#15 |
Drives: Skoda Yeti DSG diesel 4x4
#16 |
86-er
Drives: BRZ tS
Just sounds more sporty and throaty....very clean sound.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
#17 | |||
I Love custom Turbo kits
Drives: Limited BRZ
(I can ask @raul who has Nameless exhaust to see if he is interested). What filter are we talking about?? (Hoping for the Works!!!) Most probably he would do it in a Dynojet because that Mustang Dyno was expensive ![]() Quote:
Those are very good numbers! The only comment I would add is that Mustangs read lower than Dynojet's, but nonetheless, those are awesome numbers! Quote:
I really can't remember much how the car sounded stock as I went from Nameless full exhaust to removing the axleback and keeping the downpipe but I can say that it sounds louder inside the cabin. I believe outside the car its very similar to stock. All very nice type of sound, not annoying.
#18 |
Drives: 2013 Asphalt FR-S
you cannot compare one dyno to another like that. Your best bet would be to compare another stock vehicle on the same dyno, less prone to error than one dyno to another.
~Namaste~ |
#19 |
Drives: Limited BRZ
Yes yes, I agree there is no baseline, all numbers are speculation. But a fact is Mustang dynos read lower than Dynojet Dynos, just the nature of the beast. I posted the picture with uncorrected and corrected numbers for weather conditions, so even though it is all speculation, we can get a ball park figure on where it is and Leemaster's guess is not far fetched BUT I wholeheartedly agree, there is no certainty based on this Dyno about exactly how much Nameless DP/OP gains, just ballpark figures.
#20 |
Drives: Limited BRZ
Added more pics to OP
#21 |
Drives: Asphalt FRS
How does the nameless add so much more power than the motiv/invida/etc? From my understanding at the end of the day its the same diameter pipe with the same bends in the same places-am I wrong?
#22 | |
Also the plot posted in post #3 from nameless is for the combo of the old axleback with the over / front pipe not just the Frontpipe alone with otherwise stock exhaust, or adding the over / front to the axleback. In other words if the stock catback is a bigger restriction that the front pipe, you would see a bigger gain from the front pipe AFTER replacing the catback than before replacing it. I am running the catted, helmholtz, over/front pipe right now with otherwise stock exhaust. I am not going to bother going to the dyno again until I add the axleback. The sound is a little different, a bit more aggressive. But in all honesty, after the first few minutes of a cold start you would be VERY hard pressed to tell mine from stock. So, it is louder during cold start, but once the idle kicks back down you can't tell a difference due to the stock catback.
~Namaste~ Last edited by mad_sb; 03-17-2013 at 01:58 PM. |
#23 | ||
Drives: Limited BRZ
Edit: Mad_sb was referring to the Nameles Dyno plot, not mine. My car was with ONLY DP/OP everything else in the car was stock
#24 |
Drives: Scion FR-S
I think I remember reading somewhere from nameless that there isn't a power difference between the downpipe and downpipe overpipe combo. I also remember them saying the cat they use flows the same as an open 2.5" pipe and is rated for a 500 hp engine. So if there is a difference it may be that.
Sent from my Nexus 7 using Tapatalk HD |
#25 | |
~Namaste~ |
#26 | |
Drives: Limited BRZ
Ohhh yes yes!! Nameless plot is with OP/DP AND Axleback :happy0180:
#27 |
35r + 35r = 70rr ?
Drives: Subaru BRZ Time Attack S13
Good numbers, but wait till you have boosted numbers lol. Your going to beyond happy.
#28 |
Drives: Attitude
I have a baseline with ONLY the Nameless offset axleback. I just installed the over/downpipe with HFC and Helmholtz; I'll will go back to the EXACT dyno I got my baseline done on and provide the forum with those results.
Sound? Good god it's awesome. |
| Nameless Performance Overpipe/Downpipe Combo | Jason@Nameless | Engine, Exhaust, Transmission | 277 | 04-04-2018 12:37 AM |
| Will nameless downpipe w/highflow cat fit with... | Pandle | Engine, Exhaust, Transmission | 2 | 02-17-2013 07:13 PM |
| Nameless axleback and downpipe FS | 117 | Engine, Exhaust, Bolt-Ons | 8 | 02-01-2013 10:06 AM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 04:57 PM |
| Dyno results for the Nameless Performance street package! | John@Nameless | Announcements, Contests, Giveaways | 31 | 06-26-2012 04:37 AM |
