#71 |
Drives: A Potential Traffic Ticket
I just want to try them out.
#73 |
and also reduce added stack hieght? correct me if im wrong...
#74 |
Drives: Some rust bucket
R2 coilovers installed. Good thing I raised the lower perches a couple inches before lowering the car, lol.
What's the best method to accurately lower the car on all 4 corners? I honestly don't want to go that low. Maybe 0.5''-1'' at most. Paging @Dave-ROR |
#75 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | ayau (04-28-2013) |
#76 |
Did someone have the OEM height measurement so I know how much I've dropped from the OEM height? I forgot to measure before removing the OEM suspension, lol.
#77 |
#78 | |
http://www.ft86club.com/forums/showthread.php?t=30129 |
#79 |
I have the car lowered about 0.5" all around (rough estimate). I'll keep it at that until I get can get an alignment this week. The final ride height will be pretty much dependent on how much camber is in the back, eg., raise ride height to decrease camber, and lower ride height to increase camber.
Some first impressions: Ride quality is VERY compliant for my tastes, and I'm on 500/650 springs. I drove on some rough roads and my butt says that it's only about 35% more harsh than OEM. There's very little dive when I brake hard. This is probably caused by a couple of things though. The tires weren't fully warmed up (Dunlop DII), and XP10 pads lock up the rotors very quickly even when they're cold. |
#80 | |
Drives: Attitude
#81 | |
Site Moderator
Drives: Stuff
I lowered the car about 10mm or so... a little less up front, need to corner balance it eventually. These dampers don't have as much rear bump as I would like, the rear dampers are about halfway from fall droop to bumpstops currently.
-Dave
#82 |
Site Moderator
Drives: Stuff
It will. Tires, tire pressure, car, etc.
-Dave
#83 | |
There's an autox event next week and I'll be able to more fine tune it there and with some help of some local S2k guys. One of them runs Motons, so he knows a thing or two about adjusting shocks, lol. How much are you lowered? Have you had a chance to check how much camber you got in the rear? Edit: just saw your edit for the ride height. |
#84 |
@Dave-ROR, what do you mean by this statement?
"These dampers don't have as much rear bump as I would like, the rear dampers are about halfway from fall droop to bumpstops currently." You mean there's not enough bump compression, or there's not enough bump travel? |
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 06:30 AM |
| Eibach Multi-Pro R2 Coilover Review | donutfilling | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 254 | 05-08-2016 11:56 AM |
| Eibach Multipro R1 and front and rear sway bar installed | Pekingduck | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 43 | 12-30-2013 10:59 AM |
| ***Time to freak out, Eibach coilover pricing available**** | JoeBoxer | Brakes, Suspension, Chassis | 154 | 05-16-2013 05:30 PM |
| Eibach Coilover Options - SEMA 2012 Coverage | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 01-25-2013 07:19 AM |
