| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: scion tc
Wheel lock on only one per wheel: unbalanced?
Is the weight difference of only putting one wheel lock on 1 wheel negligible or does it cause a problem like using a lab centrifuge without balancing the test tubes in it?
Would it be the cause of camber wear? |
#2 |
Drives: Attitude
You should be using 5 per wheel for maximum security and theft deterrence.
#3 | |
#1362
Drives: 2014 Ice Silver WRX
edit for clarity: i prefer these: ![]() not these:
#4 |
Drives: scion tc
I dont really live in a high crime area but I was wondering if it causes some unbalance at high speeds. Yea, I have those ghetto ones in the bottom pic.
#5 |
#1362
nah you won't have any problems with balance. and they're not ghetto, they're perfectly fine. just if they're overtorqued constantly with like an air impact gun, you'll start to see the ridges fade. but yea if the balance thing really bothers you (and i'm 100% sure you won't have a balance issue using 1 wheel lock per wheel) then just get 5 wheel locks per wheel if you want.
#6 |
Drives: '13 GBS Subaru BRZ
I'm sure they are very close in weight, if not exactly the same. In addition they very close to the center of rotation where a minor imbalance has far less effect then it would close to the outer edge of the wheel.
#7 |
Red wine
Drives: Subaru BRZ(R.I.P)
As long as you are not mix matching aluminum locks with the stock ones then you should be fine. Lighter is always better though so when in doubt go get a full 20pc set aluminum from ebay.
I have these exact ones on my Impreza for only 2 months during winter and they have already started to rust.
#8 |
Drives: 2013BRZ Premium St Silver Metallic
I have set of the original Subaru wheel locks (with key) as shown in the lower photo (one lock per wheel) for 15 bucks including shipping to continental U.S. (the lower 48 only).
#10 |
Camber wear is caused by a bad camber setting for how you drive, nothing else.
#11 |
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
The further out from the center of the wheel that you find a difference in weight the stronger the effect will be. The difference here in weight is so slight and so close to the center of the wheel (axle) that there will not be any effect on balance.
#13 |
Sarcastic SOB
Exactly. It's at the hub so it's effect is minute.
#14 |
The butt dyno is an amazing thing...
| FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel | Pekingduck | Interior Parts (Incl. Lighting) | 7 | 02-12-2014 05:59 PM |
| WTB: Steering Wheel Lock for Anti-Theft | 86 FRS | Miscellaneous | 0 | 11-06-2012 05:38 PM |
| OEM wheel lock work on aftermarket wheels? | #87 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-27-2012 08:00 AM |
| Anyone in NOVA have enkei wheel lock key? | Grishbok | Mid-Atlantic | 0 | 10-13-2012 07:20 AM |
| Are there any RWYB Wheel to Wheel road races? | LexusFman | Other Vehicles & General Automotive Discussions | 1 | 11-05-2011 12:28 PM |
