Old 03-23-2013, 11:28 PM   #1
stocktc1
Drives: scion tc
Wheel lock on only one per wheel: unbalanced?
Is the weight difference of only putting one wheel lock on 1 wheel negligible or does it cause a problem like using a lab centrifuge without balancing the test tubes in it?
Would it be the cause of camber wear?
stocktc1 is offline   Reply With Quote
Old 03-23-2013, 11:30 PM   #2
OrbitalEllipses
Drives: Attitude
You should be using 5 per wheel for maximum security and theft deterrence.
Old 03-23-2013, 11:32 PM   #3
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
no, man lol. they wouldn't sell 1 per wheel wheel locks if it was bad for the car in any way. that being said, 5 per wheel is more protective and will generally look better. i also prefer not to have the keyed ones as they could wear away over time.
edit for clarity:
i prefer these:
not these:
mezdup is offline   Reply With Quote
Old 03-23-2013, 11:37 PM   #4
stocktc1
Drives: scion tc
I dont really live in a high crime area but I was wondering if it causes some unbalance at high speeds. Yea, I have those ghetto ones in the bottom pic.
Old 03-23-2013, 11:40 PM   #5
mezdup
#1362
mezdup's Avatar
nah you won't have any problems with balance. and they're not ghetto, they're perfectly fine. just if they're overtorqued constantly with like an air impact gun, you'll start to see the ridges fade. but yea if the balance thing really bothers you (and i'm 100% sure you won't have a balance issue using 1 wheel lock per wheel) then just get 5 wheel locks per wheel if you want.
Old 03-24-2013, 02:32 AM   #6
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I'm sure they are very close in weight, if not exactly the same. In addition they very close to the center of rotation where a minor imbalance has far less effect then it would close to the outer edge of the wheel.
Old 03-24-2013, 04:10 AM   #7
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
As long as you are not mix matching aluminum locks with the stock ones then you should be fine. Lighter is always better though so when in doubt go get a full 20pc set aluminum from ebay.
Originally Posted by mezdup View Post
i prefer these:
I have these exact ones on my Impreza for only 2 months during winter and they have already started to rust.
LeeMaster is offline   Reply With Quote
Old 03-24-2013, 09:37 AM   #8
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
I have set of the original Subaru wheel locks (with key) as shown in the lower photo (one lock per wheel) for 15 bucks including shipping to continental U.S. (the lower 48 only).
BRZfan is offline   Reply With Quote
Old 03-24-2013, 09:56 AM   #9
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
try and not create imbalance
Huehuecoyotl is offline   Reply With Quote
Old 03-24-2013, 10:10 AM   #10
wparsons
wparsons's Avatar
Camber wear is caused by a bad camber setting for how you drive, nothing else.
flickr
Old 03-24-2013, 10:17 AM   #11
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
The further out from the center of the wheel that you find a difference in weight the stronger the effect will be. The difference here in weight is so slight and so close to the center of the wheel (axle) that there will not be any effect on balance.
whaap is offline   Reply With Quote
Old 03-24-2013, 10:27 AM   #12
Huehuecoyotl
Uh I can 'feel' a lock missing, so its not that slight!
Old 03-24-2013, 10:48 AM   #13
wbradley
Sarcastic SOB
wbradley's Avatar
Exactly. It's at the hub so it's effect is minute.
Old 03-24-2013, 10:52 AM   #14
jshadeck
jshadeck's Avatar
The butt dyno is an amazing thing...
jshadeck is offline   Reply With Quote
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel Pekingduck Interior Parts (Incl. Lighting) 7 02-12-2014 06:59 PM
WTB: Steering Wheel Lock for Anti-Theft 86 FRS Miscellaneous 0 11-06-2012 06:38 PM
OEM wheel lock work on aftermarket wheels? #87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-27-2012 09:00 AM
Anyone in NOVA have enkei wheel lock key? Grishbok Mid-Atlantic 0 10-13-2012 08:20 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
