Old 11-28-2011, 05:53 PM   #29
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Originally Posted by Kostamojen View Post
LOL!
There is already a photo of them, or have you not seen all the photos?
I already acknowledged that they were not speakers...Not sure what they are though...
Looks at the Lexus IS-F trunk...you can see those same things either side of the brake light..Also the ISF has goosenecks in the trunk....They did not go cheap on the Toyota 86.....Nice
tripjammer is offline   Reply With Quote
Old 11-28-2011, 06:06 PM   #30
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Agreed. Those should work for rear fill, which is fine. The three way setup if done right up front could eliminate the need for those rear speakers anyways. I'll be sure to fade mine all the way to the front for testing. I'm still undecided whether or not I want a system in this car and if I do how crazy I want to go.. whatever I do will be easily removable for track/autocross usage. I currently leave the amps in the ITR when I track/autocross it though.. too lazy to remove it.
Makes sense on the holes. VLN just cut the dash like any other race car would have done which makes sense.
That is sort of a bad design to have the dash mounted speakers. Even if they are polypropylene, direct sunlight will eventually take its toll.
On my GSR, I had 2 10's with the amps mounted on the box so when I need to remove it, both could come out at the same time. For this car, I don't plan to upgrade the speakers or put subs; those days are behind me.
I know! the 86 has strongarm lifts! That bumps up the price to 23-25K!
Old 11-28-2011, 06:35 PM   #31
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I run 1 8" sub. I use it to fill out the sound. Everything else is run actively crossed and front stage only.
Sun can take it's toll, but it will present a solid sound stage at a good height, so that's a plus. Insane reflections though so it'd have to be setup right. Normally I prefer higher mounted mid/tweet but firing across, not bouncing at the window
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-29-2011, 09:26 AM   #32
Levi
Drives: Toyota
There are 2 speakers on front door panels for base trim, and 6 speaker for high trim: 2 on front door panels (250 mm), 2 on rear side panels (160 mm) and 2 tweeters on the dash (85 mm).
Levi is offline   Reply With Quote
Old 11-29-2011, 11:37 AM   #33
SHINCHU86
SHINCHU86's Avatar
Drives: 98 z28 but i miss my ae86
if those rears are anything like the 4th gen camaro i have, you need to pull the whole panel to access them. lots of people put midbass there with good results. depends how deep a speaker that will allow for though.
i plan on just a 10" sub. nothing crazy. just added to the factory system will be fine. thats how im running my camaro with the factory "monsoon audio" upgrade plus an infinity powered 10".
this setup is a TON better than the original AE86! haha 4" dash speakers pointed at your shins, and 4" rears pointed at the roof. THAT needed an upgrade! this should sound just fine. my wife's '11 altima sounds great and its just the 2.4S with normal audio. "new" speakers usually sound fine these days. at least for the upper half of the spectrum.
however im getting worried about rear leg room. my kids seats will BARELY fit, and they would have to sit indian-style! and speaking of, those are definitely child seat anchors at the rear deck. they pop up like they did on my GS300.
Sold my 94 S14 for a 1998 Z28 Camaro. Woops.
Springs, Shocks, Sways, Bushings
Cam, Lid, magnaflow catback, BBK intake manifold, LS7 lifters, ECU tune. good for 400 hp.
sure its fast, but it drifts like a boat.
SHINCHU86 is offline   Reply With Quote
Old 11-29-2011, 11:42 AM   #34
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I suspect that's wrong. Crap OEM quality ~3.4" speakers will should like shit on the highs. They may be combining a mid and a tweeter in that dash measurement. The photos clearly show it's a 3 way setup, unless they made a fake grill covering for looks. 250mm = 9.8" woofer, the grill opening doesn't look ANYWHERE near that large. The largest factory door speakers I know of are 8". The rear speaker grills look like 4", 160mm is really a 6.5" woofer. If they are basing the measurements on cone diamter only not including surround and stuff then the door speakers would have to be 10" minimum to fit the 250, dash would be 3.5-3.75, which could mean a 3" and .75" if they are combining those into "one" speaker in the count.
But still, those grills aren't showing those sizes for the doors and back speakers.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-29-2011, 11:43 AM   #35
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
You aren't the only family man wanting the GT86 to work as a DD. Many others on here who would like a S2000, 370z, MX-5 but couldn't due to being 2 seaters. Will have to see how much room the back offers for a car seat/ small kid.
tranzformer is offline   Reply With Quote
Old 11-29-2011, 11:50 AM   #36
Sully
Drives: In the market for something fun
Not too worried about how difficult it is to swap out speakers for better ones.
It's probably only something that needs to be done once. It's okay if it takes a full day of work.
Sully is offline   Reply With Quote
Old 11-29-2011, 12:16 PM   #37
SHINCHU86
SHINCHU86's Avatar
*nod* to a member of the "dads who still have fun" club member :happy0180:
and yeah this is a HUGE make or break deal for my purchase of this vehicle. if its a no-go, im getting a Yaris/Fit (havent decided yet) and another tried and true AE86. either way, i win.
start thread for dads? lol
h6 swapouts? any thoughts or advice? f1ver BRZ First-Gen (2012+) — General Topics 53 11-22-2014 12:46 AM
Aspera's thoughts on AWD/RWD... aspera Scion FR-S / Toyota 86 GT86 General Forum 89 11-16-2013 03:55 PM
Your thoughts of the Ford Mustang Abflug Other Vehicles & General Automotive Discussions 31 08-25-2011 11:15 AM
Thoughts and secrets of the FR-S/FT-86 Interior KevinDuMa Scion FR-S / Toyota 86 GT86 General Forum 56 07-21-2011 03:38 PM
Aston Martin Veloce: Conceptual Study for a DB9 Replacement vh_supra26 Other Vehicles & General Automotive Discussions 1 02-13-2010 07:30 PM
