Old 04-01-2013, 03:42 AM   #15
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You might have a weak battery. Cold mornings would make it apparent. Try a battery tender or block heater. You're on your own for the tire. I'd get a stock one until the rest are worn. Then I'd switch to Michelin super sports.
Old 04-01-2013, 03:56 AM   #16
laxfogo
Drives: DGM Limited BRZ
Ok thank you guys, I'll just eat this one.
laxfogo is offline   Reply With Quote
Old 04-01-2013, 08:19 AM   #17
Snowblind
Sounds like the biggest problem with the car is that they put a transmission in it that shifts itself.
Old 04-01-2013, 01:48 PM   #18
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Hey, look at the tough guy here shifting 200HP.
I'm sure when you drop into 2nd you get a real adrealine rush!
Don't be a douche nozzle, you'll only make your self look worse.
The Following 2 Users Say Thank You to dem00n For This Useful Post:
chenshuo (04-01-2013), naikaidriver (04-01-2013)
Old 04-01-2013, 02:23 PM   #19
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Originally Posted by laxfogo View Post
I'm having issues with the passenger side window, sometimes I would have to press it real hard and hold it for a second or the it won't auto go up/down.
Takes a long time to start in cold mornings.
Condensation in the rear lights sometimes also.
Also there is a lot of wind noise when driving on the highway, and the car have some sort of rattling noises.
Sometimes when I turn off the car, I heard metal clanking noises like someone is throwing rocks against the car.
Yesterday while I was on the highway doing 63, the TPS light came on I stopped and checked the tires, it wasn't flat only a little lower, I drove 5 miles and got off the exit and I heard a loud pop and I rolled to the nearest gas station about a quarter mile away and this is what happened.
Could I possibly have a case for a Lemon?
I know warranty doesn't cover tires, but this is clearly a defect in the stock tires or whatever is causing the heating issues in the blowout.
Window: i remember someone posted on this forum saying that cars made after October/November last year have a new switch. When did you get your car? You can take it to the dealer to get it replaced for a new part.
Start the car: i had this issue twice, but then i realized that if i hold the push button for 1-2 full seconds then release it, then i don't have hard time starting the car.
Condensation: i don't have that.
Metal clanking noise: completely normal. That happens when the engine is cooling down. Happens on every single car i owned.
TPMS: Your BRZ has TPMS? Mine doesn't.
Tire: It's gonna be hard to convince the dealer that the tire problem is not your fault.
chenshuo is offline   Reply With Quote
Old 04-01-2013, 02:26 PM   #20
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
wow you have the ability to shift a stick! You must be really smart and really cool!
Old 04-01-2013, 02:38 PM   #21
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
The tire warranties are generally for the first useable 2/32" of tread depth or 12 months which ever comes first.
Welcome to a first year car. There are going to be hiccups in any first model year and we are the lucky ones that get to work through them.
Lemon Laws usually require a problem to render the vehicle immobile or unuseable after multiple attempts at fixing the same problem.
Beyer Subaru is offline   Reply With Quote
Old 04-01-2013, 02:41 PM   #22
ST185RC
Drives: White Out FR-S
My rule of thumb: Take 30 seconds every fill up to check the tire pressure. I fill up every two weeks and tires need to be topped off every month and a half to two months.
Check under your hood, anything that is yellow are things you can check yourself and takes at most a minute to check everything. All the clear resevoirs have an indicator so most things can be visually checked. Pull out the dipstick, wipe, replace and pull out to check oil levels after you've stopped the car and let it cool down for 10 minutes. Coolant has a cold and hot indicator i believe, fill it up to what the status of your car is. It's not rocket science really.
Do these things to minimize chances of failures. When you have done your due dilligence to reasonably maintain the car, then you have an issue that you can bring up with the dealer and you have a case to argue if you've done everything you could. If you neglect doing things yourself, you are most certainly shit out of luck with any service department.
I just find it funny when preventable things could have been done but aren't and suddenly law this and law that start flying everywhere.
ST185RC is offline   Reply With Quote
Old 04-04-2013, 10:47 PM   #23
SVThis
SVThis's Avatar
Drives: Scion FRS
As far as the tire goes it was run with low pressure. So in the words of Michael Jackson
Just Eat It, Eat It, Eat It, Eat It
No One Wants To Be Defeated
Showin' How Funky Strong Is Your Fight
It Doesn't Matter Who's Wrong Or Right
Just Eat It, Eat It
Just Eat It, Eat It
Just Eat It, Eat It
Just Eat It, Eat It
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 04-04-2013, 11:29 PM   #24
foxhu
Hey welcome to america ^^ lawsuit lawsuit lawsuit!@!@!!
foxhu is offline   Reply With Quote
Old 04-05-2013, 06:15 PM   #25
kioton32
kioton32's Avatar
Drives: 14' Monogram FRS, ulramarine, white
The lemon law comes into effect if the dealership has to repair or replace the same component 3 times in the first 3 years of the vehicles life... Or first year on the case of a used vehicle... For example... If the starter goes out after 3 months and they replace it and
6 months later it goes out a second time they replace it again... If it happens again in the next 2 years the lemon law comes into effect... Most dealerships are nice about it... Especially Toyota... They will most likely end up giving you a brand new car at that point... I hope this helps clarify to anyone the understanding of the lemon law.
whether it be low and slow, fast and loud, or riding on rails, make it unique and make it your own.
kioton32 is offline   Reply With Quote
So my FR-S is officially a lemon... frsinpa Scion FR-S / Toyota 86 GT86 General Forum 90 01-19-2013 12:50 PM
Lemon law? Not sure what to do anymore. yayforaddison Issues | Warranty | Recalls / TSB 19 12-05-2012 12:14 AM
Anyone thinking about lemon law? Accurate Race Shop Issues | Warranty | Recalls / TSB 16 10-18-2012 10:11 AM
Lemon? grgonium Scion FR-S / Toyota 86 GT86 General Forum 13 10-08-2012 11:13 AM
Lemon FRS in Tampa FL??? ICEBONEZ Scion FR-S / Toyota 86 GT86 General Forum 44 08-27-2012 11:56 PM
