Old 04-15-2013, 02:02 PM   #393
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Huehuecoyotl View Post
I think I like the raised idle, is my point...
I like it too
Old 04-15-2013, 02:31 PM   #394
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
I just sent a new map out to @tg_1981, there was a bug from Ecutek when changing the maps, it should be fixed now. If anyone else is having this issue, send me an email, and I'll send you out a new map. Thanks!
PERRIN_Chris is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
tg_1981 (04-15-2013)
Old 04-15-2013, 04:14 PM   #395
tg_1981
Just loaded the new tune on the car. Map 3 works ran it up and down the street with a smile on my face.
Tony
tg_1981 is offline   Reply With Quote
The Following User Says Thank You to tg_1981 For This Useful Post:
PERRIN_Mladen (04-15-2013)
Old 04-15-2013, 05:08 PM   #396
reyruiz191
reyruiz191's Avatar
Drives: 2013 FRS Vortech Supercharged
Sent out an email with my first datalog last night on the first map. Wasn't sure if it was ok to run the 3rd map yet or not.
reyruiz191 is offline   Reply With Quote
Old 04-15-2013, 05:38 PM   #397
Calum
That Guy
Drives: 2013 asphalt FRS MT
Did you guys ever post a dyno of the new compressor?
Old 04-15-2013, 07:02 PM   #398
Pete
Pete's Avatar
Drives: 22 BRZ
I hope to this week.
I just got home from work and flashed to the new tune @PERRIN_Jeff sent me. WOW. Not only is my idle raised a bit but also the rough idle issue seems to be a thing of the past. I switched to map 3 on the way out of my neighborhood while I was rolling down the road and it worked with no problem. I gunned it as I pulled on to the main road to merge with traffic and it was perfectly smooth delivery of power(new headers ). When I turned around and headed back towards my house there were no more shudders from my engine mounts when I clutch in, it felt rock solid.
Jeff also told me a trick to get rid of dead pedal after a flash, this might be old news to some:
Turn the key on, give it full throttle then lift about 20 times. Turn it off then do this again (20 full throttles, then turn it off). Now start your car. I bet the gas pedal feels better?
This works perfectly. I flashed, followed those directions, and I had zero dead pedal after the flash.
Very cool Jeff, thanks a ton!
Pete is offline   Reply With Quote
The Following User Says Thank You to Pete For This Useful Post:
Sonolin (04-16-2013)
Old 04-15-2013, 07:08 PM   #399
Foobar
SLO NO MO
Foobar's Avatar
This is without starting the car right? Just put car in the ON position but without actually starting it?
Sent from my Nexus 4 using Tapatalk 2
Old 04-15-2013, 07:09 PM   #400
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Tryin real hard to be patient here @Pete
F1point4 is offline   Reply With Quote
Old 04-15-2013, 07:11 PM   #401
Pete
Pete's Avatar
Drives: 22 BRZ
yes, I just turned the key to "on".
Old 04-15-2013, 07:22 PM   #402
F1point4
Photo Specialist
F1point4's Avatar
And @PERRIN_Chris came through. That's High definition service right there.
The Following User Says Thank You to F1point4 For This Useful Post:
Pete (04-15-2013)
Old 04-15-2013, 07:23 PM   #403
Calum
That Guy
Glad to hear it's working well! I can't wait to see the charted results when you get a chance. And thanks in advance for doing that.
So should be calibrating the pedal voltage after a flash. GOOD TO KNOW as with that info I'd say my pedal's output voltage is a little low.
Old 04-16-2013, 02:29 PM   #404
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
Very interested in your updated dyno's too.
A question to all three of you Houston Vortech early adopters:
You have all driven on the original kit and then were given a bump in power with the updated blower. After driving on the new blower for a while are you considering additional upgrades like E-85 or higher psi, or is the current power sufficient for now? I guess I'm wondering if there is a stopping point where you feel everything is good or is this the beginning of an addiction...
Amadeus is offline   Reply With Quote
Old 04-19-2013, 11:11 PM   #405
Pete
Pete's Avatar
Drives: 22 BRZ
I made 252 hp to the wheels and 201 tq to the wheels. The wireless router was not cooperating so Chris is not yet able to email me my dyno chart, but @F1point4 snapped a pic of the screen so he should post it before too long.
Edit: I should also mention that my rough idle has come back, it was steady for about a day and half after the flash, then started wavering a bit, then started doing the full rough idle thing again within a couple of days. (+200 to -200 from idle back and forth). Sigh. It has been like this since I picked up the car, but there has to be a solution.
Old 04-20-2013, 09:21 AM   #406
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
I think when it comes to mods I'm the most negative person I know.
I never expect to see gains. This attitude ensures that I won't be disappointed.
HOWEVER...
The new blower and new tune.. I can tell the difference.
If Victor doesn't get around to posting his pictures, I'll grab the data and post it up.
Sent from my SCH-I605 using Tapatalk 2
PhastekSport is offline   Reply With Quote
ft86, perrin, phastek, supercharger, vortech
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! Visconti Forced Induction 67 04-03-2013 03:56 PM
Vortech Supercharger Kits @Pure Automotive Performance Pure Automotive Forced Induction 25 01-15-2013 11:48 PM
