Old 05-16-2013, 01:40 AM   #15
Kayzer Soze
Drives: 2013 BRZ 6MT Satin White Pearl
ok, so i think im gonna go with the pdx v9 (seems like an amp i can use with most potential future setups), and i like that its compact....
morel components
2 8" alpine type R 4ohm subs
im going to get a single box for now, but will eventually get custom boxes to put one in each corner of the trunk. anything else i should know or get ?
Kayzer Soze is offline   Reply With Quote
Old 05-16-2013, 02:06 AM   #16
BlueSTaR
BlueSTaR's Avatar
Drives: 13 BRZ Limited & 16 Hyperblue
Crutchfield.com... Just go there.
Also, I prefer to just run 1 Mono and 1 4channel. In the BRZ I would just go high end speakers, bridge the 4 channel and forget the back (not like you need it).
BlueSTaR is offline   Reply With Quote
Old 05-16-2013, 02:16 AM   #17
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
morel components
I think you may have it. Where are you getting your wire from?
Sent from my SPH-L710 using Tapatalk 2
Sbeezy is offline   Reply With Quote
Old 05-16-2013, 02:18 AM   #18
Sbeezy
What's the point of two amps when the v9 is basically two amps in one chassis?
Old 05-16-2013, 02:51 AM   #19
BlueSTaR
BlueSTaR's Avatar
Main reason? Wiring.
Old 05-16-2013, 03:01 AM   #20
cruzinbill
Drives: Argento 6spd FR-S
morel components
Legit choices
I'd add some deadner to do your doors and rear deck for sure. Other than that a DSP if you wanna splurge later, but that's about it.
cruzinbill is offline   Reply With Quote
Old 05-16-2013, 03:38 AM   #21
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
Wiring is amazing on the V9. You wire all the speakers and power into plugs that then plug into the amp. Makes very neat, easy to install and very easy to remove.
Also means you only need a single 4g power cable with no distribution.
Gir is offline   Reply With Quote
Old 05-16-2013, 03:43 AM   #22
BlueSTaR
BlueSTaR's Avatar
I would rather wire my speakers to a 4 channel under the seat.
I'm not saying the V9 is a bad option, because it's a great one. I just like 2 Amps vs 1 for wiring purposes.
Old 05-16-2013, 03:55 AM   #23
Gir
Gir's Avatar
I do not envy anyone trying to put an amp under a seat in this car. Also, that means you have to pull the seat out to adjust the tune, which is a little annoying.
Old 05-16-2013, 07:15 AM   #24
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
Originally Posted by cruzinbill View Post
Legit choices
+1. You should definitely factor in some sound deadening material into your build. This car is a no-frills sports car and therefore is prone to road noise and rattles - they wanted to keep the car as light as possible. The small 10 will exacerbate any rattles.
rmjjensen is offline   Reply With Quote
Old 05-16-2013, 08:03 AM   #25
Kayzer Soze
I found the v9 new for 399$ shipped on eBay, and the 8 inch speakers 99$ each shipped. Just wondering if the v9 has more than enough power if I wanted to put the 10inch alpine later on?
Also, what volume box should I look for for the 8 inch type R? (eBay)
Old 05-16-2013, 08:11 AM   #26
Kayzer Soze
http://www.ebay.com/itm/300893482719?redirect=mobile
Or
http://www.ebay.com/itm/330922708191?redirect=mobile
Or something else?
Old 05-16-2013, 08:23 AM   #27
Gir
Gir's Avatar
I'd just go a single 10". 2 8's is a bit much for this car.
Old 05-16-2013, 11:21 AM   #28
Sbeezy
2 8's will have more surface area than a 10 and just a little shy of 1 12.
GaN-MaN's Custom Audio Setup + Sub/Amp Box GaN-MaN Electronics | Audio | NAV | Infotainment 23 03-26-2014 05:43 AM
Boombacloud's BRZ Audio Build...Need Help/Advice boombacloud Electronics | Audio | NAV | Infotainment 1 12-28-2012 12:35 AM
In need of advice (full setup) computertech01 Electronics | Audio | NAV | Infotainment 8 08-02-2012 06:23 PM
Any specs on the standard Audio setup? viking84 Electronics | Audio | NAV | Infotainment 72 05-30-2012 03:34 AM
Audio setup 315FR-S Electronics | Audio | NAV | Infotainment 20 05-17-2012 06:23 PM
