go_a_way1
Old 05-09-2013, 09:43 AM   #183
blags
Drives: Toyota 86
Interesting, what's a set up like that cost? Something I should look at... I live and work in impractical areas so it'll suit me.
blags is offline   Reply With Quote
Old 05-09-2013, 01:09 PM   #184
xxscaxx
Drives: 2013 SWP BRZ
I get this question a lot and its hard to answer, only because it depends on what management system/air struts you go with.
Airlift struts - 995 a set (need front, rear, so 1990) Airrex also has struts available but they are 2350 I believe
Management system - You can opt to go for the eLevel system (which is a height sensor based system - 4 sensors are installed in each corner) but that is around 1800 last time I checked. I have the AutoPilot v2 which is a pressure based system (no sensors in each corner) and thats around 1200. Mine was cheaper because I already had parts of the system from my old sti. I actually had the elevel which is great, it does all the thinking for you, but I was hesitant to drill into a new car to install the sensors and theres more involved with installation on it, so I decided to try out the v2. I like both, the elevel is a bit easier to use but I like the fact that the v2 has a controller that you can see PSI in each corner, its great for tracking down leaks/monitoring (elevel has a controller but doesn't have a display for pressure, you would need to install gauges).
You could do a basic management system with paddle valves for like 500-600 bucks, but you need to mount gauges to monitor the pressure, and also mount the paddle valves somewhere. Wandering on the VW forums, a lot of people prefer this setup because there are less working parts which means less leaks, less worry, and you don't have to worry about an ecu crapping out on you and getting stuck lol.
It all really depends on what you want. It could cost up to 4.5k, down to 2500-3k.
xxscaxx is offline   Reply With Quote
The Following 3 Users Say Thank You to xxscaxx For This Useful Post:
Bcarlos (06-18-2013), boucher (05-09-2013), nix (05-10-2013)
Old 05-09-2013, 02:51 PM   #185
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
dont think the BRZ section has an aggressive wheel thread..
but here it is-
BC Coils
18x10 front, 18x11 rear.
SLICVIC is offline   Reply With Quote
The Following 6 Users Say Thank You to SLICVIC For This Useful Post:
636 (05-10-2013), boucher (05-09-2013), jdmasfcuk (05-11-2013), SciOnDrifTtSlIdeR (12-29-2014), xxscaxx (05-09-2013), zenki_levin (05-09-2013)
Old 05-09-2013, 02:54 PM   #186
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Meisters. What did you end up getting?
Meister and xd9s lol
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 05-09-2013, 06:40 PM   #187
blags
Drives: Toyota 86
Have you got your Meisters yet?
SLICVIC - have you removed the collars from your BC's?
Old 05-09-2013, 07:24 PM   #188
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
@blags yeah fronts are completely maxed
Old 05-09-2013, 07:33 PM   #189
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Ya both sets are at home... I'll be back in less then a month hopefully.
Omar GC
Instagram: 2jzus
The Following User Says Thank You to OmarGC For This Useful Post:
JDMenrique (05-09-2013)
Old 05-10-2013, 02:25 AM   #190
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
Dem Porsche wheel ain't for me but props for being different.
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
The Following User Says Thank You to jedichimp For This Useful Post:
SLICVIC (05-10-2013)
Old 05-10-2013, 02:53 AM   #191
PradiG
Drives: Fr-s
nice! which set of meisters did you get? S1R?
PradiG is offline   Reply With Quote
Old 05-10-2013, 03:08 AM   #192
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Yeah 18x9.5 +27 bronze/gloss bronze
Then I also got a square set of 18x10's
Omar GC
Instagram: 2jzus
The Following 2 Users Say Thank You to OmarGC For This Useful Post:
PradiG (05-10-2013), PRORICAN (05-10-2013)
Old 05-10-2013, 08:45 AM   #193
xxscaxx
blang blanggg!
All Things Proper Photo 2 by xxscaxx, on Flickr
The Following 7 Users Say Thank You to xxscaxx For This Useful Post:
636 (05-10-2013), Bcarlos (06-18-2013), Frs123 (09-29-2014), jdmasfcuk (05-11-2013), Jesse@JDLAutodesign (05-10-2013), ozne99 (05-10-2013), PRORICAN (05-10-2013)
Old 05-10-2013, 03:19 PM   #194
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
XXR 530s w/Eibach Pro-Kit:
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
The Following User Says Thank You to Moshpit37 For This Useful Post:
mgarcia707 (03-18-2019)
Old 05-10-2013, 03:20 PM   #195
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
18x10s
JDLAutoDesign is offline   Reply With Quote
The Following 3 Users Say Thank You to JDLAutoDesign For This Useful Post:
Bcarlos (06-18-2013), xxscaxx (05-10-2013), Zaku (09-15-2013)
Old 05-10-2013, 04:06 PM   #196
PRORICAN
PRORICAN's Avatar
NT03+M 18x9.5 +40 265/35 squared
PRORICAN is offline   Reply With Quote
The Following 10 Users Say Thank You to PRORICAN For This Useful Post:
boucher (05-10-2013), chanomatik (05-21-2013), HATED1 (05-10-2013), Jesse@JDLAutodesign (05-10-2013), Juvenile (05-10-2013), M-17 (05-10-2013), sal (05-10-2013), tomato86 (06-12-2013), Wolfking (09-24-2014), Zaku (09-15-2013)
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
