alpine, ATL BRZ, ftc~brz, jamesm, King Tut, OrbitalEllipses, sklimo, SmsAlSuwaidi, Sportsguy83, whitefrs
Old 05-10-2013, 12:05 AM   #435
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I like the idea of a 180 heading down and then going over on top of the transmission. Let me know if you find something that will accomplish that.
Old 05-10-2013, 12:21 AM   #436
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by nix View Post
Black looks fine! Could you do a tight 180 bend from the top of the tank and point it straight down?
I think getting one or two more 90 degree elbows along with the barbed hose connectors will do the trick. Elbows are $16 each though :-( . I'll order them tomorrow and will update as soon as I get them.
Sent from my HTC One X using Tapatalk 2
Old 05-10-2013, 04:29 PM   #437
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Really don't want to jack this thread, but the piping on top with the filter is basically just to keep the fumes going out underneath the car correct ?
Old 05-10-2013, 04:43 PM   #438
Sportsguy83
Drives: Limited BRZ
Not jacking at all. Yea for the fumes.
Old 05-10-2013, 05:59 PM   #439
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
So where the fumes come from that you need that tube?
kombatlion is offline   Reply With Quote
Old 05-10-2013, 06:07 PM   #440
Sportsguy83
Drives: Limited BRZ
The Catch Can is vented to atmosphere, so it's like if you drill a hole in the block in the oil side, and have those hot oil/gasoline fumes in the engine bay.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
kombatlion (05-10-2013)
Old 05-10-2013, 06:16 PM   #441
ft_sjo
Drives: GT86
Considered venting it back into the intake tract like OEM?
The Following User Says Thank You to ft_sjo For This Useful Post:
Jason (05-10-2013)
Old 05-10-2013, 06:44 PM   #442
Sportsguy83
Drives: Limited BRZ
What I initially wanted was to use the port on top of the TB for my pressure signal and only use the intake port to recirculate. At the time I ordered this can, there were none like that with specific application to our cars, so I ordered this one. Since then, the AVO now offers the option as I intended it but since I already purchased this one, might as well keep it.
I guess I would have to find a reducer from 1.5 inch to 1/2. It's not a bad idea, I'll consider it. Thanks!
Old 05-11-2013, 01:35 AM   #443
ft_sjo
Drives: GT86
Just stick it into the air box....
Old 05-11-2013, 01:37 AM   #444
Sportsguy83
Drives: Limited BRZ
I have the Perrin CAI, airbox is gone.
Old 05-11-2013, 01:41 AM   #445
ft_sjo
Drives: GT86
Get a boss/take-off welded to it then.
Old 05-11-2013, 07:20 PM   #446
Sportsguy83
Drives: Limited BRZ
Added two extra O-Rings to the fuel pump since I had an intermittent issue getting lean on high RPM's. Initial testing shows the issue is solved! i now have four O-Rings in the fuel pump.
Old 05-12-2013, 01:04 AM   #447
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
No, 500 cc injectors, DW65c fuel pump.
how are your injectors handling your current boost setting ? % wise ?
trying to decide on going 550 or 700.
killerkid08 is offline   Reply With Quote
Old 05-12-2013, 01:11 AM   #448
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
550 should b good for about 280 HP (at the crank, not wheels i believe) so if u want more then about 250 WHP id go higher
lbroskee is offline   Reply With Quote
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 05:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 11:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 03:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 08:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-13-2012 12:35 AM
