Old 04-15-2013, 09:06 PM   #1
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
redlinegoods shift boot and ebrake boot
Figured id be the guinea pig and take a shot on the redlinegoods boots. I had them custom ordered in solid black real italian leather with a solid red leather stripe up the middle and red stitching. They were $100 shipped for both so i figured it was worth giving a try. They arrived today and look beautiful. The shift boot has the holes cut at the bottom which should hopefully be lined up with the tabs on the bezel for a quick installation. The ebrake boot i'll have to do some work on and pull apart the original/glue the new one down but it looks damn nice and matches perfect. Arrived here in NY from Poland approximately 2 weeks after ordering. Not bad at all.
UPDATED - new pics
abutterman is offline   Reply With Quote
The Following 3 Users Say Thank You to abutterman For This Useful Post:
Axis2011KR (04-17-2019), BR-ZED (03-25-2022), mezdup (04-20-2013)
Old 04-15-2013, 09:59 PM   #2
dflood75
dflood75's Avatar
Drives: FR-S Asphalt & FJ-Cruiser Voodoo
Looks good. Hurry and install em so we can get a full review!
dflood75 is offline   Reply With Quote
The Following User Says Thank You to dflood75 For This Useful Post:
abutterman (04-16-2013)
Old 04-15-2013, 10:11 PM   #3
abutterman
abutterman's Avatar
shift boot should be easy enough to get on tomorrow afternoon as long as everything lines up and fits properly. i'm gonna swap my oem red stitch ebrake boot with @mezdup and take his plain black one since i'll just be ripping the fabric off the plastic anyway but hopefully that'll be done within the week or so.
Old 04-16-2013, 12:36 PM   #4
abutterman
abutterman's Avatar
Just installed the shift boot. Pictures are up on the first post. The fit is perfect and looks beautiful. Clips right on to the stock hooks as shown with a nice tight fit so it doesn't move around. the top where it slides over the reverse lockout has 2 small notches cut in the back side to it can slip over yet still remains snug and in place. Its slightly more bunched up at the bottom than stock but it's also real leather so it'll probably settle down and sink in a bit over time but it's not too bunched up that it gets in the way of shifting or anything. I'll see how it holds up as far as stretching and whatnot over time but as of now i think it was well worth the $50 shipped. Ebrake boot should hopefully be ready to go by the weekend
Old 04-17-2013, 02:44 PM   #5
abutterman
abutterman's Avatar
looks like i made the website too http://www.redlinegoods.com/BRZshiftboot.php
Old 04-17-2013, 03:22 PM   #6
Derik210
That Army Guy
Derik210's Avatar
Drives: Firestorm FR-S MT
im loving that dash cover
Firestorm FR-S MT
HIDs, black and red headlights, perrin crank pulley, black and red emblems. Instagram Username- derik210
Derik210 is offline   Reply With Quote
Old 04-17-2013, 03:24 PM   #7
s2d4
s2d4's Avatar
Damn, they turned out a lot better than I thought, not bad at all even if the red stripe may be a bit too much for me.
Will you be ordering the dash pad as well?
Old 04-17-2013, 03:43 PM   #8
abutterman
abutterman's Avatar
I just asked them about the dash pad and apparently its just the material cut to the exact shape and u have to use adhesive to put it on the stock parts but since these came out so nice i might give it a shot. Might skip the stripe though since they say itll probably just go across the middle of the right dash piece
Old 04-17-2013, 03:51 PM   #9
s2d4
s2d4's Avatar
Sounds like a good choice!
Are you getting solid leather for the dash as well? I am getting sick of seeing alcantara for some reason.
Old 04-17-2013, 03:56 PM   #10
abutterman
abutterman's Avatar
Probably solid black with just the red stitching. I was originally thinking perforated so the silver from the stock trim would show through the holes but then i was thinking depending where the adhesive needs to be applied, it might seep through and look bad.
The Following User Says Thank You to abutterman For This Useful Post:
s2d4 (04-17-2013)
Old 04-17-2013, 04:15 PM   #11
Derik210
That Army Guy
Derik210's Avatar
is the brz/frs stiched onto the dash pad?
Firestorm FR-S MT
Old 04-17-2013, 04:21 PM   #12
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
Love the shift boot...when are you installing the e brake boot? For $100, its a steal!! Thanks for the pics, can't wait to see more.
chadstyle is offline   Reply With Quote
Old 04-17-2013, 04:32 PM   #13
abutterman
abutterman's Avatar
should have the ebrake boot installed maybe friday evening or sometime this weekend. the stitching and stripe matches great and it looks to be cut properly as far as i can tell. i don't see there being any issues with it. I'll just have to make a template or something with the original one so i knot where to fold the edges over
Old 04-17-2013, 05:30 PM   #14
abutterman
abutterman's Avatar
anyone know if this [ame="http://www.amazon.com/3M-03609-Scotch-Mount-Molding-Tape/dp/B000BO913C/ref=sr_1_1?ie=UTF8&qid=1366230514&sr=8-1&keywords=3m+automotive+tape"]3M 03609 Scotch-Mount 1/2" x 5' Molding Tape : Amazon.com : Automotive[/ame] will hold leather down to plastic? It would have to stick well to the suede backing. I already have some industrial strength adhesive but if this would work, it might make for a cleaner and more easily reversible installation
Crown Royal Shift Boot Derik210 Cosmetic Modification (Interior/Exterior/Lighting) 30 09-04-2015 06:06 PM
How-to: Install JPM Coachworks 6MT Alcantara or Leather Shift Boot JPM Coachworks DIY (Do-It-Yourself) Guides 22 06-27-2014 12:46 AM
WTB: Red stitched ebrake boot AG3NT_5CARFAC3 Interior Parts (Incl. Lighting) 1 02-28-2013 01:04 AM
WTT: My red stitched ebrake boot Laika Interior Parts (Incl. Lighting) 10 02-09-2013 02:26 AM
Need Subaru BRZ shift Boot djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 0 10-21-2012 05:18 PM
