#225 |
Drives: 2013 Asphalt FR-S
What tuning solution are you using that requires the maf?
I assume your not going ecutek since i believe those tunes are speed density. If you were going stand alone I would assume speed density as well. That leaves BRZedit (what i am using for my na tuning, and they are working on a speed density patch i hear) or unichip.
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | Silverdub (03-13-2013) |
#226 | |
Boostin'
Drives: FRS-T
i was going to get vistonti but he is not coming over just yet, so i need a basemap and then be able to drive my car... i need to get back to him, if he tells me that he has a 5psi base map mafless i can get this thing running in no time! other solutions are Treadstone performance has a maf housing, but thats too many couplers in my engine bay, or KStech has a maf flange in stainless but it says WRX 02-07 so im not sure it is going to fit
#227 | |
Must respect to you for taking on a project like this!. One of these days I'll get around to buying some welding gear so I can start doing my own builds :happy0180:
~Namaste~ |
#228 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
have you asked KStech if they can machine you an 08+ flange in stainless? I'm sure they could.
| The Following User Says Thank You to JP For This Useful Post: | Silverdub (03-14-2013) |
#229 |
Boostin'
Drives: FRS-T
I did and they said no, not enough people asking... I am buying the treadstone complete housing kit for now, just waiting on them!
#230 |
Mad Sciontist
Drives: gt86
I made my own when I was going to run stainless piping, I had 3" stainless bar and bored it out then parted it off. Was just a disk that I welded onto the pipe and then drilled the holes lol
| The Following User Says Thank You to jet86 For This Useful Post: | Silverdub (03-14-2013) |
#231 |
Boostin'
Drives: FRS-T
i was thinking of making mine but the problem was de 1.02 inch bore hole, if not it would of done it...
#232 |
Mad Sciontist
Drives: gt86
26.3mm. I just used a small boring tool.
#233 | |
Drives: Asphalt Frs
#234 |
Boostin'
Drives: FRS-T
As of now i am buyinv his basemap and i ll see from there. Is it needs adjustments but runs good i might drive down there and pick up parts stateside plus ball game somewhere, redsox perhaps
#235 |
Good choice :happy0180:
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
| The Following User Says Thank You to Turbowned For This Useful Post: | Silverdub (03-15-2013) |
#236 |
Boostin'
Drives: FRS-T
Just waiting on parts to showup from treadstone to finish this up
#237 |
Boostin'
Drives: FRS-T
I finally welded my BOV adapter and installed it! I also built my turbo inlet pipe and ordered my K&N filter. I will be welding the inlet this week and once the filter shows up i can put the bumper back on for good!
#238 |
Boostin'
Drives: FRS-T
Not much to brag about but i got my air filter and wideband o2 plug. As soon as i get my maf housing from treadstone i can drive!
| Silverdub firestorm 6mt | Silverdub | Member's Car Journals | 26 | 07-23-2012 06:13 PM |
| 86-X project | phenom86 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-11-2012 03:57 PM |
| Project continue | 4agze | Other Vehicles & General Automotive Discussions | 37 | 11-15-2011 03:55 AM |
| New Project x2 | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 9 | 10-25-2009 12:17 PM |
