Old 05-03-2013, 09:37 PM   #1
Mustang88_357mag
Mustang88_357mag's Avatar
Drives: 2013 FRS Raven color
Perrin LCP
So I got my Perrin light weight crank pully in the mail today I installed it per perrins directions and for some reason I am getting this whineing noise it's only at idle as soon as it rev's up past 1000 or so Rpm it goes away so am letting it idle and then I notice the pully is vibrating back and forth a bit so I'm going to take it all apart again tomorrow buy a new torque wrench and do it all over again
Mustang88_357mag is offline   Reply With Quote
Old 05-03-2013, 09:40 PM   #2
ramiram1984
Drives: 2016 STi DGM
K. Recheck it.
ramiram1984 is offline   Reply With Quote
Old 05-03-2013, 10:10 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Replace the bolt. Go get it at the dealer, better safe than sorry.
Old 05-04-2013, 01:36 AM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
And check the o-ring, and keyway are installed properly.
The Following User Says Thank You to Calum For This Useful Post:
Sportsguy83 (05-04-2013)
Old 05-04-2013, 12:25 PM   #5
Mustang88_357mag
We'll took it off and put it back on retorqued it and the noise is still there every once in a while it's defentily not coming from the crank almost sounds like a very small vacuum leak or something the noise is coming from the left side and is directly over the fuel injectors. The noise is only at idle rpm as soon as any gas it applied to goes away. Gonna drive it around a hit and see if it goes away
Old 05-04-2013, 01:29 PM   #6
Sportsguy83
Drives: Limited BRZ
Did you get a new bolt?
Old 05-04-2013, 01:34 PM   #7
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Stories like these are what made me shy away from this mod. It seems like more and more people are having problems with new pulleys. And if you care about warranty, the dealership won't be very happy that you changed out a pulley.
husker741 is offline   Reply With Quote
Old 05-04-2013, 02:00 PM   #8
Mustang88_357mag
I have not yet, can I ask what a new bolt will do I only have 1000 mile on my FRS
Old 05-04-2013, 05:30 PM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
And by the same token more and more people are not having problems.
Has the OP read this thread?
http://www.ft86club.com/forums/showt...=perrin+pulley
"This warning has to do with installer error and has no bearing on the quality of any pulleys."
Old 05-04-2013, 07:38 PM   #10
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
15k miles on the perrin pulley...no issues at all...and it was a simple install. OP..did you try simply putting the old one back on to see if the issue was indeed the pulley?
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 05-04-2013, 07:48 PM   #11
Sportsguy83
Drives: Limited BRZ
You most probably will be fine. My comment was because re torquing that bolt might become a liability. This is a "plastic region" bolt, so it was intended to only be torqued once and thrown away if it ever needed to be removed.
A plastic region bolt means that when torquening it, it deforms and elongates. This deformation means that its properties have changed and would not have the same strength if it is used again.
That is why I didn't even ask what was your mileage, my issue was with toquening it a third time. At the factory and now you twice.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
SmsAlSuwaidi (05-04-2013)
Old 05-04-2013, 08:25 PM   #12
Mustang88_357mag
That thread is great wish I read that before installing my LCPL'S. so the wobble I mentioned in the Original post was just the tensioner pully. Everything was flush when I put the LCPL'S pully on and it's running fine now no noise so I dunno what was up
Old 05-04-2013, 08:35 PM   #13
ramiram1984
I have 3 pulley set to include crank, H2O pump and alt pulley. No probs at all. Have Had it on about a week now and drove to perrin and back yesterday. No issues and it's awesome upgrade. Love the engine response.
Old 05-04-2013, 09:22 PM   #14
empower-auto
Kouki-Monster
empower-auto's Avatar
13k miles on my Perrin Pulley .. no issues to report
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Let there be NO DOUBT: Non Resonated PERRIN> Resonated Perrin HP gmookher Engine, Exhaust, Transmission 78 09-11-2013 10:42 AM
Perrin Stubby Antenna and black Perrin oil cap. notFRS Exterior Parts (Aero, Lighting, Etc.) 13 05-22-2013 09:05 PM
perrin pulley perrin intake tube Area51 Engine, Exhaust, Bolt-Ons 4 04-05-2013 06:11 PM
