Old 05-18-2013, 06:04 AM   #1
slowmo
slowmo's Avatar
Drives: '13 BRZ
Issues with my ecu when tuned
I would like to share my bizarre experience witg you guys. I took my car to get it tuned by an ecutek dealer first of alk the car ran a base dyno map with an astonishing 169 whp max power with a 3 inch full exhaust. I was so happy that with the ecutek tune I would be in 183whp+ (an assumption).
When the base map got tuned the car did the 1st tune run and I was shocked car dropped 13whp. 2nd run dropped 19whp and it kept going on until the dyno kept reading 145WHP!!!
We have checked everything and I am sure that its a genuine ecu problem of limiting the power or something like that.
Any members or tuners faced this issue my car is a 2013 march batch Brz.
400+whp
slowmo is offline   Reply With Quote
Old 05-18-2013, 06:38 AM   #2
ft_sjo
Drives: GT86
Same dyno, same day? Find a better tuner!
Old 05-18-2013, 07:48 AM   #3
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by ft_sjo View Post
... Find a better tuner!
^ this
just because they have money to pay EcuTek does not mean they are a competent tuner. I hope you went back to the stock map and got a refund, or at least whatever map gave you 169whp.
The Following User Says Thank You to mad_sb For This Useful Post:
Ingen (05-18-2013)
Old 05-18-2013, 09:34 AM   #4
wparsons
wparsons's Avatar
It's most definitely not the ECU fighting you, it's the tuner not able to do what they're claiming they can do.
Get it flashed back to stock and get your money back.
flickr
Old 05-18-2013, 09:49 AM   #5
FeaR-S
Drives: Great White
3" on a NA is the worse thing car lost 15 hp and had to fight to get back to base line. Just saying you may be better of with a 2.5" or stock
FeaR-S is offline   Reply With Quote
Old 05-18-2013, 09:51 AM   #6
FeaR-S
Drives: Great White
@slowmo just saw in your sig. you have a turbo kit on the way that will make up but don't expect much with the NA and 3"
Old 05-18-2013, 10:53 AM   #7
slowmo
slowmo's Avatar
Drives: '13 BRZ
Same day same dyno. Im sure its not the tuner because a guy had some dyno pulls before me and made in the 180'swhp
400+whp
Old 05-18-2013, 10:55 AM   #8
slowmo
slowmo's Avatar
Drives: '13 BRZ
He didnt charge a dime. The problem is even when I switched back to the stock map the car made low powee and was acting lazy.
Originally Posted by mad_sb View Post
^ this
400+whp
Old 05-18-2013, 10:57 AM   #9
slowmo
slowmo's Avatar
Drives: '13 BRZ
I doubt that because the base run was with a 3 " exhaust and had an output of 169whp
400+whp
Old 05-18-2013, 10:57 AM   #10
slowmo
slowmo's Avatar
Drives: '13 BRZ
http://www.motoiq.com/magazine_artic...strations.aspx
This is what im facing although im runing 98ron fuel
400+whp
Old 05-18-2013, 03:20 PM   #11
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Try changing to a different type of fuel/gas station then go back to the dyno to see if the problem still exist if the type of fuel/fuel content is the issue.
Bach415 is offline   Reply With Quote
Old 05-18-2013, 03:53 PM   #12
Foobar
SLO NO MO
Foobar's Avatar
Did you reset your ECU before you got your baseline dyno? If not, you may have to wait a while for the ECU to get used to the new tune. I think it's best to reset the ECU before each run if you're trying to do comparisons, no?
Old 05-18-2013, 04:07 PM   #13
Opposed
I did 168whp bone stock, so its hard to say. Different dynos, different days, yada, yada. Don't listen to the 3" is bad for an N/A 4cyl people. There is still a terrible amount of missinformation on the internent about backpressure myths. I doubt the bad numbers have anythign to do with your exhaust. With my S2k, I made more power and TORQUE everywhere with the 3" over the 2.5".
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 05-18-2013, 05:33 PM   #14
FeaR-S
Drives: Great White
with the 07 civic si made more power with 3" while the FR-S lost power. no tune just base before the 3" and returned a few days later and 3" lost had to be tuned to get back +1 lol on E slightly different story.
AEM tuned Intake wbsrazzle Engine, Exhaust, Bolt-Ons 5 05-17-2013 02:25 PM
FR-S E85 Tuned! Kochinopride Engine, Exhaust, Transmission 9 11-07-2012 02:29 AM
Visconti Tuned 0-60 brichard0625 Engine, Exhaust, Transmission 96 09-16-2012 09:56 PM
FR-S vs. Tuned WRX and Tuned B8 S4 Snozzberries FR-S / BRZ vs.... 2 07-29-2012 09:35 PM
Used tuned 86! STJ Scion FR-S / Toyota 86 GT86 General Forum 21 05-02-2012 10:42 PM
