Old 03-21-2013, 11:39 PM   #71
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by andrew20195 View Post
It's in the SRS control unit. Of course, if you remove it, you will no longer have functioning airbags...
Furthermore, the data stored in that unit is YOUR property. The only way the dealership or manufacturer can legally access it is if you give them permission, or law enforcement has a warrant, or a court subpoenas the information.
"legally" being the key word.... I guess i'll start investigating to see if the recording function can be shut off...big brother needs to stay the F out of my car.
Old 03-21-2013, 11:43 PM   #72
andrew20195
Drives: 2013 Subaru BRZ
If they illegally access the data, you can probably sue the everloving crap out of them. Technically, I believe it is also a criminal offense and could be prosecuted under "hacking" laws.
andrew20195 is offline   Reply With Quote
Old 03-22-2013, 12:19 AM   #73
Marrk
Drives: Honda Fit
Originally Posted by BlaineWasHere View Post
... I'm not sure what that has to do with I was saying though. ...
What that has to do with what you were saying:
There will come a time when the dealer won't have to ask you anything. Indeed, maybe we're there now.
[ame="http://en.wikipedia.org/wiki/Event_data_recorder"]Event data recorder - Wikipedia, the free encyclopedia[/ame]
Marrk is offline   Reply With Quote
Old 03-22-2013, 02:49 AM   #74
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Right, but the OP said something about following a snow plow in the snow and the dealer goes "oh shit hydrolock". How does this black box know it's snowing and your following a snow plow?
As long as you're not being negligent with your speed and you haven't modified the car what can the black box show that would void a warranty claim?
The Following User Says Thank You to BlaineWasHere For This Useful Post:
strat61caster (03-22-2013)
Old 03-22-2013, 10:16 AM   #75
andrew20195
Although we're a bit off-topic now, I'd like to point out a very important paragraph in the BRZ owner's manual concerning the EDR for all you paranoid people:
NOTE: EDR data is recorded by your vehicle only if a non-trivial crash situation occurs. No data is
recorded by the EDR under normal driving conditions
and no personal data (e.g. name, gender, age
or crash location) are recorded. However, other parties such as law enforcement could combine the
EDR data with the type of personally identifying data routinely acquired during a crash investigation
The Following User Says Thank You to andrew20195 For This Useful Post:
Marrk (03-22-2013)
Old 03-22-2013, 11:41 AM   #76
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
If I may add one more tidbit to this side-conversation...
A few years back I was taking my BMW in to be serviced and I made a comment about how much technology had advanced when the "technician" took my key, stuck it in a reader box and was able to get all kinds of data off of it including ECU logs!
He told me about a warrantee claim that was made a few months earlier over a brand new 7-series that a dad bought for his son. It was returned a few months earlier with a blown transmission. The "technician" said when he inserted the key from the car, he was able to tell that the car was moving at 70mph at full throttle when the car was shifted into reverse. He was quite proud of himself for being able to deny the warrantee claim due to abuse.
Anyway, just thought that I would share.
Scott
naikaidriver is offline   Reply With Quote
Old 03-22-2013, 12:37 PM   #77
Marrk
Drives: Honda Fit
@Blaine&Andrew:
I am not an expert on this. However, my understanding is that a Congressman in Massachusetts and the ACLU are upset about EDRs, and they want to make sure there is legislation to protect the consumer because, as pointed out above, you own the data. Also, because of First Amendment rights.
My understanding is also that the EDR is like a "black box" recorder on an aircraft. It is logging data of a kind above and beyond error codes, including what's going on in the cabin (e.g., whether or not there is a passenger sitting on the passenger seat).
Could they tell there was a snowplow on the road at the time of the incident? I don't know. Can some cars tell where the curb is and park themselves? Yes.
Old 03-22-2013, 12:58 PM   #78
OrbitalEllipses
Drives: Attitude
EDRs basically record telemetry in the event of a crash; or at least that's what we're told they record. Some cars record different data, as evidenced by the BMW 7 series warranty claim above.
Old 03-22-2013, 01:00 PM   #79
Marrk
Drives: Honda Fit
In any case, you don't have to be a paranoid conspiracy theorist to want to be the one who controls the data, i.e. where is goes and what it's used for.
Old 03-22-2013, 01:29 PM   #80
OrbitalEllipses
Drives: Attitude
I very much agree, but let's talk about rod knock and the dealer trying to screw this guy instead of EDRs.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Marrk (03-22-2013), strat61caster (03-22-2013)
Old 03-22-2013, 02:44 PM   #81
mad_sb
LOL,
I still don't understand what the OP mentioned about the piston hitting one of the injectors.....
The DI injectors are located between the intake valves in a recess of the head... I don't see how it could get hit unless there was debris inside the chamber.. then again, i don't think we have a cross section view anywhere that shows if the tip of the injectors protrudes into the cylinder...
I understand if the bearing is worn enough for rod knock that there is extra slop in the travel.. but there should be enough squish area that nothing would hit the injector...
Old 03-22-2013, 06:18 PM   #82
pozer
pozer's Avatar
Drives: 13 FR - s
Send a message via AIM to pozer
To me it looks like the DI might have a few mm overhang but I did not see it myself so I can only guess.
pozer is offline   Reply With Quote
The Following User Says Thank You to pozer For This Useful Post:
Marrk (03-22-2013)
Old 03-22-2013, 07:01 PM   #83
andrew20195
Yeah, I was thinking that with a bad rod bearing, there may have been enough slack for the piston to kiss the injector tip.
Old 03-22-2013, 07:44 PM   #84
Marrk
Drives: Honda Fit
Great graphic. Many thanks for that.
BC Racing Coilovers - Knock? 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 12-09-2015 11:41 PM
anyone experience engine knock on 91 octane? chenshuo BRZ First-Gen (2012+) — General Topics 15 01-13-2013 08:10 PM
Why you shouldnt support knock off companies.. showbe Engine, Exhaust, Transmission 44 10-29-2012 09:13 AM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 02:17 AM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 07:17 PM
