Old 04-30-2013, 10:17 PM   #43
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Shit I hit over 7psi with my Full Blown kit right out of the box. I'm sure you hit boost cut then.
if i did.
what do i have to do
Old 04-30-2013, 10:20 PM   #44
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by whitefrs View Post
if i did.
Either get John to get you a map with a 9 psi or so boost cut or remove your wastegate and change the springs inside to a lower wastegate pressure. If you only want to run 7 psi, then you should run just the red spring in your wastegate for a pressure of 5.6 psi.
Old 04-30-2013, 10:22 PM   #45
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
you are a big help man
im still gonna take it to the shop so they can check any leaks but towing companies wat 700 bucks
Old 04-30-2013, 10:24 PM   #46
King Tut
NASA SpecE30 Racer
King Tut's Avatar
If you are still worried and the AFR is fine outside of boost, then just drive the car to the shop. Make sure you never go more than 40% throttle and let off if you feel you are building any boost. If you are just hitting an EcuTek boost cut, then you won't hurt the car even if you boost.
Old 04-30-2013, 10:25 PM   #47
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Do you have AAA?
86_ZN6 is offline   Reply With Quote
Old 04-30-2013, 10:26 PM   #48
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
AFR outside boost is 12-14
what i can do is shit from 2.5 to 3k so i dont build boost
Old 04-30-2013, 10:35 PM   #49
King Tut
NASA SpecE30 Racer
King Tut's Avatar
No need to shit for 500 RPM.
Old 04-30-2013, 10:38 PM   #50
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Originally Posted by 86_ZN6 View Post
Do you have AAA?
nop how much will it cost to sign up?
Old 04-30-2013, 10:49 PM   #51
FullBlown
FullBlown's Avatar
Drives: Scion FRS
It does sound like a boost leak. You would be fine driving it back to RAD as long as you stay out of boost , which is still possible.
FullBlown is offline   Reply With Quote
Old 04-30-2013, 10:58 PM   #52
sw20kosh
Drives: 2013 Black FR-S
1. Check your couplings and intercooler piping and vacuum lines. Make sure everything is tight and secure. Since this is your first turbo car...you don't realize how often couplers and lines blow off. lol Every time something was wrong with my mr2 I was like "another boost leak, gotta check my couplers and lines again".
2. If you cant find anything and your car cruises around normally then just drive it there without getting into boost.
Old 04-30-2013, 11:11 PM   #53
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Yea Id check every coupling, hoses and etc.
Hope you find it man, so you can enjoy your car, and keep us posted.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 05-01-2013, 01:22 AM   #54
FA20Club.com
Drives: 2013 White Out FR-S
Originally Posted by sw20kosh View Post
Sounds like a classic boost leak. You are probably leaking metered air causing a rich afr.
Don't know about the clutch issue...
fbm kit is similar to ours and its a blow maf through so it wouldnt matter if he had a leak
FA20Club.com is offline   Reply With Quote
Old 05-01-2013, 01:30 AM   #55
FA20Club.com
Honestly you need a ecutek cable IMHO none of the turbo owners out there should be without a cable. this would have helped solve your issues on day one. if your rpms drop back down then resumes when this occurs seems more like a boost cut. shoot John an email if you havent already and see if he an help you.
Old 05-01-2013, 01:37 AM   #56
ft_sjo
Drives: GT86
It would if the leak was after the MAF sensor.
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
No CEL problems here BRZranger Issues | Warranty | Recalls / TSB 41 12-08-2012 01:36 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
