Old 05-03-2013, 12:50 AM   #43
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Guys, lets take it easy.
Just always start off in 6th gear, and the only time you need to shift is when you need reverse. Saves the syncro's IMO, ymmv
The Following 3 Users Say Thank You to continuecrushing For This Useful Post:
Enraged21 (05-03-2013), sprintertrueno86 (05-03-2013), virobloc (05-03-2013)
Old 05-03-2013, 01:16 AM   #44
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
I've read about gear skipping (sorry can't remember the source), and it's actually more complex than just using rev-matching to compensate - even when you rev match is you are skipping gears you are still putting extra strain on the synchros. I saw the mechanical driveline diagrams that explained the reasons for this at the time, they were very clear, but couldn't recall the technical explanation now.
The takeaway was - if you want to skip a gear, it can be done without straining the synchros but only if you go through all the intervening gears while the clutch is kept in as this 'steps down' the speed differences the sychros have to deal with. So:
clutch in
2 -> 3
3-> 4
clutch out
Sport-Tech is offline   Reply With Quote
The Following User Says Thank You to Sport-Tech For This Useful Post:
Old 05-03-2013, 02:01 AM   #45
virobloc
virobloc's Avatar
Drives: Toyota GT86, MT, Kyuzo Red
You can skip all the gears you want without straining the synchros at all if you double clutch properly.
virobloc
virobloc is offline   Reply With Quote
Old 05-03-2013, 04:19 AM   #46
burnt toast
burnt toast's Avatar
Drives: whiteout
clutch in
2 -> 3
3-> 4
clutch out
Exactly what I came across on forums during my s2000 days. The frs/brz trans is pretty similiar to the s2000 trans, aisin az6 iirc.
burnt toast is offline   Reply With Quote
Old 05-03-2013, 04:04 PM   #47
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
side question since we're talking about shifting. i give the engine a little bit of gas when upshifting (revmatch). I recently read that you're not supposed to revmatch at all during upshifts? is this true? how do you get a smooth shift without too much accel decel without revmatching it?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 05-03-2013, 04:21 PM   #48
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
All this talk about Rev matching and double clutching while daily driving is total bunk. It's thrown around by guys who think they are doing something special.
The synchros now negate all this crap. My MT toyota pickup is 19 years old. 160k miles, original clutch. I've never rev matched, double clutched, or blipped it. I spent years driving it like I stole it.
Drive your vehicle how ever you want, but don't act like you NEED to do any of that junk.
Freetime is offline   Reply With Quote
The Following User Says Thank You to Freetime For This Useful Post:
jmaryt (05-03-2013)
Old 05-03-2013, 04:44 PM   #49
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
You don't need to do all that shit, but don't go and post crap about how it's stupid on public road.
Even been on the highway in 5th/6th and want to pass in 3rd? Double clutch and rev match like a king, it takes less than a second and the gear goes right it and it's just as smooth as an automatic.
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
virobloc (05-15-2013)
Old 05-03-2013, 04:52 PM   #50
OrbitalEllipses
Drives: Attitude
What, you want us granny shifting and not double clutching like we should?
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Tim_Asphalt_FRS (05-03-2013), virobloc (05-15-2013)
Old 05-03-2013, 09:14 PM   #51
jmaryt
Drives: 2012 honda civic ex
this is "dead nuts" accurate!
jmaryt is offline   Reply With Quote
Old 05-03-2013, 09:21 PM   #52
jmaryt
synchros and "helical" cut gears eliminate double clutching,and rev matching. "older" trucks required ''double-clutching",AND rev matching because they were equipped with "conical" cut gears that would NOT mesh WITHOUT double clutching,and rev matching. example: "fuller road ranger" transmissions 15 speeds. (conical gear box) conical vs. helical is indicative of the "shape" of the gear teeth.
Old 05-03-2013, 09:28 PM   #53
jmaryt
it's not stupid if you want to do it! it's your car! do what you want!
Old 05-03-2013, 09:31 PM   #54
MojoToot
MojoToot's Avatar
Drives: red fr-s
When you're upshifting, you are going from higher RPM to lower RPM. So no need to give it gas until letting clutch out. (unless maybe you are a super slow shifter).
Downshifting you are going from lower RPM to higher RPM so "revmatching" has a purpose here (although-as has been noted already-not "needed" when you have syncro')
MojoToot is offline   Reply With Quote
Old 05-03-2013, 09:43 PM   #55
jmaryt
as long as your shifts are smooth,there is no reason to rev match at all.now if ya want to,then that's different! i don't particularly get a charge out of it,as it's never a concern with me. modern trannies have eliminated the "need" to do it (as noted in previous posts)
although i have to admit to "double-clutching" all the time, a carryover from my truck driving days. tough habit to break...just sayin'
Old 05-03-2013, 10:53 PM   #56
FR-anco89
FR-anco89's Avatar
Drives: Asphalt FR-S MT
Originally Posted by BlaineWasHere View Post
What gap are you talking about? 4 lanes of freeway traffic moving 55-75 MPH and I have 100 feet from a dead stop at the meter lights. Some ramps have plenty of space after the meter lights but some have hardly any space like the one I get on every morning from my house.
If you read the whole post not just what you quoted it will answer your question. And the gap I'm referring to is the space in between cars when you merge into (assuming you're merging into another lane, if not then this post is irrelevant). You will not save gas skipping gears if your still flooring it, you're actually wasting gas the more you press the pedal not only what gear your on. You can't accelerate from 0-55/75 fast and be efficient. Sorry you need another car if that's what you want.
FR-anco89 is offline   Reply With Quote
Shift Knob Zoomryder Issues | Warranty | Recalls / TSB 5 04-09-2013 09:39 PM
CF Shift Paddles? FRS_Ken Cosmetic Modification (Interior/Exterior/Lighting) 2 01-24-2013 12:05 AM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 02:11 PM
Thoughts and secrets of the FR-S/FT-86 Interior KevinDuMa Scion FR-S / Toyota 86 GT86 General Forum 56 07-21-2011 03:38 PM
Shift Apparel Lexicon101 Other Vehicles & General Automotive Discussions 2 05-02-2010 01:44 AM
