-20-2013, 01:17 PM   #392
cmss2000
Drives: 2013 BRZ Premium 2012 Acura TSX
Is the overpipe a full 3 inches?
cmss2000 is offline   Reply With Quote
over 9000, ptuning, turbo kit
FA20CLUB.com Turbo Kit Sneak Peek.... FA20Club.com Forced Induction 98 12-14-2013 01:34 PM
Sneak peek at new 57Xtreme? vividracing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-07-2013 02:24 PM
Sneak Peek! P&L Motorsports Stg.1 BRZ/FRS Turbo Kit. P&L Motorsports Forced Induction 179 01-31-2013 07:32 PM
AFE PROTOTYPE EXHAUST: SNEAK PEEK! autofashionfred Engine, Exhaust, Transmission 20 08-13-2012 01:22 PM
Tsukuba Circuit BRZ/FRS showdown Sneak Peek AVOturboworld BRZ First-Gen (2012+) — General Topics 19 06-23-2012 11:13 AM
