Koji_Online
Old 04-03-2013, 07:17 PM   #211
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Originally Posted by Sensisnow View Post
I just finished doing this a few minutes ago and it made an amazing improvement over the factory setting! Mine is even with, or perhaps a millimeter below the brake pedal. The clutch engages so much earlier now! I haven't even put 200 miles on the car yet, so I had been worried about breaking the clutch in properly since I always revved too high, not being used to such a high engagement point.
My gear indicator still seemed to work fine, but I went ahead and adjusted that sensor anyways since I was already down there. The entire job only took 10 minutes, if that long. Just follow the other tips in this thread, mainly using the shortest 12mm wrench possible, and everything should go fine.
I'm also nearly 6'5" and 260 pounds, so if I can fit down there anyone can!
You must be a contortionist, i'm the same size and weight and I barely got in there. haven't adjusted it -- need to wait on a sunny day to do it =).
CamryDS is offline   Reply With Quote
Old 04-05-2013, 12:14 AM   #212
CamryDS
did this, this afternoon. I have to say i'm happy with the result. I don't think i've been happier.
Sent from my ASUS Transformer Pad TF700T
Old 04-05-2013, 10:28 PM   #213
iamkyle
iamkyle's Avatar
Drives: Firestorm FR-S
Finished mine, I stalled the first time leaving my driveway lol, neighbor even saw. I just wasn't used to the very low grab point.
I absolutely recommend doing this mod, i feel like i'm driving a whole new car, and have more control of my shifts.
iamkyle is offline   Reply With Quote
Old 04-07-2013, 04:23 PM   #214
VoiD
Drives: 13 WRB BRZ
Did this right now. So much easier to drive! Should have done it sooner.. Thank you for the DIY and the video. Made much more sense after watching the video.
I pushed the seat the way back and went in to the pedal area diagonally, backwards. Resting the back on the door sill.
VoiD is offline   Reply With Quote
Old 04-07-2013, 10:12 PM   #215
Ingen
Drives: Ultramarine FR-S 6MT
Just hit 9500 miles, and did this.
Thank god I did. It's worth it, back agony or none.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 04-10-2013, 12:20 PM   #216
Unleashed
Unleashed's Avatar
Drives: 13' WRX
So after about 18k miles with this adjustment my clutch pedal spring is now no longer fully pushing the pedal completely in the up position. I first noticed the issue the other day when i pushed in the clutch to shift and as I lifted my foot I felt the thump of the pedal returning to the fully up position. It fully disengauges so it isn't riding the clutch at all but it is not rising off the sensor that lets your cruise control know you aren't pressing the clutch, and the gear inidicator doesn't display the gear unless i lift the pedal up with my foot. It will stay there once manually lifted but the spring seems to be tired and can't fully pop it into the up position.
Unleashed is offline   Reply With Quote
Old 04-10-2013, 12:25 PM   #217
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
Damn bro you've got a lot more miles than me now haha.
How far down is your pedal? try moving it closer to just right above the brake pedal; being that the spring is feeling worn in, the minimal clutch travel may be overwhelming the lesser tension from the spring now; also, most people who posted seem to like the feel of that pedal position the best; personally mine still sits slightly Lower; though I haven't driven 18k miles yet like you have.
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
Old 04-10-2013, 12:33 PM   #218
Unleashed
Unleashed's Avatar
Drives: 13' WRX
Yeah mine is slightly below the brake pedal as well and I feel like that offers the best clutch pedal feel and allows for smooth driving but I may back it out some due to the fact that with the ACT clutch it has be adjusted back out. I drive a lot man, I will be putting 500+ miles on it this weekend driving out to Cali.
Old 04-10-2013, 12:40 PM   #219
Koji_Online
N7 Spectre
Nice! you got the new clutch in man; can't wait to see the finished build. On a side note, it may be that the worn-in spring is not able to push up on the cruise sensor button (being that it is at the top/end of travel); when you first did the pedal adjustment & we talked about it, I think you said you never adjusted the sensor inwards. Though if you do make the sensor adjustment just refer to my OP post on pulling back on the pedal while screwing in the sensor; so that it doesn't end up always riding your clutch.
LMK how it works out man & probably see you otw to Cali, I'm headed there with my girl this weekend too.
Old 04-10-2013, 12:54 PM   #220
Unleashed
Unleashed's Avatar
Drives: 13' WRX
I didnt know that you had to adjust the cruise sensor. that may be the issue, and not the spring.
Old 04-10-2013, 12:59 PM   #221
Koji_Online
N7 Spectre
Yea man, most people on this thread did not have to because they kept their height above the brake pedal; but for those, like you & me, who adjusted below the brake pedal, the clutch pedal barely makes it back up to the cruise switch that also controls the gear indicating function; adjust your sensor in & let us know if that works
Old 04-10-2013, 01:12 PM   #222
Unleashed
Unleashed's Avatar
Drives: 13' WRX
Well the issue just started and my gear indicator/cruise has been working so I don't think the issue is the switch, I think its just the fact that the spring can't push it far enough up. I'm just gonna adjust the pedal some back to even or slightly higher than the brake pedal.
Old 04-10-2013, 02:00 PM   #223
CamryDS
I can to say that even if you have your pedal slightly above the brake (like I do) it's still recommended to adjust the gear sensor. I had to, and it only went down slightly, but still you'll see it protrude. The springs will last forever from the feel of the clutch, since it's strong as hell.
Old 04-10-2013, 08:27 PM   #224
Foobar
SLO NO MO
Foobar's Avatar
If you're able to lift the pedal up from it's "rest" position, then it sounds like the clutch return spring snapped off. Does the clutch seem lighter to press down on?
Either way, yeah - it would be a good idea to adjust the switch regardless, but get that return spring checked out first.
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
