Old 04-07-2013, 01:08 PM   #85
Ch3cho86
Ch3cho86's Avatar
Drives: Scion FR-S
Originally Posted by sw20kosh View Post
Hello,
***UPDATE: Housings are still intact - Silicone sealant worked perfectly
***UPDATE: No condensation/fogging at all after rain, fog and wash with pressurized water stream!
Here is a simple guide on how to black out your tail light housings.
It is not for a feint of heart as dremel'ing (cutting) up your tail light is some serious business. Hopefully it pays off in the end.
This is a 5-7 hr job depending on how good you are with a dremel and how comfortable you are with cutting up tail lights. I was very nervous and took things really slow especially on the first light. You also need to let the new sealant set over night so this is a long process.
You need:
1. screw driver
2. wrenches or metric sockets (deep sockets)
3. dremel with a cutting tool
4. paint (i used semi gloss black spray paint)
5. tint (optional - for those who want to make the red a darker red and to retain some functionality of the turn signals)
6. painters tape
7. sealant adhesive
(used some of Darrendriven's pics for the removal of tail lights - Darren let me know if you don't want me doing that for this guide and I will get my own pics)
1. Pop the plastic rivets out on either side of the trunk near the tail lights and fold the carpet back
2. Using a small tool (like a pick, or even a nail) you can lift the plastic catch inside of the zip tie. Pull the harness out and remove that plastic piece from the stud.
3. Remove 4 nuts from the studs. They are 8 mm or smaller (def not 10 mm)
4. After cleaning the lights up with mineral spirits and towel, take your dremel and cut this piece off of the lights.
5. It will look like this. You need to do this in order to get to the housing underneath it.
6. Start cutting around the housing. Cut the black plastic but never cut the clear plastic. It is really hard to describe where to cut so you have to look at it and see/imagine where the housing is fused with the clear lense. Cut "behind" where they are fused - so that when you are done cutting the two pieces fall apart and the clear lens has a border of black plastic. It is probably best to just look at the pics.
7. More cutting
8. More
9. And more
10. Tada!!! The two halves separate and the chrome garbage falls out
11. Optional: I sprayed a layer of Lens Tint on this circular area to make it darker red.
12. Mask off the side marker (Looks like it is glued in so I didn't want to risk breaking something by prying it out)
13. Optional: mask off the turn signal area where the yellow bulb sits. You may want to keep this chrome so that it stays max reflective. I, however, sprayed Lense Tint in there AFTER I painted the housing black.
(you can see that area is lighter than the rest - still retaining some semblance of reflectivity)
14. Paint the chrome bezel now. I used 3 coats with at least 20 mins in between coats. Here is what it looks like after painting with Black paint. Let it dry for a few hours.
15. Install the bezel back into the housing when paint is dry.
16. Before installing the bezel I decided I wanted the red pieces to be darker so I sprayed them with a layer of Lens Tint.
17. Install the lense and apply the silicone sealant to the interface between the two halves. Let it sit overnight.
18. Tools etc
19. Dremel bits used (I used the small one)
20. Celebrate and treat yourself to a tasty beverage!!!
Lights off.
Lights on!
Hazards/turn signals functional!
Best shot
Installed pics coming in the morning!
Cheerz
Pictures are down!
Ch3cho86 is offline   Reply With Quote
Old 04-21-2013, 07:21 AM   #86
GT2Be
AmmaniV12.com
Drives: Just an 06 Corolla for now
can you please re-upload the pictures?
GT2Be is offline   Reply With Quote
The Following User Says Thank You to GT2Be For This Useful Post:
Ch3cho86 (04-21-2013)
Old 04-22-2013, 10:09 AM   #87
Ch3cho86
Ch3cho86's Avatar
Drives: Scion FR-S
my frs have drops of water inside The taillights. I want to open them and paint them with plastidip
Old 05-01-2013, 09:01 PM   #88
Xdragonxb0i
Drives: ex500r
is it just me? but there are pictures missing
Xdragonxb0i is offline   Reply With Quote
Old 05-02-2013, 12:57 AM   #89
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Add pics back!
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 05-02-2013, 07:31 PM   #90
ph0en1xtk
ph0en1xtk's Avatar
Drives: Raven MT Scion FR-S
Im not entirely sure what i did wrong in my mod, but after cutting them open, painting them and putting them back together, i got tons of water in them every time it rained or when i washed the car. I tried resealing them on 3 separate occasions, using different kinds of silicone sealant, window weld and everything. One time i took a very strong flash light and shined it around the seal everywhere i could just to be sure no light was visible and still had the same issue. Now after time the water that keeps resting in my tail lights (and eventually disappearing after a day or 2) has caused tons of small micro fractures all over the clear lens. My tail lights are practically ruined in my eyes Shame too, cause i absolutely loved the way they looked when i was done with them, just not the water part.
ph0en1xtk is offline   Reply With Quote
Old 05-02-2013, 07:55 PM   #91
jwjknorr
Drives: FRS 2013
Make a new gasket , the factory one sucks thats probably your problem.
jwjknorr is offline   Reply With Quote
Old 05-11-2013, 10:29 PM   #92
AceNiNe
AceNiNe's Avatar
Drives: Scion FRS Raven Black 6MT
yes pls add the pics back!
AceNiNe is offline   Reply With Quote
Old 05-14-2013, 03:00 PM   #93
636
636's Avatar
Drives: '23 CWP BRZ
Pictures are broken
636 is offline   Reply With Quote
Old 05-15-2013, 01:36 PM   #94
sw20kosh
Drives: 2013 Black FR-S
So sorry guys! I will add them back. I had no idea they were broken.
As far as water getting in. USE COPIOUS AMOUNTS of silicon sealant the first time you re-seal it (after you are done re-assembling it). If there is even the slightest hole...you will get water vapor condensing in there.
Old 05-17-2013, 02:47 PM   #95
aqua8701
jAmoMz!
aqua8701's Avatar
Drives: 2013 DGM Limited BRZ
bump, they still aren't back yet
"...And if they got a problem with it, tell them I said it!"
http://www.ft86club.com/forums/showthread.php?t=35563
aqua8701 is offline   Reply With Quote
Old 05-22-2013, 12:33 AM   #96
sw20kosh
pics are back @FOO-GT86
Old 05-22-2013, 10:31 AM   #97
FOO-GT86
Drives: 2013 Argento FRS
Thank you! its a huge help!
2013 Firestorm FR-S : [TOTALED] TRD Exhaust | Zeta Silicone Intake Pipe | TRD Highflow Drop-In Filter | LED DRL| SwitchBack Front Signal Lights | Custom 86 Wheel CenterCaps
2013 Argento FR-S : Quad Tip J2 Exhaust | VIS AMS CF Hood | Nitto Neogen Tires | Perrin lightweight crank pulley | Winjet taillights | 6k HIDs | SwitchBack Front Signal Lights
FOO-GT86 is offline   Reply With Quote
Old 12-25-2013, 04:56 PM   #98
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I wanna do this but I'm way too chickenshit to cut the lights apart. I guess I'm just gonna stick to redding my out...
hmong337 is offline   Reply With Quote
Smoking or Redding BRZ/FR-S Tail Lights DarrenDriven DIY (Do-It-Yourself) Guides 596 02-20-2021 10:11 PM
Black Housing Tail Lights (FR-S) sw20kosh Cosmetic Modification (Interior/Exterior/Lighting) 20 04-13-2016 11:38 PM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
opening tail lights? JollyJON Cosmetic Modification (Interior/Exterior/Lighting) 34 07-23-2012 04:35 PM
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 09:02 AM
