#85 |
Drives: 2013BRZ Premium St Silver Metallic
There are several possible reasons for this installation:
1. Experimentation/product development. 2. Practicing speeding in reverse. 3. The owner of the car has minimal driving experience and is trying to 'prove' something to his bimbette girlfriend. 4. Did not follow installation instructions and will soon get a Big Surprise. 5. THe driver also puts his pants on backwards (see post #17) and can hardly walk let alone drive. 6. The drive doesn't know the difference between reverse lift, forward lift, up force/down force, as well as oversteer/understeer, toe-in/toe-out.. |
#86 | |
Drives: 2013 FR-S Ultramarine
![]() And this post pretty much has all the right points. At that AoA it'll likely be producing some lift just from Newton's 3rd law. The air going under the wing is hitting that bottom surface and being deflected downwards (probably) so the wing is going to be pulling up on the trunk Now, with that lip at the front of the wing and that AoA, it's 99% guaranteed flow is separating as soon as it hits the leading [trailing ] edge. So that's going to create a TON of drag.Nathan |
#87 |
Guest
Posts: n/a
If i was the pedestrian, ill will smash that spoiler lol
#88 | |
Drives: FR-S Firestorm 6MT
#89 |
Drives: 2017 Subaru BRZ PP
Sadly, I wouldn't be too surprised if this was part of Scion's new 10 Series FR-S.
"In addition to the illuminated Scion logos in the front, rear, door sills, dashboard, and shift knob, we have now added a reverse spoiler for the ultimate in brand identification - now standard on all 10 Series Scion models." *13 year old Mexican kid claps* Ugh...
Toyota + Subaru =
| The Following User Says Thank You to Bristecom For This Useful Post: | Anthony (08-18-2013) |
#90 |
Drives: 09 Honda Fit MT
I am getting BRZ instead of FR-S because of this car!
#91 |
Drives: Toyota 86 GTS
The biggest problem I have with this is not the fact that it may generate some lift (I doubt it's more than 50 kg at highway speeds) but the potential for decreased rear end stability under braking and cornering. Now that would be dangerous if it makes an already tail happy but balanced car even more likely to fishtail.
#92 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
since we're talking aerospace, thought i'd chime in for fun (my background is in aerospace). without seeing the actual cross section of the wing, i find it hard to draw a conclusion (besides the wing looking like it'll add drag) as to whether it's lifting or pushing down on the back of the car. the wing basically looks like a deep camber airfoil. but put on backwards, i'm not sure what that would actually do.
as for angle of attack, we can't assume that the direction of airflow is the same as the direction of travel of the car, because the air follows the contour of the top of the car and it may actually be hitting the front of the wing without a negative angle of attack. so, performance-wise, i think it's hard to draw a definitive conclusion without more info. but, i think we all agree that the owner probably made a mistake and it looks stupid
#93 |
Poor College Kid
Drives: ~.~
That car must have some crazy aerodynamics now
#94 | |
Novice Drifter
Drives: 2013 Asphalt FR-S
#95 |
Drives: 2013 CBS BRZ Limited
Maybe the instructions were in Japanese?
#97 | |
Drives: A lot of supercars.
6th gear at 151 mph running on NA on e85. Reguardless of it literaly taking about 2 minutes to hit that speed from a dig. |
| The Following User Says Thank You to Carwhisperer For This Useful Post: | ftc~brz (04-14-2013) |
#98 | |
Because Racecar
Drives: 2013 Asphalt FRS
It did not take long at all for this to happen
| The Following User Says Thank You to tuckdaddy For This Useful Post: | ftc~brz (04-14-2013) |
| Giving her what she deserves | 86 Legend | ASIA | 25 | 05-23-2013 01:28 PM |
| noob question. giving thanks? | its_the_biz | Site Announcements / Questions / Issues | 2 | 02-16-2013 05:57 PM |
| Is your FR-S giving you any mechanical problems now? | doctortt | Issues | Warranty | Recalls / TSB | 40 | 01-19-2013 01:06 AM |
| We're giving away 4 Firenza performance tires | SCIONMONTREAL | CANADA | 13 | 01-18-2013 06:41 PM |
| The color choice is giving me migraines. | pastuch | CANADA | 8 | 05-11-2012 09:36 AM |
