#673 |
What difference do you feel with the differential bushings?
#674 |
Conedancer
Drives: 2013 Subaru BRZ SWP
Its hard to say as the whole package:
Motor mounts. Trans insert.. Front Bar/bushings, Steering Rack bushings, Control arm Bushings, Subframe Bushings, and Rear Diff Bushings makes the car feel more solid and connected all the way around.. I could tell my launches were better...no wheel hope and minimal spin. so I think it hooked up alot better and way more smooth.. Turn-in is instantaneous.. Car goes where its pointed...no questions.. Steering is almost to sensative..to a point that if your not used to it, will easily make you overdrive the car.. once your used to it.. it drives sooooo easy that I was ahead soooo far on course that I went Conefree all day yesterday except my last run.. which I don't recall hitting any cones..so I might have just nicked one somewhere.. but as a whole.. Car is SOLID and completely connected.. if that makes sense.. Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
| The Following User Says Thank You to Scooby South For This Useful Post: | civicdrivr (04-29-2013) |
#675 | |
i'm sorry, what?
Drives: Canada
what product did you use for the engine mounts?
#676 |
Conedancer
^^^ cusco engine mounts
Bill
#677 |
i'm sorry, what?
Drives: Canada
sweet, didn't know they were finally out.
you also mention that oyu have the transmission insert, would you switch to a similar cusco/beatrush "cage" design if it came out or if it's already out or do you feel the insert is more than enough to get the job done?
#678 | |
Conedancer
![]() Bill
#679 |
Conedancer
One of my runs from yesterday..car took 1-2 in class and 7th and 10th out of 120 on index..
Giddyup[ame]http://youtu.be/Nz4uoEOUdpo[/ame]
#680 |
Drives: '13 BRZ in WRB--let's mod!!!
Were you ever able to even out the rear camber w/o aftermarket LC arms?
#681 |
Conedancer
yes...
no problem now.. -2.0 lowered the rear ..
#682 |
Conedancer
And my INCAR of me doing Work..
enjoy[ame]http://youtu.be/c6PyGKN8soU[/ame]
#683 |
A man on a mission!
#684 |
Conedancer
#685 |
__(X)__
Drives: '11 Legacy, '89 190E, '78 GS1000
What exhaust do you have on your car?
IG: @dustin_faulkner
#686 |
| Subaru/Scion warranty and autocross | Ribface | Tracking / Autocross / HPDE / Drifting | 55 | 06-17-2015 08:30 PM |
| Will you Autocross your 86? | Ribface | Tracking / Autocross / HPDE / Drifting | 131 | 06-22-2012 05:48 PM |
| Which autocross class? | jpdarty7 | Tracking / Autocross / HPDE / Drifting | 66 | 06-21-2012 05:53 PM |
| FR-S at a CA Autocross | oneday | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 03-26-2012 03:38 PM |
