AVOturboworld
Old 03-26-2013, 11:21 AM   #2367
ft_sjo
Drives: GT86
Originally Posted by vubaru View Post
There's no EBC. Boost is controlled via an internal wastegate at 5 psi. There's something else going on to cause that curve.
Feels great already, actually! And the new Roms by Paul don't have that same boost issue at 4k rpm. Tuning can only get better from here, too.
How is your tuning challenge going dude did anyone make you that awesome flat torque curve at 400 wtq yet??
Thanks for the clarification. Boost raising by itself means a restriction somewhere. If they can dial it out with a remap then it must be a radical limit on VE in the engine (e.g. cam timing). Perhaps it was put it for some safety? I dunno, pure speculation.
Unfortunately no, noone has manned up to my challenge yet.
The Following User Says Thank You to ft_sjo For This Useful Post:
vubaru (03-26-2013)
Old 03-26-2013, 11:47 AM   #2368
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Has anyone received a march shipment of these kits? Just wondering if and when the second set of kits will begin shipping?
gdrider77 is offline   Reply With Quote
Old 03-26-2013, 11:50 AM   #2369
AVOturboworld
They'll be shipping a bit late, from the end of this week and through the next 2 weeks. Our apologies, just got delayed a bit on some components.
Old 03-26-2013, 01:57 PM   #2370
sw20kosh
Drives: 2013 Black FR-S
That's not correct. Restriction only increases boost on supercharged motors where there is no waste gate to control boost level.
A wastegate senses the pressure in the system via a vac hose and maintains it via a spring with a certain psi rating.
On a turbo motor boost creeping up means:
1. an inability of the waste gate system to expel the gas enough to keep boost stable. This can be due to:
A. Boost control, if there is one, is faulty or un-tuned.
B. malfunctioning waste gate flapper door (in internal gated system) or an inadequate wastegate size
C. Boost leak in the system causing the signal to the waste gate to be less than what it is. This allows boost to reach higher levels before the waste gate opens.
Vu, I am sure you have experts working on fixing your problems but these are the areas on the system you can check yourself. I've had an internally waste gated turbo have a sticky flapper door which prevented the door from opening fully. Boost creep resulted. I've also had broken vac hoses causing the waste gate to not open when it should. And lastly I have had an ebc that just couldn't do what it was supposed to do. Switched to a manual one and it was fixed.
The Following User Says Thank You to sw20kosh For This Useful Post:
Alienate (03-26-2013)
Old 03-26-2013, 02:15 PM   #2371
2forme
Don't forget the rare, but applicable case of wastegate control rod adjustment. I've gotten internally gated kits where the arm from the wastegate actuator to the flapper door needed to be adjusted because of boost creep.
Old 03-26-2013, 07:24 PM   #2372
superpilun
Drives: 1986 MR2
What's up with the boost decrease from 4.5psi to 4psi from 3k to 5k rpm?
superpilun is offline   Reply With Quote
Old 03-26-2013, 07:51 PM   #2373
AVOturboworld
I'm waiting for some log analysis, but right now we suspect a bit too much retard on the ign. timing, especially in that range, along with a adjustable boost actuator rod being screwed up a bit too tight.
We know from experience that the kit will maintain a smooth boost curve, even at higher boost levels.
8psi on Stage 1.5, with full exhaust, MAP sensor, 7psi Actuator
10psi on Stage 1.5+, with full exhaust, MAP sensor, 7psi Actuator
So just looking at sorting out what it is specifically.
The Following 7 Users Say Thank You to AVOturboworld For This Useful Post:
Alienate (03-27-2013), BRZranger (03-26-2013), dabocx (03-26-2013), Draco_PR23 (03-27-2013), MSTiFK8R (03-27-2013), SkAsphalt (08-13-2014), Sportsguy83 (03-26-2013)
Old 03-26-2013, 09:35 PM   #2374
AVOturboworld
Stage 2 work in progress thread.
http://www.ft86club.com/forums/showthread.php?t=27399
The Following User Says Thank You to AVOturboworld For This Useful Post:
Old 03-27-2013, 02:13 AM   #2375
ft_sjo
Drives: GT86
I should have been clearer. My statement was based on the assumption that the waste gate was saturated. Your comments fill the void well, though.
Old 03-27-2013, 04:10 AM   #2376
ft_sjo
Drives: GT86
Looks like Fensport in the UK are doing well with the AVO kit:
They claim the calibration/map is not finished yet.
Old 03-27-2013, 04:15 AM   #2377
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
^^^ NICE! Looks really similar to ours, a little more power due to generally better gas I'm assuming...
Regards,
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 03-27-2013, 04:20 AM   #2378
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
which psi?
MSTiFK8R is offline   Reply With Quote
Old 03-27-2013, 04:23 AM   #2379
ft_sjo
Drives: GT86
Originally Posted by MSTiFK8R View Post
which psi?
I'm not sure, sorry.
Old 03-27-2013, 11:45 AM   #2380
sw20kosh
Does theirs spool up faster due to their gas?
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
