Old 05-10-2013, 02:07 PM   #589
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
I found a sweet app for Android today for those of you with Droids that tether your head unit to your phone for interweb access.
AutoTether:
https://play.google.com/store/apps/d...ethering&hl=en
This is such a simple app that senses your bluetooth connection from your radio and kicks your phone into tether mode automagically. And when you turn off the car, the BT connection stops and the app shuts down tether mode for you.
Now I can just get in and go. My phone switches to tether for me and my android radio has internet access for pandora, etc.
I have a Nexus 4 for reference. Tethering isn't locked out for me, don't know what might happen on a locked down carrier phone like a GS3 but won't hurt to try.
Just thought I would share something I found useful to make my knockoff experience even better.
Narcoden is offline   Reply With Quote
The Following 2 Users Say Thank You to Narcoden For This Useful Post:
microbionic (05-10-2013), redsuns03 (05-22-2013)
Old 05-10-2013, 02:11 PM   #590
privfaith
Drives: RX8 -> 2013 FRS
AutoTether:
I use an s3 and tether over wifi. I'll have to check it out.
Sent from my SGH-T999 using Tapatalk 2
privfaith is offline   Reply With Quote
Old 05-11-2013, 08:18 AM   #591
Ghostmerlott
Drives: GT86
Gents, what do you do with the ground/earth wire from the unit? The beatsonic wiring harness does not have a ground/earth line...
Ghostmerlott is offline   Reply With Quote
Old 05-11-2013, 08:53 AM   #592
Ghostmerlott
Drives: GT86
Originally Posted by yhng View Post
I'm going with the Tun21A as well. The extra buttons and with a few others using the same unit made me more inclined to pick it. Ultimately it was the Toyota startup logo on a BRZ that decided it though lol
@Ghostmerlott, out of interest would you be able to take some photos of the bundle of the Tun21A? Just so that I know what I'm up for with the installation.
@yhng, here is one for ya. The camera, beatsonic dashkit, connectors and tape are mine. rest came with the package..
Old 05-12-2013, 01:13 AM   #593
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
A question for those using one of these head units with your iPhone. I have an old 30GB iPod, a newer but still fairly old 160GB iPod and a 16GB iPhone 4s.
The iPod lead charges the 30GB and my iPhone 4s but doesn't seem to provide enough power to charge my 160GB. Anyone know why - it's not like it's new so shouldn't be affected by the old voltage change. If I was going to have a "non-charger" I thought it would be the newer phone.
And, is there any way I can amplify or step up the voltage in the iPod cable to provide the required extra juice? I quite like the iPod app the HU came with but ideally I'd like to be able to leave the 160GB iPod in the car for that purpose.
nzer is offline   Reply With Quote
Old 05-12-2013, 10:08 AM   #594
yhng
Drives: -
@Ghostmerlott thanks mate! Hope the install goes well and you can update us on it.
yhng is offline   Reply With Quote
Old 05-12-2013, 10:52 AM   #595
Lo
Drives: Old Saturn
@Ghostmerlott I can't wait to read about how you mounted your rear camera. I too (much like nzer) would be doing a small mod on my future car for the first time. Although nzer has a step up on me with changing his oil by himself... I've got much to learn and try...
Lo is offline   Reply With Quote
Old 05-12-2013, 07:02 PM   #596
ph0en1xtk
ph0en1xtk's Avatar
Drives: Raven MT Scion FR-S
dunno if you ended up figuring this one out yet or not, but i also use the beatsonic harness and what i did was i ran a wire from the negative terminal on the battery through the firewall and to the unit so it has a dedicated ground. I dont know if this is the proper way to go about it, but it works for me!
I think typically you can just ground it to a bolt nearby under the dash thats on metal, but i like my dedicated wire.
ph0en1xtk is offline   Reply With Quote
The Following User Says Thank You to ph0en1xtk For This Useful Post:
Ghostmerlott (05-13-2013)
Old 05-12-2013, 08:25 PM   #597
Ghostmerlott
Drives: GT86
thanks buddy, can you elaborate more on the "bolt nearby" approach? Where is this bolt?
Old 05-12-2013, 08:53 PM   #598
yhng
Drives: -
you can hook the ground cable to a metal piece, see if you can locate a convenient metal bolt around the dash.
The Following User Says Thank You to yhng For This Useful Post:
Old 05-12-2013, 11:13 PM   #599
Lo
Drives: Old Saturn
I've seen pictures of a dedicated ground bolt located in the fuse box near the driver's left leg (LHD models so dunno about Aussi spec). I saw those pics in a DIY thread about installing Dash cams.
The Following User Says Thank You to Lo For This Useful Post:
Old 05-13-2013, 10:12 AM   #600
qoncept
qoncept's Avatar
I have a 30gb 5.5gen ipod connected to a Pioneer HU in my Sequoia and have some sort of battery issues.. It seems the battery drains while the HU is off and KIND OF charges while it's on. I wonder if your problem is the same.
qoncept is offline   Reply With Quote
Old 05-13-2013, 10:37 AM   #601
2forme
I have a 160GB classic, and it functions fine off the TUN21A. I've never seen the battery die on it. It freezes regularly and needs to be rebooted or refreshed on occasion, but that's because crApple, not the HU.
The Following User Says Thank You to 2forme For This Useful Post:
nzer (05-13-2013)
Old 05-13-2013, 02:15 PM   #602
krikke
Drives: Evo x gsr
Hope you guys can clear two things out for me as I think the questions are Android related and common with the units that you guys are using:
-1- the Ekoore unit can be ordered with a OBD2 usb cable as the Elija S2 is Torque compatible.
However, will Torque also work with a OBD2 bluetooth connector instead of the USB cable?
-2- as the unit comes without any offline navigation software + maps, I assume pressing the NAVI/GPS hardware button will open Google Maps. Is it possible to re-address the NAVI/GPS button to any aftermarket navigation software I install later on?
krikke is offline   Reply With Quote
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-19-2013 11:51 PM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 10:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 03:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 05:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 10:47 PM
