Old 04-20-2013, 08:10 PM   #2465
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Originally Posted by normanb21 View Post
I had an 2005 subaru sti stage 2 with custom tune. It made 271whp and 371wtq. The torque peaked at 2800rpm and dropped off from there. How would the frs with this stage one turbo compare to my sti?
Are you not capable of reading the dyno charts in this thread?
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 04-20-2013, 08:54 PM   #2466
GeekB
Drives: 2013 BRZ Limited
Are any of you who put a deposit/preorder down for the March shipment still waiting for their kit?
GeekB is offline   Reply With Quote
Old 04-20-2013, 10:05 PM   #2467
sw20kosh
Drives: 2013 Black FR-S
Compare the high rpms of the two cars and factor in weight.
Even though your STi has huge torque in the low end, it falls off drastically. This matters because in high performance driving you are never in the low rpms. Whatever that driving may be. If your torque levels are similar in the higher rpms (which it looks like it based on your HP number) then the FRS in a simplistic test will be faster due to its weight advantage.
Also a turbo that small that gets exhausted in the higher RPMs will be blowing so much hot air into the motor. This over time (like a few laps) can reduce power. Heat soak is a concern.
Old 04-21-2013, 12:36 PM   #2468
AVOturboworld
Originally Posted by dabocx View Post
350-400whp?
If you know you can always be running on e85 - always - a 12psi actuator would probably be the way to go. I would personally suggest a 9psi actuator, so that if/when you need to run on pump gas, you can dial it back down to the safe range (9~10psi).
With the 9psi, you can run it up to 18psi with a good boost solenoid, which would allow you to hit your power goals.
Old 04-21-2013, 09:59 PM   #2469
normanb21
Drives: black frs
No speaka englishia
normanb21 is offline   Reply With Quote
Old 04-22-2013, 07:04 AM   #2470
vinnie86gt
Drives: Pearl White 86 GTS
Is there room for the avo kits to upgrade the turbo? Say I wanted to put a gtx2867r or maybe a precision turbo on later on??
vinnie86gt is offline   Reply With Quote
Old 04-22-2013, 11:26 AM   #2471
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Yes.
gdrider77 is offline   Reply With Quote
Old 04-22-2013, 01:18 PM   #2472
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Originally Posted by gdrider77 View Post
Yes.
and YES (prepaid on 02 Dec)
MSTiFK8R is offline   Reply With Quote
Old 04-22-2013, 02:20 PM   #2473
AVOturboworld
I do apologize for the wait - we will be shipping all those kits out this week and next.
Old 04-23-2013, 01:18 AM   #2474
dabocx
dabocx's Avatar
Drives: Scion FRS
Finally put a deposit on my kit with a 7psi acu. Now for the long wait till june, and to buy fuel pump/injectors/clutch and a boost/afr gauge!
dabocx is offline   Reply With Quote
Old 04-26-2013, 08:17 PM   #2475
ChristosG
Drives: 2013 Scion FR-S Hot Lava 6MT
So this kit is designed to work with the stock airbox but can it work with TRD air intake?
ChristosG is offline   Reply With Quote
Old 04-26-2013, 08:28 PM   #2476
AVOturboworld
No, it won't work with the TRD intake, not without some sort of modifications. The TRD intake outlet points straight back towards the intake manifold, instead of towards the side where our inlet is.
Old 04-26-2013, 08:52 PM   #2477
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
No, but it does work with the Perrin CAI
Old 04-26-2013, 09:00 PM   #2478
ChristosG
I guess I'll have to hang on to the stock one then for when I eventually get this kit.
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
