#85 | |
IMO, the best comparison is to mate each shock with the recommended spring, for an accurate comparison. Spring cost (afaik) doesn't change based on rate, so why is that even a variable? Isn't it logical to choose the spring that is best suited for a given damper? Are Eibach's springs chosen based on the shock, or is the the shock designed around a spring? I'll be at Buttonwillow this weekend, and be more than happy to provide feedback from the passenger seat. |
#86 | ||
Drives: E46 M3 (daily) / EG Civic (track)
You and I both know there's no magic spring rate that's going to work with everyone. For a novice on street tires I would recommend using the off-the-shelf rates as they will be very well balanced for street and track. From there they can package the kit with different rates as they get more seat time. Quote:
We plan to buy a BRZ sometime this year. As time goes on and we get more seat time with the car and suspension I'll be able to answer questions like these more accurately. Our springs are chosen based on the vehicle's ride frequency and the valving is engineered loosely around that number. For some R2 kits like the S2000 we chose a low spring rate but valved them very high for consumers running 600lb+ rates. Every application is different. |
#87 |
Drives: Some rust bucket
@Jackson, i noticed that the R2 is sold outside the US. Is there a difference between the R2 valving outside the US compared to the US spec R2 (assuming for the same car)? How does Eibach of Japan differ than Eibach of US? Is R&D completey separate?
#89 | |
Drives: really slow...
The test conditions (i.e. car setup, track, temps) should be the same. |
#90 |
Drives: 2013 FR-S, raven
omg i want some TRD branded Eibach coilovers!!!
can somebody confirm?
悪魔のハチロク
2013 Scion FR-S, Raven Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite |
#92 |
Vtec Jesus
In for more
#93 |
Drives: On track
I understand why everybody wants to know why one system might appear to be faster than another, but at the end of the day, whats faster for one driver, may not be faster for another driver, right? Its all personal preference. I don't think any of these systems are bad systems.
| The Following 4 Users Say Thank You to GTM_Challenge For This Useful Post: |
#94 | |
#95 | |
Then again i'm planning on getting an alignment at Westend but not sure if you want to share your specs and i'm not sure if I want such an aggressive alignment. |
| The Following User Says Thank You to Hanakuso For This Useful Post: | rawr (04-15-2013) |
#96 |
Drives: frs
I have a set of the R2's installed with their off the shelf spring rates. But then everything else is stock besides tires. I'll be at Chuckwalla this weekend. I'd be glad to contribute to the comparison if anyone has a near stock 86 with SRC.
#97 | |
Drives: frs
#98 |
I'm not sure if I want that much camber. I'm guessing the rest of there settings is setup aggressively. Maybe I should since I need to wear these stock tires out faster. I've had the car since June and the tires still look brand new
| Eibach Multipro R1 and front and rear sway bar installed | Pekingduck | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 43 | 12-30-2013 10:59 AM |
| AST's at buttonwillow raceway | Matt Andrews | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 07-02-2013 03:16 PM |
| ◙◙◙ [NY Local] SPECIAL on Eibach Sportlines Installed | Real Auto Dynamics ◙◙◙ | Kevin@RAD | Announcements, Contests, Giveaways | 48 | 06-07-2013 02:19 PM |
| Buttonwillow Track Day Heads-Up | sv_dave | Southern California | 3 | 09-08-2012 09:20 AM |
