Old 04-27-2013, 06:16 PM   #113
Dezoris
Dezoris's Avatar
Originally Posted by Halcyon Whisper View Post
Just a quick snap of my rig. Soz lazy iphone photos
Looks to be the optimal mounting location for dual cans.
Old 04-27-2013, 11:56 PM   #114
Foobar
SLO NO MO
Foobar's Avatar
Thinking of doing the dual can setup. Anyone know which barbs I should get for that? Two .425 and two .550?
Sent from my Nexus 4 using Tapatalk 2
Old 04-28-2013, 08:48 AM   #115
Foobar
SLO NO MO
Foobar's Avatar
By the way, I just checked with Radium regarding their group buy offer and they are willing to apply it to their dual can as well.
Old 04-28-2013, 11:09 PM   #116
Halcyon Whisper
Drives: GTS86 Man - Pegasus White (soon)
Well bugger me. Would have saved a bit if I waited.
Dual can barbs:
To breather crankcase - 1x 1/2 inch 90 degree
To pcv valve - 1x 3/8 inch 90 degree
To intake tube+manifold - 2x 1/2 inch straight (green barbs as above)
Halcyon Whisper is offline   Reply With Quote
The Following User Says Thank You to Halcyon Whisper For This Useful Post:
Foobar (04-29-2013)
Old 05-02-2013, 11:14 AM   #117
Pug
Atoning Unifex
Pug's Avatar
Drives: '13 BRZ Premium, WR Blue
As many have noted, the fittings and adapters that Radium sells with their catch cans are very expensive (they're also great quality, but still expensive). After some trial and error, I think I've worked out what would be needed to install a Radium can and not buy the fittings from Radium.
Male -10 AN to hose barb this one is a bit hard to find, this is the only model I came across. Used to connect the catch can outlet to the intake manifold.
Male -10 AN to Male -6 AN Reducer used to connect a Female -6 AN to hose barb 90 degree adapter These two are much easier to find at various online retailers. The -6 AN size matches up well with 3/8ths hoses.
The total cost of these items at this particular vendor is $21.15 + shipping, so far they're the cheapest source of these parts, but most places will be less expensive than Radium.
Of course, you'll also need 3/8ths and 5/8ths hose (or -6AN and -10AN if you can find push-fit hoses sold in AN sizing). A hose clamp is definitely needed to secure the 5/8ths hose to the intake manifold. I would recommend using a hose clamp on all connections, just to be safe. Also optional are AN fitting O-rings. (Radium includes these)
Hopefully this can help save some money on future catch can installs!
I just got my purchase link from Radium. Would picking up a 3 ft -10 AN and a 3 ft -6 AN hose be good lengths to pick up for the install?
Pug is offline   Reply With Quote
Old 05-02-2013, 11:53 AM   #118
Toxic78
Toxic78's Avatar
Drives: BRZ - Dark Grey
I searched the GB thread but didn't see anything. Where is this group buy offer?
Toxic78 is offline   Reply With Quote
Old 05-02-2013, 12:07 PM   #119
Foobar
SLO NO MO
Foobar's Avatar
Expired yesterday.
Old 05-02-2013, 12:09 PM   #120
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
Still waiting on car specific kit as well @Dezoris
Old 05-02-2013, 11:36 PM   #121
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
3ft of each type should be more than enough for any mounting setup. I would recommend making sure the hose you get is meant for installation on barb connectors, most AN hoses are meant to be installed on traditional AN hose ends. Plus, the barb-type hoses are cheaper. -6 AN Push-Lok and -10 AN Push-Lok.
P.S. Why are so many online parts sites terrible to navigate?
The Following User Says Thank You to Ninjin For This Useful Post:
Pug (05-03-2013)
Old 05-04-2013, 02:34 PM   #122
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Yeah, 3' is way more than enough (with the right fittings and orientation) - longest run on my setup is less than 2'.
When it comes to buying good quality stuff (hoses, fittings, racing supplies, etc..), Pegasus Racing is my go-to source...
https://www.pegasusautoracing.com/home.asp
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 05-20-2013, 10:39 PM   #123
Dezoris
Dezoris's Avatar
Have the dual can mounted for supercharger, will post up picks soon.
The Following User Says Thank You to Dezoris For This Useful Post:
norsamerican (05-21-2013)
Old 05-21-2013, 05:12 PM   #124
Hanakuso
Here's my mount design. Looks like @Vracer111 and I were thinking much along the same lines. This is extremely solid and has a very clean look.
I'm including all the measurements. Mine was done on a mill, but if you're handy with a drillpress it could easily be done that way.
The holes that the Radium bracket mounts to are tapped for 1/4" 20 screws, but they could be drilled the same size as the other holes and nuts could be used.
Parts:
-1/8" Aluminum Plate (cut to 2.5" x 4.5")
-7/8" Vibration Damping U-Bolts (McMaster Carr PN: 3176T45 http://www.mcmaster.com/#u-bolts/=m6ivb8) x2
-1/4" 20 x 1/2" Screws x3
-1/4" Lock Washers x3
I suggest getting the right angle outlet for the catch can. I used the straight outlet and had to angle the the can very slightly so the hose could clear the top of the battery. I'll probably switch at some point but it works for now.
Hey, just to confirm the correct Vibration Damping U-bolt is 7/8? Would you think 1" is a better fit?
Hanakuso is offline   Reply With Quote
Old 05-21-2013, 05:38 PM   #125
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Nope, it's 7/8". These are pretty speciffic fit, and a 1" will be way to loose.
The Following User Says Thank You to neutron256 For This Useful Post:
Hanakuso (05-21-2013)
Old 05-21-2013, 05:43 PM   #126
Hanakuso
Thanks for the confirmation. 13/16 Would be too small? I'm planning on making one but I will only be using 1 U-bolt, so it will need to be 100% snug.
2013 FR-S Product Technical Info and Specs (from Las Vegas press event) ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 53 07-19-2021 05:59 PM
Fifth Gear reviews the GT86 (Full Video) lazyluka Scion FR-S / Toyota 86 GT86 General Forum 20 10-10-2012 06:09 AM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
Full Specs and Info on GREDDY SCION FR-S vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 109 01-02-2012 11:11 PM
