Old 04-26-2013, 09:46 PM   #15
TSY
TSY's Avatar
Drives: 2013 BRZ Limited SWP
Originally Posted by wparsons View Post
This! Scrub radius can make a big difference in feel.
I'm running 225/45 Z2's on 17x8 +45 (which is pretty close to the stock scrub radius) and the feel is just a tiny bit heavier most of the time, but it tramlines (follows grooves in the pavement) WAY more now. If you drive on roads that see a lot of heavy vehicles, you'll quickly find the grooves where they stick to. It's not annoying or an issue, but you will notice it.
I find different tires themselves tramline more than others. It may just be the Z2's like to tramline?
I'm leaning towards going with 225s too.
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX
TSY is offline   Reply With Quote
Old 04-26-2013, 10:11 PM   #16
jshadeck
jshadeck's Avatar
Yes. The manufacturers know what theyre doing. Thats why when they built a track car they went to 18x9.5 with 250 tires with stock HP
http://www.speedhunters.com/2013/02/...ned-eight-six/
jshadeck is offline   Reply With Quote
The Following 5 Users Say Thank You to jshadeck For This Useful Post:
Ammonia (07-27-2013), jflogerzi (04-27-2013), rennlistuser3 (02-27-2021), sobrz (08-07-2017), TSY (04-27-2013)
Old 04-26-2013, 11:06 PM   #17
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Originally Posted by DarkSunrise View Post
I immediately noticed more steering feel switching from the stock setup to 215 width max-performance summer tires on lighter 8" wheels in +45. Really happy about that. The only downside is the tires look a little stretched.
Whether the increase in steering feel comes from switching to sportier tires, lighter wheels, or slight stretch, I don't know, but I bet tires is the major contributor.
I have the stock Primacy HP's mounted on 17x7.5 Enkei Fujin's with +40mm offset and have noticed an improved steering response with a very slight increase in steering feel. Most noticeable though is the improved ride quality due to dropping ~3.5 lbs a corner... grip is also better than with the heavier and narrower stock wheels. Tire construction is probably the biggest contributor to steering/road feel, while mounting the tire to the widest recommended wheel width has more contribution to car responsiveness than road feel. Dropping unsprung weight mostly goes to improving the ride quality and secondarily handling responsiveness.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
Old 04-26-2013, 11:49 PM   #18
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
I have 17x8 +35 Rota Grids with 245/40/17 Z2 Star Specs that shipped out today. We shall see how they feel in a few days
RazBRZ is offline   Reply With Quote
Old 04-27-2013, 02:06 AM   #19
MaDBaRMaN
MaDBaRMaN's Avatar
Drives: 2013 Toyota 86 GTS w/ Aero Kit
I have gone 20x9.5" all round on 245 rubber, I'm not feeling any significant loss in steering feel or functionality. If anything I find the wider rubber holds the road slightly better and results in less tail happy corners, this may also be due to the extra work the engine is doing to spin them :/
MaDBaRMaN is offline   Reply With Quote
Old 04-27-2013, 07:55 AM   #20
DarkSunrise
DarkSunrise's Avatar
Yep that makes sense. The car feels so good right now in terms of steering feel and response that I'm hesitant to switch to 235/40/17 later. Might compromise and go with 225's.
2022 BRZ Build
2013 FR-S Build
Old 04-27-2013, 03:41 PM   #21
Vracer111
Vracer111's Avatar
I'm actually planning on going with smaller yet larger Max performance tires when it's time to replace the Primacy HP's...205/45-17 Kumho Ecsta LE Sports specifically. Smaller diameter but wider than stock tread width. Not to mention ~$80 a tire for an upgrade to the stock tires (a tiny handling upgrade in the dry but massive wet handling upgrade. Only trade is tire life is shorter than Michelins and not as good in really cold weather (fortunately I don't have to worry about really cold weather...), I can live with that for way less than half the price of Michelins...full set of high quality Max Performance tires for under $300 (they qualify for a $50 rebate...)!
Old 04-27-2013, 04:07 PM   #22
mrk1
Drives: Sterling BRZ Ltd
Width of the tire won't make to much of a difference, power steering is pretty strong. A difference can be felt if you run really drastic changes in offset like to fit a wide body. That's when you start messing with the scrub radius and have to push the tires rather then pivot.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-27-2013, 04:56 PM   #23
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Originally Posted by mrk1 View Post
Width of the tire won't make to much of a difference, power steering is pretty strong. A difference can be felt if you run really drastic changes in offset like to fit a wide body...
Wait...have you, or have you not experienced different-width tires ON THIS CAR?
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 04-28-2013, 12:09 AM   #24
TSY
TSY's Avatar
those wheels must be heavy! your sectional width must be smaller as well which will affect handling too.
Old 04-29-2013, 12:04 PM   #25
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
225's increases the diameter too much IMO? 215 or 235(or 245) for stock diameter.
My dilema is stock 215/45-17 in Mich PSS, or get 235/40-17 in Falken FK-453 (lot less options in this size). I don't like the stretch look much, but value the razor steering feel more. Other threads have said I won't really be able to tell the different under 9/10 driving anyway.
Khyron686 is offline   Reply With Quote
Old 04-29-2013, 01:24 PM   #26
wparsons
wparsons's Avatar
225/45 is 0.3" (7.62mm) taller than stock (25" vs 24.7"), and doesn't effect the speed readout (compared to GPS) at all.
235/40 is actually exactly the same difference in diameter (24.4"), just in the opposite direction. 245/40/17 is an exact match, but the differences between stock and either 225/45 or 235/40 are very small.
You'll feel the difference in feel at all speeds, but as with all cars feedback is more apparent closer to the limit because the tires will be moving around more.
flickr
Old 04-29-2013, 03:37 PM   #27
DarkSunrise
Yeah that was my reason for wanting to switch to 235/40/17 -- any shortening of the stock gearing is good IMO, but in all honesty, the difference in acceleration would probably be minimal as wparsons pointed out.
Then consider how the selection and price in 225/45/17 is much better, and that size starts to look really appealing. Also I haven't run into the rev limiter yet in autocrossing, but some people say slightly longer gearing helps you stay in 2nd on some courses. Hmm...
2022 BRZ Build
2013 FR-S Build
Old 04-30-2013, 05:28 AM   #28
MaDBaRMaN
MaDBaRMaN's Avatar
The 20's are actually 2kg lighter per wheel than the factory rims, gotta love the light weight hollow spoke GTR racing rims.
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 08:14 PM
Best Tire for Steering Feel Khyron686 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 03-12-2013 12:01 PM
What would make the rear tires look wider?? Razor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 02-18-2013 11:16 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 11:16 AM
