#2325 |
Drives: 2013 Black FR-S
Turbo doesn't act like a resonator.
It quiets an exhaust down the same way this does: ![]() see the similarity? ![]() ![]() ![]() The principles are the same. Sound waves cannot just exit out freely from the exhaust ports. They hit something in the exhaust path. Whether it be a butterfly valve or a turbo turbine blade wheel.. same principle. The material absorbs the some of the sound energy and bounces it back even. |
| The Following User Says Thank You to sw20kosh For This Useful Post: | vubaru (03-14-2013) |
#2326 |
Drives: 2012 Toyota 86
that sounds pretty darn mean to me
| The Following User Says Thank You to troek For This Useful Post: | vubaru (03-14-2013) |
#2327 |
[ame="https://www.youtube.com/watch?v=4feKV_xeGeg"]AVO BRZ Test Honjo Circuit - YouTube[/ame]
| The Following 10 Users Say Thank You to AVOturboworld For This Useful Post: | BRZranger (03-15-2013), Calum (03-14-2013), cmss2000 (03-14-2013), Draco_PR23 (03-14-2013), Jeff86 (03-24-2013), Mr.Jay (03-16-2013), Sonolin (03-14-2013), Sportsguy83 (03-14-2013), troek (03-14-2013), vubaru (03-14-2013) |
#2328 |
Drives: 2013 Toyota 86 GT
Sounds hot, looks like a lot of fun... But what's with the purple interior? :-p
#2329 |
Love the purple seats. What number is the avo car? 1? 2? 3?
#2330 |
I believe they were the no.3 car with the 43 second time. Will check on that. The seats are black - that interior camera does weird things with color. Exposed to too many exotic fumes I guess..
| The Following User Says Thank You to AVOturboworld For This Useful Post: | Sportsguy83 (03-16-2013) |
#2331 |
That Guy
Drives: 2013 asphalt FRS MT
So that camera makes the seats purple, your other camera makes your FRS a very strange color orange.... I think you guys are messing with things.
#2332 |
Drives: 2018 Golf R
![]() I don't think I can trust all the dyno graphs that have been posted since I can't even trust their videography skills. STOP LYING TO US AVO!!
Parting out HERE
#2333 |
In this next week or two.
#2334 |
Pegasus White
Drives: 86
Can I add my name to the pre-order list :"D
Driving: Pegasus White Manual GTS 86.
#2335 |
Track testing update:
Ross at AVO Turboworld Japan just completed a full day of track testing at Tsukuba Circuit. And when we say full day, it was a full day, 20 minute sessions on the hour, every hour from morning till evening. All in all, the AVO BRZ did around 80 laps over the course of the day. With Ross driving, times were very consistent, around the 1m05sec mark for the entire day. This is about a 3.5 second improvement from the BRZ back when it was N/A, but with the suspension and tires. Ambient temperatures were at the 25° C mark, with the actual track surface temperatures at 35° C mark. The car was logged the entire time so we could track water and oil temps, along with a lot of other data we were keeping an eye on. Over the course of the day, the max water temperature we hit was 106° C, which dropped to 98°C when the heater turned on. Oil temperatures hit 140°C at max, which dropped to 135°C when the heater went on. In direct comparison, another BRZ being driven at the same time that was N/A and running a large oil cooler was hitting 117° C oil temperatures. Needless to say, it was a fairly comprehensive thrashing of the car at the track. Yet at no time did the car overheat. One reason for that is that the oem radiator cap is 1.1-bar unit. Ross’s advice towards anybody considering these levels of track duty may certainly want to invest in an oil cooler, it would help. Things to look at is maximizing air flow through the car, and possibly invest in a more efficient radiator. They also did a fairly comprehensive test of the track breather system, and it worked brilliantly. Part of that setup was a new PCV valve designed for turbocharged application. A problem with the standard PCV is that it was never designed for positive intake manifold pressure, and will leak under boost. We will be posting some videos of testing of the PCV soon. A couple of pics from the previous track day a week earlier at Honjou Circuit ![]()
| The Following 12 Users Say Thank You to AVOturboworld For This Useful Post: | Alienate (03-20-2013), bestwheelbase (03-24-2013), Bonburner (03-20-2013), BRZranger (03-20-2013), buditjoenawan (03-20-2013), Fly Guy (03-23-2013), Jeff86 (03-20-2013), NorCalRider (03-20-2013), Sportsguy83 (03-20-2013), sw20kosh (03-20-2013), swift996 (03-20-2013), vubaru (03-20-2013) |
#2336 |
Drives: Scion FRS
Some on needs to put a full turboback/injectors/pump and see what this thing can do on 93 and e85.
Still the most oem looking kit and that sound >_> |
#2337 |
I am planning on doing that here as soon as possible, and have it run on the Drift Office dyno again so we have clear back to back data.
| The Following 2 Users Say Thank You to AVOturboworld For This Useful Post: | dabocx (03-21-2013), Sportsguy83 (03-20-2013) |
#2338 |
Drives: BRZ WRB
I'm looking for the optimal fuel pump to support my ~10-12psi AVO build Has anyone experienced putting Walbro 255lph in the BRZ\FRS bucket? Will it fit ? As spoken with Paul from @AVOturboworld , Ross is testing some fuel pump options at the moment, so I' ll be very grateful if AVO could add the appropriate and relable pump in the package, which is about to leave my way...(hopefully) I've chosen Deatschwerks 700cc inhectors, but heard many weird things reg their DW65 pump, which seems to have a mind of its own ... so I'm seeking options |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
