Old 04-20-2013, 06:55 PM   #1
Celica00
Celica00's Avatar
Drives: 86
driver side window scratch
my driver side window makes a grind noise when I close and open my window and its leaving 2 vertical scratches. its going through the tint and everything. what should you do?
Celica00 is offline   Reply With Quote
Old 04-20-2013, 07:20 PM   #2
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
Back to the dealer she must go! Let us know what you find out so we know it's an isolated problem or wide ranged.
Ryuu0u is offline   Reply With Quote
Old 04-20-2013, 07:38 PM   #3
BRZnut
Drives: BRZ DGM Limited
Didn't someone else post recently that they had the same problem and the dealer found that some felt pads that protect the window as it goes up and down had fallen off??? I think so. Should be fixed under warranty
Old 04-20-2013, 07:41 PM   #4
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Yes, just within the past month.
whaap is offline   Reply With Quote
Old 04-20-2013, 08:30 PM   #5
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
whoo another recall in the near future!
campy is offline   Reply With Quote
Old 04-20-2013, 11:40 PM   #6
fistpoint
Drives: Supercharged Golf Cart
TSB.
If it isn't safety related, it's a TSB.
fistpoint is offline   Reply With Quote
Old 04-21-2013, 04:51 PM   #7
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Same thing! Although just one scratch closer to the front of the window. Spoke today with the AD - they scratched their heads and said that they could have look but if it's not a problem under guarantee - it would cost me circa $180 for dissassembling the door and I would expect the entire day during WE lost - something which I can hardly afford. Will likely go for it during the first servicing though.
Efferalgan is offline   Reply With Quote
Old 04-21-2013, 06:00 PM   #8
NewmarketBRZ
Drives: 2013 WRB BRZ Sport-Tech
That was me. The felt pads had separated from the window guide. The dealer took so pictures and Subaru Canada agreed to replace the window under warentee.
Look where the scratches are and the look inside the window to see if they line up with the white plastic parts.
NewmarketBRZ is offline   Reply With Quote
Old 04-21-2013, 09:18 PM   #9
N_I_N
N_I_N's Avatar
Drives: FR-S [Hot Lava]
Mine might be doing this too. It is making a squeaking noise when I roll up the windows, and you can tell there is resistance there. Like it is working harder to push the window up. Seems to be worse when it's wet outside...
N_I_N is offline   Reply With Quote
Old 05-10-2013, 11:20 AM   #10
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Which dealer did you take it to? I have the same problem where there's a vertical scratch on the inside of my passenger window messing up my tint. I took it to Markham Subaru but they didn't do much other than just looked at it. They said they don't have any TSB from Subaru about this issue so they won't do anything at this point because the glass is not damaged only my tint... I want to try your dealership. Please let me know.
chenshuo is offline   Reply With Quote
Old 05-14-2013, 08:54 AM   #11
NewmarketBRZ
I took the car to Subaru of Maple. They took very good car of the car and had it fixed in an hour. They will have to order parts which for me took a week.
Old 05-14-2013, 01:49 PM   #12
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
I have that too but only when wet.
FRSfan111 is offline   Reply With Quote
The Following User Says Thank You to FRSfan111 For This Useful Post:
hur1ey02 (05-14-2013)
Old 05-14-2013, 03:28 PM   #13
hur1ey02
hur1ey02's Avatar
My driver's side sounds like it rubs/slams in the wet as well. Dry operation is normal.
The dealer should take care of it if that's what is causing your issue, though!
Amanda - 2013 Scion FRS (Raven)
hur1ey02 is offline   Reply With Quote
Old 07-31-2013, 10:59 AM   #14
Efferalgan
By now (6 months in use) my driver's side door window has 2 sets of fat and very noticeable scratches for the entire length of the window. On the outside. No tint but the window is severely scratched - looks very ugly
Brought it to the dealer claiming a warranty case and still waiting for the result of their e-mail exchange with Toyota...
Curious to understand how many cars are affected with this issue - pls post here if you have similar problem. Thanks.
Driver Side Window Rattle RiceCooker Issues | Warranty | Recalls / TSB 23 08-18-2015 10:20 AM
Driver side door handle lordtakuban Cosmetic Modification (Interior/Exterior/Lighting) 19 06-19-2014 01:30 AM
4 pin connector driver side charley026 Cosmetic Modification (Interior/Exterior/Lighting) 0 03-30-2013 01:27 PM
Driver window controls don't work Hops Normal Issues | Warranty | Recalls / TSB 5 01-27-2013 08:35 PM
Teaking Tail light and Driver side passenger window auto down feyrerm Issues | Warranty | Recalls / TSB 2 08-11-2012 12:32 AM
