Old 04-06-2013, 04:27 PM   #15
Ben_G
Drives: Blue BRZ
Originally Posted by BuBlake View Post
Oh okay. lol I thought they were referring to the butterfly as the 4 intake pipes(or whatever they are) coming from the throttle body. I don't think it will be that hard to take the entire intake section of the engine off and check for the tape, but a walkthrough would be helpful. I'm about to take this on, now armed with a camera and a decent set of tools... Will post pics if I'm successful.
You should probably NOT be attempting this yourself if you didn't know what the butterfly valve is...... if you insist on doing it yourself, I would suggest arming yourself with an actual person who is knowledgeable about these things and have them there in person to help...
Ben_G is offline   Reply With Quote
Old 04-06-2013, 04:53 PM   #16
ST185RC
Drives: White Out FR-S
Worst case scenario, it went past the intake valve and ended up in the cylinder and now it's most likely charred and riding on the cylinder wall, best case scenario: it got caught in the intake manifold and is blocking one of the intake runners. Either way, the intake manifold has to come off at the very least.
But as above said, you should immediately stop whatever you're doing with the car now and have someone who knows what they're doing to take a look.
ST185RC is offline   Reply With Quote
Old 04-06-2013, 04:59 PM   #17
DJCarbine
Thupercharged
DJCarbine's Avatar
I think best case would be the tape has run its course and been disintegrated in the combustion chamber and expelled as bits of carbon
To be honest if the car runs fine after sealing the intake system back up, I would not worry about it as any damage has already been done.
You could remove the intake manifold but I bet you won't see anything
DJCarbine is offline   Reply With Quote
Old 04-06-2013, 04:59 PM   #18
Juurian
Juurian's Avatar
Drives: 2013 Scion FRS WhiteOut
i'd get it checked, not worth sacrificing a 29k vehicle. If getting gasket sealer inside of a head can damage a cylinder I can only imagine what tape will do.
Winnipeg, Manitoba
Juurian is offline   Reply With Quote
Old 04-06-2013, 05:09 PM   #19
DBacon1052
DBacon1052's Avatar
Drives: Argento FR-S
I'm looking for a free way to do it though... I'm thinking pvc fittings? I want a quick fix as well, but at least I don't need to go anywhere soon. haha
Why... You spent nearly $30000 on this car. Spending $30 and not ghettofying it seems like common sense to me. But then again, it's your car. Do what you want.... just throwing in my 2 cents
DBacon1052 is offline   Reply With Quote
Old 04-06-2013, 05:13 PM   #20
DJCarbine
Thupercharged
DJCarbine's Avatar
There have been other forum posts in different vehicle forums about people sucking in electrical tape for whatever reason. Apparently its a popular tape to go to when fixing things. If they only knew what it looked like after a few years in a dry electrical box....
It may also be entirely possible that the tape simply fell off and is hanging out on the interstate or his skid plate.
People have sucked in towels and rags MANY times. Rags usually jam intake valves open, but paper towels seem to just burn up and cause no real harm.
If the car runs properly and has good compression in all cylinders I would not worry about it.
The Following User Says Thank You to DJCarbine For This Useful Post:
BuBlake (04-06-2013)
Old 04-06-2013, 06:02 PM   #21
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
Well, managed to get some stuff out of the way. At the very worst, at this point, I'll just have to put it back together. The only way I can mess something up is if I break it, as I am taking pictures and notes and would probably remember every step I have taken so far anyways. I imagine the only problem I may run into is the intake gaskets not being reusable, in which case I'll just replace them.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 04-06-2013, 06:07 PM   #22
BuBlake
BuBlake's Avatar
They're $30? Oh, well I may consider, but I will definitely not be trying to tape an intake closed again. Another issue is time; I don't want to wait 1.5 weeks for a plug that I can make myself in 30 minutes sacrificing nothing but a little bling.
The Following User Says Thank You to BuBlake For This Useful Post:
PradiG (04-07-2013)
Old 04-06-2013, 06:27 PM   #23
gusbarragan
Go back in time and stop yourself from putting the tape on in the first place.
gusbarragan is offline   Reply With Quote
The Following 3 Users Say Thank You to gusbarragan For This Useful Post:
BuBlake (04-06-2013), KSC (04-07-2013), Sportsguy83 (04-07-2013)
Old 04-06-2013, 06:42 PM   #24
BuBlake
BuBlake's Avatar
You know that part when you said, "It may also be entirely possible that the tape simply fell off and is hanging out on the interstate or his skid plate."?
Well, you were right! Here it is, the whole stinking thing... The whole time, on my damned skidplate. There's nothing in my engine... SOo happy!
Must have been warm and sticky when I parked it last night, then dried up and fell off overnight or right when I started it.
The Following 6 Users Say Thank You to BuBlake For This Useful Post:
aceangel (04-07-2013), CircuitJerk (04-07-2013), cmspooner (04-07-2013), jimmillion (04-07-2013), Sportsguy83 (04-07-2013), whataboutbob (04-07-2013)
Old 04-06-2013, 06:45 PM   #25
BuBlake
BuBlake's Avatar
Thank you everyone for your help and support! I love it when it's something simple. At least I learned something about the intake manifold today. haha
Old 04-06-2013, 07:04 PM   #26
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
If you're looking at removing it for a more tidy look then AOK.
But, if it is just the sound tube you are looking at removing then this $1.50 mod is the way to go IMO as it is totally reversible if you want the sound back on the track etc
http://www.ft86club.com/forums/showthread.php?t=30659
No need to even get in the engine bay. It's genius.
nzer is offline   Reply With Quote
The Following User Says Thank You to nzer For This Useful Post:
Old 04-06-2013, 07:47 PM   #27
BuBlake
BuBlake's Avatar
I know you guys are going to kill me for this, but I just electrical taped off the sound tube fitting and stuck it back in the hole after I removed the hose... I think I'll get this as soon as possible so I do not encounter any more problems with electrical tape. lol
Old 04-06-2013, 08:07 PM   #28
wbradley
Sarcastic SOB
wbradley's Avatar
Two words: Lucky balls
The Following 2 Users Say Thank You to wbradley For This Useful Post:
BuBlake (04-06-2013), whataboutbob (04-07-2013)
Dealer made a mistake........what would you do? Dustin Scion FR-S / Toyota 86 GT86 General Forum 44 03-02-2013 12:23 AM
My First Mistake slizoth BRZ First-Gen (2012+) — General Topics 117 01-24-2013 05:19 PM
Big Mistake GoSharks Tracking / Autocross / HPDE / Drifting 40 11-03-2012 04:42 PM
Awful, terrible mistake... ShinyBRZ Scion FR-S / Toyota 86 GT86 General Forum 45 08-21-2012 12:35 PM
Was ordering whiteout a mistake? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 63 04-29-2012 11:13 AM
