Old 03-30-2013, 04:44 AM   #1
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Wheel Directory: XXR 530 18x8.75 +33
Wheels: XXR 530
Offset: 33mm
Colour: Flat Black
Tyres: Continental ExtremeContact DW
Springs: Eibach Pro Kit
On a scale of 1-10, my like factor is about 7.
There's too much poke up front
My biggest dislike is the fact that virtually every other white 86 in my area has black rims
white_knight is offline   Reply With Quote
The Following User Says Thank You to white_knight For This Useful Post:
Juvenile (03-30-2013)
Old 03-30-2013, 08:35 AM   #2
seanmc69
seanmc69's Avatar
Drives: Scion FR-S Blue
Black rims looking sweet
_____________
Seanmc69 My FRS
seanmc69 is offline   Reply With Quote
The Following User Says Thank You to seanmc69 For This Useful Post:
white_knight (03-30-2013)
Old 03-30-2013, 09:26 AM   #3
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Fitment looks good, get some camber bolts to dial in a little negative up front and it will help with the poke.
I have a white car also and don't care for black wheels at all, they seem popular but i just don't get it. You can always paint or powdercoat them a different color because the wheels and fitment do look good.
The Following User Says Thank You to JoeBoxer For This Useful Post:
Old 03-30-2013, 11:47 AM   #4
xxscaxx
Drives: 2013 SWP BRZ
I'm glad i'm not the only one. This forum has a huge hard on for black wheels, no matter what the exterior color is lol.
Not knocking your car OP, it looks nice, just something i've picked up on while browsing. Every new wheel that pops up is always black.
xxscaxx is offline   Reply With Quote
The Following 2 Users Say Thank You to xxscaxx For This Useful Post:
dori. (03-31-2013), white_knight (03-30-2013)
Old 03-30-2013, 06:52 PM   #5
white_knight
I keep greeting advised not to go for camber because of the premature tyre wear, but looks like it's what I'll have to do to reduce the poke (save for buying new wheels!)
Can you recommend a good camber bolt? Also, judging by the pic above, how much negative camber will be needed?
Old 03-30-2013, 08:19 PM   #6
JoeBoxer
JoeBoxer's Avatar
I just used the OEM subaru "crash" bolt but Whiteline and i think SPC make some too. I'd max it out with the crash bolt and hopefully get around -1.0. Anything is better than the 0 camber we get from the factory.
Old 03-31-2013, 01:07 AM   #7
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
get the subaru one.
camber will increase your tire wear but not as much as toe that is out of spec
dori. is offline   Reply With Quote
Old 07-08-2013, 03:24 PM   #8
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 07-08-2013, 04:47 PM   #9
djdnz
1337
Drives: 2013 BRZ WRB S/C
Add some camber, you'll be much happier with the look. Tire wear will be marginally affected, just make SURE you get an alignment to fix the toe.
djdnz is offline   Reply With Quote
Old 03-14-2014, 04:54 AM   #10
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
The 2nd picture posted is the front poke? Or rear poke?
If that's the front...how does the rear compare? Is there any poke back there?
ericmpena is offline   Reply With Quote
Old 03-14-2014, 06:35 AM   #11
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Old 11-04-2015, 06:22 PM   #12
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Front car pic PLEASE
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Wheel Directory: XXR 521 18x8.5 +35 Iddoit2er Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 01-05-2016 11:53 PM
Wheel Directory: BBS RG-R 18x8.5 +35 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 04-11-2015 04:03 PM
Wheel Directory: BBS CH 18x8.5 +30 Spaceywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-02-2015 01:05 PM
Wheel Directory: BBS LM 18x8.0 +50 stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 07-08-2013 07:55 PM
Wheel Directory: BBS RE 18x8.0 +50 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-25-2013 08:49 PM
