Old 03-25-2013, 01:15 AM   #99
xxscaxx
Drives: 2013 SWP BRZ
If you do the foulers, make sure to anti seize them. I did that trick in my STi and made the mistake of not putting anti seize and when I was removing my downpipe on my 30r kit I ended up snapping it off in there and there was no way of getting it out. Had to weld the hole closed.
xxscaxx is offline   Reply With Quote
The Following 2 Users Say Thank You to xxscaxx For This Useful Post:
ATL BRZ (03-25-2013), HRTROB (04-02-2013)
Old 03-25-2013, 10:53 PM   #100
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
So would the addition of the UEL header throw a CEL? I'm going to be putting on a catback soon and would love to grab a header too, but getting a tune is about as expensive as the header. I do want to keep as many cats as possible as well so not sure if this would help.
Jaylyons1 is offline   Reply With Quote
Old 03-26-2013, 05:59 AM   #101
86drift
86drift's Avatar
Drives: Toyota 86 GT
I've used one of these with success.
86drift is offline   Reply With Quote
Old 03-26-2013, 04:29 PM   #102
Jaylyons1
Jaylyons1's Avatar
Oh nice. I'm guessing you have the UEL header then. How long have you had this extension installed?
Old 03-27-2013, 09:26 AM   #103
86drift
86drift's Avatar
Actually I'm running EL headers. Got a CEL after a few wks. Then installed the spacer and got one more CEL. But none for the last 4 months.
The Following User Says Thank You to 86drift For This Useful Post:
Jaylyons1 (03-27-2013)
Old 03-27-2013, 03:02 PM   #104
BryanGT
Drives: WRD BRZ Limited
Originally Posted by ATL BRZ View Post
How's your car running? Have you been monitoring/logging AFR's or other fueling data?
Check this out: http://forums.nasioc.com/forums/show....php?t=2234058
Makes me nervous about using one.
Yes, I would rather have the light (or tune it out) than using a spacer and coaxing the ECU into messing things up.
BryanGT is offline   Reply With Quote
The Following User Says Thank You to BryanGT For This Useful Post:
Old 03-27-2013, 03:08 PM   #105
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I actually posted that before learning that the ECU only checks for cat readyness via the secondary O2 sensor. Nothing to worry about using an O2 sensor spacer to avoid a CEL on the stock tune. No fueling issues based on lots of feedback from others running catless already.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
BryanGT (03-27-2013), Eyesacky (03-29-2013)
Old 03-27-2013, 10:38 PM   #106
jwjknorr
Drives: FRS 2013
He must of not read that far back. I just wanted to chime in and say im going on one week, 350 miles, on the uel without a code, no defoulers. Fingers Crossed
jwjknorr is offline   Reply With Quote
Old 03-29-2013, 01:50 AM   #107
Eyesacky
Eyesacky's Avatar
Drives: DGM BRZ Limited "Freyja" +2 Miatas
And for some reason, my CEL turned off today. Gotta actually go check now and see if it's a different CEL. Fawk.
Eyesacky is offline   Reply With Quote
Old 04-10-2013, 04:43 PM   #108
dolph
Drives: 2013 BRZ, 2004 WRX
Originally Posted by number1Tango View Post
hmmm oem exhaust and uel would be interesting to hear
and to dyno
dolph is offline   Reply With Quote
Old 04-10-2013, 06:59 PM   #109
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
In for Borla UEL headers, Perrin overpipe/ catted frontpipe and borla catback
edit: Never mind...found in youtube!!
[ame]http://youtu.be/EZQdI9tVmBY[/ame]
minus perrin...im sold. Doesnt seem overly loud
Pablitomarrero is offline   Reply With Quote
The Following User Says Thank You to Pablitomarrero For This Useful Post:
Mr. (04-11-2013)
Old 05-10-2016, 06:51 PM   #110
Drifting86
Drives: 2013 FRS 10 Series
Originally Posted by dolph View Post
and to dyno
Gonna be the set up i have within the week 😎
Drifting86 is offline   Reply With Quote
Old 05-16-2016, 10:26 PM   #111
Smurff311
Smurff311's Avatar
http://www.bigdaddiesgarage.com
I have the angled one on the way but there's probably just enough clearance to run the minicat too. If you want a cheaper option then use autozone pn 42002 or 42009.
Read this post and watch the video: http://www.ft86club.com/forums/showp...0&postcount=78
Did you buy 2 of the angled or just one? And if you did by one, do you only need the spacer for the second O2 sensor, by second the one furthest from the engine?
**edit** Based on me rereading this a couple of times I'm guessing you went with one angled bigdaddies spacer and put in the second (furthest from the engine)
Smurff311 is offline   Reply With Quote
Old 05-16-2016, 10:31 PM   #112
ATL BRZ
ATL BRZ's Avatar
Originally Posted by Smurff311 View Post
Did you buy 2 of the angled or just one? And if you did by one, do you only need the space for the first O2 sensor?
I only bought one and never ended up using it. I came to my senses, like you and everyone else considering this should do: I tuned the engine for the header with Ecutek and disabled the CEL for catalyst efficiency.
I also got a refund for the Borla header and bought a JDL UEL header which is much better quality.
Dynos.. Mustang, DynoJet and Dynapack phenom86 Engine, Exhaust, Transmission 44 01-19-2018 06:32 PM
Borla R&D: Comparison UEL v EL Header 2013 Scion FR-S/Subaru BRZ RiskyTrousers Engine, Exhaust, Transmission 155 08-16-2013 10:05 PM
New! Borla cat-back for FR-S/BRZ Mach V Dan Engine, Exhaust, Bolt-Ons 9 02-06-2013 09:57 AM
Berk mid pipe and track exhaust installs, dynos, and video Matt Andrews Engine, Exhaust, Transmission 15 12-11-2012 09:15 PM
Borla Exhaust in the works DAZE752 Engine, Exhaust, Transmission 14 06-13-2012 03:27 AM
