Old 01-24-2013, 07:12 AM   #57
jmh
jmh's Avatar
Drives: 86 GTS
Originally Posted by Paragon View Post
Holy shit never knew they came in that size. Where are you getting it from and do they do 17x8 +35?
I'm getting them from autotechnik. I just looked up the sizes on the enkei site and ask them to bring them in. The design is slightly different depending on the width of the rim, the 9"+ rims are the ones with the really flat face.
http://www.enkei.com/size_chart/RPF1.pdf
jmh is offline   Reply With Quote
Old 01-25-2013, 11:29 AM   #58
ayetothejay
ayetothejay's Avatar
@Stance86 meaning to ask you? do you get any rubbing on your front tires when you go through bumps, etc? seems there's little clearance between your front tires and the fenders.
ayetothejay is offline   Reply With Quote
The Following User Says Thank You to ayetothejay For This Useful Post:
Frsexxxy (03-30-2013)
Old 01-25-2013, 04:18 PM   #59
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
9.5 inches wide, does the car not feel slower? no one ever answers this question and I really want to now how are car copes with ~9" of tire
Old 01-25-2013, 08:01 PM   #60
Skurj
Drives: SOLD...
Width of tire has nothing to do with 'speed or acceleration'
Weight yes, width no...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 01-26-2013, 04:31 PM   #61
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Width does matter. It is basic physics . grip = friction plus additional weight.
I say this because it effects bikes, why not cars? I want wider rims but I sorry about 9-9.5 being too wide. Plus you have to worry about scrubbing and clearances.
Old 01-27-2013, 04:14 AM   #62
Stance86
Drives: Toyota 86 GTS
The car doesn't feel any slower in a straight line... it's always been slow and still is. The car does have too much grip now and isnt as playful as it used to be. The VSC seems to be more intrusive though which is interesting.. cuts in now just going around corners fast...
I repeat there is no rubbing or scrubbing at all. So whats to worry about?
Originally Posted by wrohdejr View Post
Looking at Enkei's size chart the 18x 9.5 +38 is 5x114.3?
Thats right, it's a custom order. They are not on the size chart.
Originally Posted by Xdragonxb0i View Post
With just lowering springs, would we have to buy control arms and other stuff to control the camber/ toe? I'm also interested in know if you scrape going over bumpy roads
It doesn't scrape or rub.
Stance86 is offline   Reply With Quote
Old 01-31-2013, 06:19 AM   #63
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
18x9.5+38 245/35ZR
Installed today with Cusco Street Zero A Coil overs.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
The Following 3 Users Say Thank You to Metabrz For This Useful Post:
A-RS (03-15-2014), armythug (07-29-2013), PRORICAN (01-31-2013)
Old 02-10-2013, 03:43 AM   #64
Metabrz
001 of 012
Metabrz's Avatar
Originally Posted by Timtamtt View Post
They make rpf1s in this 18x9.5+38 for 5x100? Can't find it on the size chart for rpf1 on enkeis website I want a setttt
Ring them up. They are not on the charts but have been made. Good luck.
Old 02-10-2013, 04:27 AM   #65
Stance86
The Following User Says Thank You to Stance86 For This Useful Post:
Vic4uf (06-18-2017)
Old 03-01-2013, 12:31 AM   #66
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Merged another topic with the same wheels and same specs.
Old 03-02-2013, 10:48 PM   #67
yohan04
yohan04's Avatar
Drives: Your sister
First WRB BRZ I believe with this set-up.
yohan04 is offline   Reply With Quote
The Following 2 Users Say Thank You to yohan04 For This Useful Post:
botbs (03-03-2013), nix (06-17-2013)
Old 04-11-2013, 12:35 AM   #68
jammz
Drives: '13 Scion FR-S Agento
Talking Enkei RPF1 SBC finishing
Hey fellas just wanted to share my frs with you guys
just wanted to say thanks to @FT-86 SpeedFactory for getting me these !
Current set up:
18x9.5 +38 all around with Falken Ziex 512 tires 225/40/18
*on a side note i didnt have to roll fenders at all *
Enjoy
Side shot 1:
Side shot 2:
Rear Shot:
Overview of the front:
Update:
The pictures above was when i had tein coilovers with shorter springs installed in the front.. had a drop of 3inch -front and 2.5- rear
Recently Installed BC Coilovers w. the Extreme Drop kit.
Front fenders were slightly pulled, fender linings were cut. Still can go lower in the front. I have all 3 lock rings in the front and took 1 lock ring out in the rear.
jammz is offline   Reply With Quote
The Following 6 Users Say Thank You to jammz For This Useful Post:
619_FRS (06-17-2013), AE86guy (04-24-2013), eseboner (09-11-2013), SLICVIC (04-24-2013), Wes (04-11-2013), Wusaa (04-25-2013)
Old 04-11-2013, 12:43 AM   #69
ysr50guy
ysr50guy's Avatar
Drives: brz
Looks really good! What coilovers are you on?
ysr50guy is offline   Reply With Quote
Old 04-11-2013, 12:48 AM   #70
jammz
thanks ! im on Tein Street Basis Coilovers with shorter springs in the front. maxed them out as soon as i got them installed.
current drop-
front: 3inches
rear: 2.5 ~ i say this cause from what tein says 2.3 is the max but with settling in should around 2.5.
ft-86 speedfactory
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 11:30 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 05:53 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 02:52 AM
