Old 02-27-2013, 09:14 AM   #15
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Originally Posted by Sam Strano View Post
You know that as long as you are in stock or RT that's not going to be legal... Fine in STX, but not in stock category rules
I will be moving to STX in a bit, only plan on running Dixie this year (no other big events) so I'll check with my local competitors to see if they're okay with it if I find a bracket before I make the STX move. Im just tired of the bad seating position when wearing a helmet
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
whataboutbob (02-27-2013)
Old 02-27-2013, 07:49 PM   #16
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
WOW, i am keen for this. PM me when you have done it!
I will need a passenger side one, because im upside down in australia..
Surok is offline   Reply With Quote
The Following User Says Thank You to Surok For This Useful Post:
Kido1986 (02-28-2013)
Old 02-27-2013, 09:49 PM   #17
cf6mech
Drives: FRS Silver LS1 swapped.
My only issue with the car,....seat height,...even considered taking headliner down,...feel wise,... seems like a half an inch gain can be had,.....im down with anything that lowers seat height.
cf6mech is offline   Reply With Quote
Old 03-04-2013, 03:47 PM   #18
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
I'm very interested in this as well. Not only for tracking, but for daily driving too. I have to duck to be able to see traffic lights. Subscribed!
1994 Plymouth Acclaim - Engine died and went to cash for clunkers
2001 Dodge Neon R/T- Hydro-locked engine and parted out
2003 Nissan Sentra SE-R Spec-V - Traded for next car
2013 Scion FR-S - Got taken out by a distracted driver while I was sleeping. Total loss.
1997 Mazda Miata - Current
thejevans is offline   Reply With Quote
Old 03-04-2013, 08:14 PM   #19
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
Originally Posted by DAMotorsports View Post
Sam i'm not going to say I know those rules like the back of my hand. However if the modification is for the safety of the driver then I'm sure the tech will pass them. however i will have my team look into the rules and see if i can provide additional information.
Tech might pass it, but that doesn't make it legal. Tech is for stuff falling off, not legality in Solo. And fwiw, the car is safe enough to pass government testing and all, so that's a hard argument to make (and one that would not pass a protest in stock). ST and up, have at it..... Stock, not legal.
Sam Strano is offline   Reply With Quote
Old 03-04-2013, 08:19 PM   #20
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
So glad Im the size of a typical Asian man. 5'6" and never had an issue fitting in any Japanese sports car...or airplane seats. I consider myself "travel size".
GTM_Challenge is offline   Reply With Quote
The Following 2 Users Say Thank You to GTM_Challenge For This Useful Post:
Rev Works (06-19-2013), wparsons (03-04-2013)
Old 03-04-2013, 08:30 PM   #21
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
haha!!^^
i just think ill never be happy until im in an exige.
Old 03-04-2013, 10:40 PM   #22
wparsons
wparsons's Avatar
If you look at rules for roll cages (not in pure stock classes), there's a spec for minimum clearance between the helmet and the bars, and it's definitely way more than 1/2". Safety would be for allowing a driver to move around in a crash without snagging their head on something and tweaking their neck.
I honestly can't imagine someone putting up a fight over this since it in no way helps the handling of the car.
flickr
Old 03-04-2013, 11:02 PM   #23
coyote
coyote's Avatar
Drives: Slowly
I tend to agree that it should be a non issue, but I've seen people pull out rule books and argue the most tedious of regs in order to get their hands on a $2 trophy.
And FWIW, lowering a 90kg driver will help handling.
coyote is offline   Reply With Quote
The Following User Says Thank You to coyote For This Useful Post:
Scooby South (03-05-2013)
Old 03-04-2013, 11:04 PM   #24
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Sam is talking autocross, not tracking. Sam is 100% correct regarding Autocross rules (atleast with SCCA). No matter what the arguement, its not OE and therefore not legal to run.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 03-05-2013, 01:07 PM   #25
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
In stock or RT classes... ^^^
STX should be fine..
Bill
Scooby South is offline   Reply With Quote
Old 03-05-2013, 08:03 PM   #26
wparsons
wparsons's Avatar
I realize that, my point was simply that you could argue safety on the basis that a tall driver is too close to the roof and it could put them at risk.
As for lowering a 90kg driver down, it would be interesting to see where the weight of two very different sized drivers is and what it does to the CG. I would bet that a 6'4" 90kg driver sitting an inch lower doesn't have a measurable difference in CG compared to me at 5'8" ~65kg
flickr
Old 03-31-2013, 01:54 AM   #27
serial gixxer
Count me in as well.
serial gixxer is offline   Reply With Quote
Old 04-02-2013, 08:43 PM   #28
merlin2111
merlin2111's Avatar
Drives: Widebody '94 Miata R-Package
Me too!
I <3 my Miata.
But I <3 my new BRZ even more!
merlin2111 is offline   Reply With Quote
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 07:59 AM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 05:15 PM
Inside the making of the Status Racing Ring Bucket seat! vividracing Cosmetic Modification (Interior/Exterior/Lighting) 1 10-23-2012 06:00 PM
Seat Bracket phm14 Tracking / Autocross / HPDE / Drifting 0 09-12-2012 02:02 AM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 02:27 AM
