Seems Legit
Drives: Toyota
FR-S/BRZ/BRZ (Smart Key) Wiring Info
Finally made it to the requisite 10 posts before you can create a thread.
Just what the DIY junkie needs. FR-S Wiring Info BRZ Wiring Info BRZ (Smart Key) Wiring Info Enjoy :happy0180: |
| The Following User Says Thank You to ecko04 For This Useful Post: | Trap63 (11-22-2013) |
#3 | |
Seems Legit
Drives: Toyota
If you have to ask what you can do with it, you probably shouldn't be doing anything with it. The information in the PDFs alone is enough to install a remote start, but you'd lose a key in the process. In conjunction with some data bus modules (AL-DS, FLCAN, BLADE) you can avoid losing a key and have most of the hardwiring controlled through data. You'd also need to wire a relay (such that the vehicle thinks the clutch is being pressed during the remote start sequence) to interface with a remote start that had a manual transmission mode, (i.e. Compustar FT-6200-S or higher end Viper/Python/Clifford/Automate) systems. Also, any information you'd need related to the audio system is included so if you're changing speakers or the headunit. If you wanted to integrate window control modules (DEI 530T) so the windows automatically roll-up when you lock the doors, that information is there as well. The benefit of directechs is you have a guide to wire color, wire location, and pin location but you better still use a multi-meter to verify. So for me, directechs wiring info is the holy grail of any 12v electronics person...in conjunction with my trust multi-meter I can do nearly anything, very easily. |
#4 | |
Dismember
Drives: 2013 Red Scion FR-S
Sounds like buying a kit would make this much easier. I'm not into hacking it. |
#5 | |
Seems Legit
Drives: Toyota
There are other elegant, albeit more involved, methods of completing the remote start rather than placing a key inside a box, hiding said box then running the coil around the key cylinder/ignition switch. In conjunction with the directechs documents, properly wired relay, purchase either 2 FLCANS and mated with the appropriate Directed or First Tech remote start system you can complete a remote start; given you have the cables to program the aforementioned data bus modules. Last edited by ecko04; 03-12-2013 at 08:31 AM. |
#7 |
Seems Legit
Drives: Toyota
#8 |
Dismember
Not sure about Texas beer, but we have some damn good breweries in California. http://beeradvocate.com/beer/profile/112/412
After two beers at 9%, you'll be confusing red for blue. |
#9 |
DNGZONE
Drives: Raven FR-S
#10 |
Seems Legit
Drives: Toyota
Yeah I still have them somewhere
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#11 |
Dismember
#12 |
Dismember
I'd really like a remote start with windows down feature that can use the factory remote or something similar. Also, does the remote start keep the car on when you get in and drive away or do you have to put the key in and turn it on? How do you turn the car off, then?
#13 | |
Dismember
#14 |
Drives: 2013 FR-S 10-Series #1394
Sorry to bump this again, but same as the other poster - do you still have these? The links on the OP won't open. Specifically the SmartKey one. Thanks!
| Smart Key options? | Sythellri | BRZ First-Gen (2012+) — General Topics | 39 | 02-25-2017 12:11 AM |
| Where do you put your smart key? | Surok | Scion FR-S / Toyota 86 GT86 General Forum | 61 | 03-03-2013 05:01 PM |
| So is there a DIY yet for BRZ headlight wiring for the FR-S? | seven | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-25-2012 09:24 PM |
| Smart key? | tawheed | BRZ First-Gen (2012+) — General Topics | 5 | 10-18-2012 01:19 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
