Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
SCCA Solo C Street Discussion
A few of us running C Street currently and it seems a few more are interested. Just thought I'd start a thread we can update with information.
What is C Street? C Street is a stock based classed for low to medium power cars that are upper-lightweight. Main competitors are the 370z, 350z, RX-8, twins and non-MSR MX-5. Modifications This class has limited modifications. You can modify/add: *Any exhaust behind the last Catalytic converter (Aka you can add an Catback or Axleback exhaust). It must be full length, reach the rear bumper *Any drop-in filter (you cannot change the intake or modify the airbox or intake tube) *Any shocks/struts that mount up as stock replacements (though you can currently have external reservoirs). Change, replace or remove ONE sway bar. One of the two bars must remain *OEM and attached though it is your choice of which one to modify (though a front bar is the only one that makes sense for this car) *OEM Crash/Camber Bolts. These allow you to add a small amount of front camber. Some cars vary in the amount of camber you can gain. I reached -1.4 while some people could not pass -0.8 and others saw -1.5. Get an alignment after install!. This is likely to throw the Toe off in your front end. Large tire wear, pulling to one side or poor handling can occur from this. OEM part numbers are as follows: Toyota: SU003-02818 Subaru: 901000394 *Any brake pad you want *Any fluids you want (brake, oil, coolant, transmission, differential) *Stock sized wheels within 6mm offset. This means 17x7 with an offset between +42 and +54. Spacers to count for offset reduction. Example, with a +48 offset wheel (such as stock), you can throw on a 5mm spacer (never use bigger than 5mm on our stock studs!) and have an effective offset of +43 and be legal but you cannot use a +42 wheel and use a 3mm spacer. That would equal +39 which is too low of an offset. *Tires. This is the biggie. You can use a 140 treadwear or higher tire in this class. This only rules out RCompound tires. Common Upgrade Parts This will be a non-comprehensive list, meant to give you guys an idea of what the more popular parts are for the major modifications for C Street Tires This is the key to this class (as any autocross class). The competitive tires in this class are Hankook RS3, Dunlop Starspec Z1, Dunlop Z2, BFG Rival, Bridgestone Potenza RE11 and RE11A, Toyo R1R. There are others but that covers 98% of street tire SCCA cars. Different conditions and driving styles call for different tires. Please do not ask "What tire is best?" as there is no one answer. The short answer is the three top tires are the Rival, Z2 and RS3 but each one is better for different drivers and different conditions. And other tires can be competitive, those three are just the most popular for a majority of the faster drivers. Front Sway Bars These will reduce oversteer and give a more planted front end feel to the car. Different bars are preferred by different people and different setups. These are the most common bars I see around the RTR world. Strano 22mm Hollow - 85% stiffer than stock Hotchkis 25mm Hollow adjustable - 180% or 245% stiffer than stock Whiteline 22mm Solid adjustable - 118.5% or 174% stiffer than stock Cusco 20mm - I know little about this bar. Will add more when I get information Whiteline 20mm - Unknown stiffness You can also add aftermarket endlinks to the front bars to provide additional stiffness and adjustability. Air filter Air filters are mostly the same in that no one will make huge gains over another, despite the claims. Just know that there are two kinds; oiled and dry. Oiled tend to let slightly more air through and thus slightly more powerful (but negligible amount). However, many people believe that the oiled filters can lead to damaged MAFs after a while (I myself am in this camp and use Dry because of this). I won't list individual companies here so just look for dry or oiled air filters for sale from your favorite vendor. Shocks/Struts There are two big choices at the time on writing. Koni Sport/Yellow at $600-800 a set (which require you to cut up your front struts and insert new cartridges) or MCS at $3000-4500 a set. MCS is obviously expensive and at ~$3000 gives you single Rebound adjustment, as the Konis do or at ~$4200 MCS give you Rebound and Compression adjustment (as well as an external reservoir). Konis are what most people are using due to the cost and they are working well. There are many people who believe trick shocks just don't provide enough value during your autocross runs. But then again, many do. Do your own research and make your own decisions. Throughout this thread, hopefully there will be shock setting discussion to help all of us learn, especially those of us trying to tune these Konis in still. Wheels With any 17" wheel with a width of 7" and an offset of +42 through +54 legal, you now have a handful of choices. As I cannot list all of these without a huge thread just for it, I suggest you check out @DarrenDriven's EXCELLENT wheel thread over here. Darren spent countless hours listing every known wheel for our cars. Go there and do a search in your browser (CTRL+F) for 17x7.0 to browse through your options I will put that the most popular options is the Enkei RPF-1 as it is decently priced and very durable while being one of the lightest options. Shock/Strut/Sway Bar Tuning These are not gospel but just a general rule of thumb to get you started. Corner entry over steer: Soften rear rebound Corner entry under steer: Stiffen rear rebound Corner exit over steer: Stiffen front rebound Corner exit under steer: Soften front rebound Mid corner over steer: Stiffen front bar Mid corner under steer: Soften front bar RTR Build Threads/Progress Logs @Kido1986 - http://www.ft86club.com/forums/showthread.php?t=31456 @TRev - http://www.ft86club.com/forums/showthread.php?t=33074 @trippinbillies40 - http://www.ft86club.com/forums/showthread.php?t=34493 @DylanFRS - http://www.ft86club.com/forums/showt...444#post919444 @Dezoris - http://www.ft86club.com/forums/showp...45&postcount=5 More to come... I am at work adding as I can. Anyone please throw up sections you'd like added to the first post and I'll make it happen
| The Following 36 Users Say Thank You to Kido1986 For This Useful Post: | 6-Shift (05-10-2013), Amadeus (05-12-2013), amram (03-18-2014), Biggins (05-08-2013), BRZ21 (04-21-2014), des (05-08-2013), DylanFRS (05-08-2013), funwheeldrive (03-25-2015), housecat (07-01-2015), HSUBLU (08-22-2017), Jeff-RS (06-07-2015), jetfire (09-02-2014), leon78 (05-08-2013), Lonewolf (05-08-2013), mla163 (05-13-2013), MoarGeesPlease (11-23-2013), NYC BRZ (05-13-2013), Ocala FR-S (01-16-2014), pinski (10-03-2014), PoorMansRacing (10-25-2013), Prmspen (05-23-2016), Quentin (05-15-2014), racecaresuaceb (04-08-2014), rs999 (08-16-2014), rusty959 (06-17-2013), Ryeong86 (02-10-2014), Shankenstein (03-18-2014), ShoShin (01-15-2015), Sonolin (05-08-2013), sosick (01-30-2014), stevesnj (09-10-2015), TofuJoe (10-19-2015), TRev (05-08-2013), TurtleFace (07-30-2015), whataboutbob (05-09-2013), zohaib (03-19-2014) |
#2 |
Dodging cones
Reserved
#3 |
Very helpful. I won't do a build thread, but with such a limited amount of prep allowed, it might help to list the options available for each, and maybe even who has them:
Sway bars: 20mm Cusco (des) 20mm Whiteline (TRev) It wouldn't hurt to include alignment, tires and wheels in the mix, either. There's no point in repeating each others' mistakes, right? |
| The Following User Says Thank You to des For This Useful Post: | Kido1986 (05-08-2013) |
#4 |
I will just add my build to this thread:
Dezoris RTR AutoX Build Thread Shocks: OEM Front ARB: Strano (From Stranoparts) Camber Correction Front: OEM Crash/Camber Bolts (Subaru) Tires: 225/45/17 Hankook RS3s (Discount Tire) Brakes: Project Mu HC800 (Vendor CSGMike) Alignment: (Private) FR (Camber -1.5 - Toe Out -.05) FL (Camber -1.5 - Toe Out -.05) RL (Camber -1.3 - Toe In -.08) RR(Camber -1.3 - Toe In -.08) AutoX Video: (Forward to 11m:19seconds) [ame]http://youtu.be/rsWHuEUVK3k?t=11m9s[/ame] Final Thoughts: In all honesty if you are strapped for cash, I would not even consider doing more than this, as it is completely competitive in local clubs for 1-3rd place in class. I have had 4 events and so far its even good for competing with your STX competition. All you need is some seat time to improve. The car feels excellent, on the street and autocross. Very impressed. It's a setup I stand behind for daily driving and driving right to any event no drama. (Brake pads are totally optional as they made fractional difference for me in performance overall) However I doubt this would be competitive on a national level but, I have yet to try.
| The Following 7 Users Say Thank You to Dezoris For This Useful Post: | amram (06-04-2014), Bimble Bamble (03-08-2015), Boxer 86 (06-27-2013), CatDaddysBBQ (06-06-2014), Kido1986 (05-08-2013), racecaresuaceb (10-20-2014), spineman (03-04-2015) |
#5 |
Dodging cones
I felt the build pages on this class were still good so you can list events and behaviors of particular changes. Let others get an idea of what setting changes have what effect.
I will be adding common parts sections for the mods later (most common FSBs, Shocks, Tires, wheels)
#6 |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
Yeah, I definitely like the idea of build threads to keep track of what the individuals are doing, This thread will be nice for us to do actual discussing of what we are thinking, comments, concerns, plans, etc so we aren't just constantly jacking the build threads with long discussions and this leaves a lot of the discussions in one places instead of 6 different threads.
Looking forward to this thread. ![]() Anyone making Nationals this year? |
| The Following User Says Thank You to DylanFRS For This Useful Post: | Kido1986 (05-08-2013) |
#7 |
Dodging cones
2014 in C(?) Street but not this year for me.
#8 |
#9 |
Dodging cones
If I add something that is wrong, let me know. Of course I am doing my best to stay as neutral as possible but of course everyone has biases as well as I am not an expert mechanic nor expert on every part for this car.
I can and will make mistakes so help me keep the first post as topical and accurate as possible.
#10 | |
#11 |
May be a stupid question, but are the rears adjustable for camber?
#12 | |
With all my cars I run on the street and track I always setup slight toe out in the front as it improves turn in/steering feel. Toe in on the back for braking stability. I have done this on my Lotus, Atom and S2000 and have been very confident. There are benefits to zeroing toe in the rear on this car but not many for street driving aside from potential wear. As always this is driver dependent, but that's why I do it in short.
#13 |
No only toe. Sucks big time.
#14 |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
With the multi-link rear there really shouldn't be any need to add significant camber to the rear anyway, the camber curve is not nearly as bad as with a Mac-Strut. Most people who need to adjust camber on the on rear are those who change ride heights, and that is more for camber correction than needing additional camber. Since stock doesn't allow it, I wouldn't consider it a disadvantage to the rest of the field... I can't recall any OE multilink rear suspension vehicles which come with an OE rear camber adjustment.
Andrew and Sam posted info on how to adjust rear toe through the subframe bushings if you find your car came from the factory with left to right toe imbalance. For the forseeable future I'll be running RTR/Street. We'll see where it goes from there.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
| The Following User Says Thank You to Sccabrz192 For This Useful Post: | amram (03-18-2014) |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
