Old 04-27-2013, 08:02 PM   #253
slowbrz
Drives: '13 black BRZ MT
Originally Posted by Koji_Online View Post
Heya, you have to use your other hand to put pressure on the face of the pedal while you screw it in with your other hand; this relieves the pressure from the threads & will get you unstuck =p
You are going to be threading into the pedal & away from the firewall, in order to bring the grab point closer to the floor.
Ive tried threading while pushing down on the clutch pedal with my other hand but it didnt help at all
slowbrz is offline   Reply With Quote
Old 04-27-2013, 09:24 PM   #254
TM
TM's Avatar
Drives: DGM BRZ 6MT
I had to pulsate my clutch petal in order to turn the rod. It only turned as I press down on the petal, so I kept pressing and releasing as I turned the rod.
I think I hear a metal rattling sound now at low RPM (<1.5k). Does anyone have any ideas what it could be?
Edit: I meant between 1.5 and 2k.
TM is offline   Reply With Quote
Old 04-28-2013, 11:40 AM   #255
HunterGreene
Hail Magnet
HunterGreene's Avatar
Is the sound coming from inside the cabin or outside the firewall? Did you re-tighten the nuts after adjustment? How far down did you adjust the clutch pedal?
Old 04-28-2013, 02:53 PM   #256
slowbrz
I can try it again but I did it several times yesterday with no luck. It doesnt help that I can get a firm grip with all of that grease either.
Is there a tool like a plier that I can use to get a firmer grip?
Old 04-28-2013, 03:49 PM   #257
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Plier will work on the non-threaded section of the pipe.
I had adjusted my clutch grab lower while stock and had to readjust it up yesterday after installing FX300 clutch. It was basically grabbing exactly as soon as I lifted the foot off the floor.
Old 04-28-2013, 06:23 PM   #258
TM
TM's Avatar
Drives: DGM BRZ 6MT
Not sure where it's coming from. I think it went away. I adjusted the clutch about the same height or slightly lower than the brake petal. I "think" it might be from the elbow area where the grease is, but I'm not sure. I just pushed it to one side and I don't think I hear it anymore.
Old 04-29-2013, 12:35 AM   #259
stockysnail
Just the tip
stockysnail's Avatar
I did this tonight since I didn't have anything going on. I was weary on doing this as I figured my clutch was fine even though I didn't care for the long travel. All I have to say is after driving to the grocery store after doing this (mine is just below brake pedal height), my shifting is much smoother. I'm not jerking my head anymore from all the pedal travel and trying to catch the clutch grab point. Now with the pedal closer to the floor with less travel, my shifts are much smoother and I'm sure passengers will appreciate my driving more now. Thank you for his mod. It's one of my favorites, plus it's free if you have a 12mm and 14mm wrench.
Definitely telling all the PDX area guys and adding it to my build thread.
Old 04-29-2013, 01:56 PM   #260
Sgt.Beardface
OMOH O2
Drives: Midget Women Crazy!!
Just did this in the garage. Went even with the brake and all I can say is wow. Got rid of my one complaint about the car. After a test drive I can honestly say that the OP was correct. Ever so slightly below the brake is damn near perfect. I took it out and put it through the paces. I look at all adjustments like a penis tho. When your done messing with it ya gotta take it out and beat on it for a few. Thanks for the info on this!!
-Chuck
You don't need a parachute to skydive; you only need a parachute to skydive twice.
I calls her Mrs. Lohan LIKE A SIR!!
Sgt.Beardface is offline   Reply With Quote
The Following User Says Thank You to Sgt.Beardface For This Useful Post:
Sensisnow (04-29-2013)
Old 05-01-2013, 09:49 AM   #261
Mikem53
Drives: FR-S 6MT
I haven't done this mod yet... My car isn't a week old yet and I'm still getting used to it.. One thing concerns me.. There needs to be some free play in the pedal as it is adjusted from the factory.. Otherwise the throw out bearing is engaged which will cause premature wear..
Just as you are not supposed to put your foot lightly on the clutch say when your at a light in neutral... Cause that slight pressure causes wear on the throw out bearing.. So if you are taking up slack by this adjustment .. You might be actually causing the throw out bearing to be engaged..
Again.. I don't know the "feel" or have any hands on with this car... Just know how it works and what could be happening if adjusted incorrectly..
Mikem53 is offline   Reply With Quote
Old 05-01-2013, 11:55 AM   #262
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
When you adjust the clutch pedal, you're also adjusting the engagement point. This will have no effect on the throw out bearing if done right.
You'll see in the procedure that you'll have to do this in order to raise or lower the clutch pedal anyway.
CamryDS is offline   Reply With Quote
Old 05-01-2013, 07:52 PM   #263
Mikem53
Drives: FR-S 6MT
I just did this mod.. Took literally 10 minutes..
I got the clutch pedal level with the brake pedal..
There is enough clutch play to where taking up the slack will
Not affect pressure on the clutch assembly. It grabs lower now
And is a bit easier to drive smoothly.. Like others have stated..
Thanks to the OP for getting this started and for the write up and vid.
I also referenced the manual available on here before I started..
My first mod within 5 days of ownership.
Old 05-04-2013, 12:09 AM   #264
djdnz
1337
Drives: 2013 BRZ WRB S/C
After you unscrew the nut with the 12mm wrench, make sure you unscrew it even further by hand. When you adjust the rod, you end up moving the nut back towards the bracket, effectively tightening it up again. If you back it off by hand by a generous amount, you should be able to twist the rod with some pulsing of the clutch pedal.
Thanks Koji, and Jon Harrington for your video on youtube. I played with the position of mine, I ended up adjusting it 4 times before I found my personal sweet spot. At first I set it a bit under the brake pedal (~3-4mm), but found it strange that the throw of the clutch was so short. Then I moved it too far above the brake, then set it to even with the brake, and finally settled on just a hair under the brake pedal. Feels very natural now, and I don't tend to over-rev at stops.
djdnz is offline   Reply With Quote
The Following 3 Users Say Thank You to djdnz For This Useful Post:
jcw99 (09-11-2015), JonnyRocket (05-04-2013), slowbrz (05-04-2013)
Old 05-05-2013, 01:49 AM   #265
canon_spec
Drives: FT86 GTS
Took a lot longer than 10 mins but man was it worth it.
I have mine sitting just a few mm above the brake pedal.
A tip for the RHD drivers out there. There is a white plastic/rubber stopper that gets in the way of the 12mm nut. To make it easy, pinch the back of the stopper and pop it off. That way you have enough space to loosen or tighten the nut.
canon_spec is offline   Reply With Quote
The Following User Says Thank You to canon_spec For This Useful Post:
manonastick (03-04-2014)
Old 05-06-2013, 10:31 AM   #266
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
As a noob,
Can we get a video of the adjustment? I cant visualize the way to do it properly =(
Thanks!!
Chinadian is offline   Reply With Quote
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
