Old 03-03-2013, 08:35 PM   #225
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Painted mine today, used duplicolor metalcast and the clear coat from automotivetouchup.com. Did three light coats of the metalcast, followed by wet sanding with 2000 grit, then two coats of the clear. In a few days I will cut and buff it but it came out great so far. Very happy with the results.
Supplies:
Results:
Flat Black VW is offline   Reply With Quote
The Following 4 Users Say Thank You to Flat Black VW For This Useful Post:
marky (06-12-2013), SILENT (05-15-2013), TOTO_86 (05-14-2013), ZeHeadBanger (10-31-2013)
Old 03-09-2013, 03:15 PM   #226
milenko11
Drives: no
Did this today. The color turned out great however the paint did not. It's textured. Now I didn't sand because I forgot to buy some. Can I just try sanding it down good tomorrow and then clear or should I strip all of the paint off and start over?
milenko11 is offline   Reply With Quote
Old 03-09-2013, 04:26 PM   #227
suaveflooder
I LOVE the red tails! I'm a chicken, though. I will probably spend the money and get them professionally painted, although that clear coat from automotivetouchup.com is looking promising.
suaveflooder is offline   Reply With Quote
The Following User Says Thank You to suaveflooder For This Useful Post:
hmong337 (07-24-2013)
Old 03-19-2013, 01:28 PM   #228
mottor
mottor's Avatar
I used the same clear coat paint and had issues with it coming out very blurry. I tried buffing it out and still no luck. I'm going to strip mine down and do them again this week, do you have any recommendations for how to use the clear coat? I did 3 light coats with it last time.
2013 Asphalt FR-S 6MT - Perrin 2.5" Catback Exhaust - Grimmspeed Strut Tower Bar - Grimmspeed Master Cylinder Brace
Grimmspeed Hood Struts - Grimmspeed 86 Oil Cap - Grimmspeed Boxer Battery Tie Down - HID - Pioneer AVH-X5500BHS - Infinity Basslink 10" Sub
mottor is offline   Reply With Quote
Old 03-19-2013, 01:49 PM   #229
xxscaxx
Drives: 2013 SWP BRZ
You can't sand down the last layer of red, or it will show through the clearcoat. Mine came out shiny as hell... I didn't even have to wetsand the clear.
I only did on a few spots that had tiny bumps, but other than that, it came out perfect.
For anyone using the 2k spraymax urethane clear from automotive touchup, just be aware it only has a shelf life of 24 hours. I learned the hard way by "testing" it on a different headlight first and then it turned solid on me and had to buy another one.
xxscaxx is offline   Reply With Quote
Old 03-19-2013, 02:02 PM   #230
mottor
mottor's Avatar
I buffed the last layer of red to a nice shine before applying the clear and it was really blurry afterward. I'll try to post pics later. It even came out blurry over the section that I taped off to leave clear turn signals. Did you apply the clear in several light coats or a couple of heavier coats?
Old 03-19-2013, 08:49 PM   #231
Justin91M
Justin91M's Avatar
Drives: Bagged RB8Six
Mine came out with a little bit of a matte look even after clear coating and wet sanding. Any suggestions on how to get rid of the matte look. Cant really tell from this picture but from like a side angle you can tell. Ill try to post another photo from the side when I get off from work.
My Bagged Rocket Bunny FRS!
2013 Asphalt FR-S MT.
IG: itsjay8six
Justin91M is offline   Reply With Quote
Old 03-19-2013, 11:11 PM   #232
xxscaxx
Maybe whatever you used to buff it messed with the clear... but i wetsanded each layer up until my last coat of red, then left it alone and let it dry, then hit it with the clear and it was perfect. That is weird that the taped part came out blurry. I applied it in light coats. I actually had a slight run in one spot because it was really cold when I painted them and I thought it had enough dry time and it didn't. I applied a bunch of coats though, I figured if this stuff was going to go to waste I might as well clearcoat the hell out of them
What clear did you use?
after you wetsand, you have to polish it out with a compound to bring back the shine. They look awesome in that photo lol. Maybe you didn't clear it enough?
Old 03-19-2013, 11:20 PM   #233
Justin91M
Justin91M's Avatar
I used this duplicolor perfect match clear. What I did was put about 6 layers of red and went with about 6 layers of clear, 2000 wetsand and then polished with some meguiars by hand because I dont have an orbital
Should I add some more clear coats, wetsand and then polish again maybe?
IG: itsjay8six
Old 04-25-2013, 10:32 AM   #234
smbstyle
smbstyle's Avatar
love this... but i may have to go with the red film, as I worry about opening up the factory tail lights...
smbstyle is offline   Reply With Quote
Old 04-25-2013, 11:29 AM   #235
mottor
mottor's Avatar
This doesn't require opening the factory tail lights...
Old 05-10-2013, 11:39 AM   #236
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
That looks good! Now I'm pretty convinced to do this to my Asphalt.
So what I'm getting from here is this..
-Planning to use the Dupicolor Metal cast red since it looks so nice with Spraymax 2k
-Wet sand each layer of red until the last one
-clear coat and wet sand. then polish at the very end. Would I need to do every layer of clear? Or does that just depend on how each turns out?
-enjoy
Old 05-12-2013, 09:33 AM   #237
Noob4Life
86 Noob
Drives: Firestorm FR-S
Thanks for this DIY! Here's mine, Thought I went a little dark but due to these being LEDs the brake lights are clear as day. Probably gonna wet sand recoat and clear them today, as well as do my reverse lights. Debating on leaving the reverse lights clear and just tinting the triangle.
Noob4Life is offline   Reply With Quote
Old 05-12-2013, 11:12 AM   #238
JDMSushi
JDMSushi's Avatar
Drives: JDM86
Haha shit thats dark dude.
JDMSushi is offline   Reply With Quote
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 10:02 AM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 02:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 03:30 PM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 07:20 PM
