Old 03-12-2013, 04:56 PM   #1
kaybee123
Drives: Scion FR-S
Detective Work - Dealer Misleading
Situation:
I have had the winter tires & rims for about 3-4 months and suddenly the tire pressure light comes on a week ago.
Ok cool, I check the tire pressure, re-fill a tire that was a little low and figure it's going to go off.
Nope, it stays on in spite of all the tires being at 35psi. (I even tried 32psi)
I drive like this for a week thinking that one of the sensors is faulty... light is always on but the tires are fine so who cares.
One week later, I go to the dealer and he tells me I don't have any tire sensors on the car (and if I want this problem to go away, I should buy 4 of them at $50/piece).
My question: Wtf?! If my tires haven't had sensors on them ALL winter then why wasn't the light on for 3 months?!
His answer: "Oh, it just takes time for the computer to calculate things"
Alright, I'm not convinced but fine.
I get back into my car to drive off and I notice: "The tire pressure light is off!!"
WTF?
I call them: "Did you reset the computer?" Assuming this is why the light was off.
Dealer: "Nope, we didn't do anything. Didn't reset the computer. It's just random like that sometimes".
OK BS.
There's no way that I was driving around for 1-2 weeks with the light on.. I go to the dealer, they do "nothing" and then magically the light is off.
My questions:
What really happened?
Is there a way to 'soft reset' something like the tire pressure? Is there a secret computer option they don't want to talk about? Are there pressure sensors I don't know about?
RESOLVED: Thanks. I didn't know there were wireless sensors.
kaybee123 is offline   Reply With Quote
Old 03-12-2013, 05:02 PM   #2
whtchocla7e
Drives: 2013 FR-S Hot Lava
My light doesn't go off on its own until I park next to my stock wheels. The dealer musta did something to your car or the sensor is indeed defective.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 03-12-2013, 05:06 PM   #3
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Your winter rims probably don't have sensor. Each night you park at the garage, you are probably close to your OEM wheel and tires so the car thinks your tires pressure is ok and it takes a bit of of time for the car the realize that you don't have senors but just before the light triggers you probably went back home and parked your car again close to your OEM set before the computer realizes anything.. lol
Don't know if I made much sense
shu5892001 is offline   Reply With Quote
Old 03-12-2013, 05:12 PM   #4
HunterGreene
Hail Magnet
HunterGreene's Avatar
This happened to me all the time when I swapped winter wheels on the previous car. If you are away from your stockies for a little while, the light will turn on.
As far as the dealership, I really wouldn't worry about it. This is not a problem you need to stress over.
Old 03-12-2013, 05:29 PM   #5
kaybee123
Drives: Scion FR-S
Oh, so the sensors work wirelessly and if they are near tires in good conditions... the light will go off?
hahaa well that would explain things.
Old 03-12-2013, 05:45 PM   #6
FR-S Hot Lava
FR-S Hot Lava's Avatar
Drives: FR-S Hot Lava (AT)
the sensor is prob telling you that your summer tires in the garage need air not the winters on the car
FR-S Hot Lava is offline   Reply With Quote
The Following User Says Thank You to FR-S Hot Lava For This Useful Post:
JesseE (03-12-2013)
Old 03-12-2013, 05:54 PM   #7
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Everything already stated is correct except maybe what the member above me said.
I don't have a garage so I kept my stock wheels in my basement when I had the winter tires on. Every morning when I sat in the car for 3-4 minutes to warm it up, the light would go away because it could pick up the sensors on the stock wheels/tires.
After I drove a continuous ~15 miles, the light would come on. I had it down to a science where I knew where the light would come on during my drive to or from work.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 03-12-2013, 05:58 PM   #8
markitect
Drives: Scion FRS
Indeed I did supramkivtt2jz
markitect is offline   Reply With Quote
Old 03-12-2013, 05:59 PM   #9
HunterGreene
Hail Magnet
Yes, the car checks for the sensors every so often, at least once a day, or after a certain time of operation. It basically pings them.
However, the sensors will activate if one of your tires gets low, so its called an "Active" TPMS. Just keep an eye on your tire pressure every so often, and you will be fine.
Old 03-12-2013, 06:01 PM   #10
HunterGreene
Hail Magnet
Originally Posted by markitect View Post
I sprayed lithium grease into the A/C pulley trying to get it into any groove, hole, etc. It fixed the problem, for about 3 months.
What the hell?!?
The Following User Says Thank You to HunterGreene For This Useful Post:
Cajun (03-12-2013)
Old 03-12-2013, 06:15 PM   #11
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Originally Posted by HunterGreene View Post
What the hell?!?
Im 100% sure he was replying to this thread
http://www.ft86club.com/forums/showthread.php?t=13173
he just clicked the wrong thing, scrolled down and replied without looking
supramkivtt2jz is offline   Reply With Quote
Old 03-12-2013, 06:29 PM   #12
OrbitalEllipses
Drives: Attitude
It definitely pings them at least every 15-18 miles of continuous driving.
Old 03-12-2013, 06:35 PM   #13
fistpoint
Drives: Supercharged Golf Cart
Use google, search for "TPMS bomb".
Build one.
fistpoint is offline   Reply With Quote
Old 03-12-2013, 08:58 PM   #14
rbizzle004
My light goes off if I drive 20 miles in a trip. Eventually after a few short trips in town the light automatically turns off. I park in my garage but my summer tires with sensors are in the basement on the opposite side of where the garage is.
rbizzle004 is offline   Reply With Quote
Would you buy a car from a dealer that stuck a dealer (ad) plaque or sticker on cars? HitTheGas Off-Topic Lounge [WARNING: NO POLITICS] 49 04-29-2013 04:37 PM
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 04:14 AM
can I get a re work tint from dealer? marky Scion FR-S / Toyota 86 GT86 General Forum 18 01-23-2013 06:06 AM
Misleading Moto iQ article... MF_DEUCE Scion FR-S / Toyota 86 GT86 General Forum 4 12-09-2012 08:32 PM
Are 17" wheels too big? Might work 16's work a little better? rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 05-10-2012 11:09 PM
